Question about Intel Computers & Internet
I have a samsung80GB pata harddiskdrive.But nw its doesnt working.when i connect it and start my pc then a sound came from that hdd and it doesnt work.Please someone tell me hw should i repair it!
  • 1 more comment
  • Donald Tucker Mar 20, 2011
    What type of sound? If it was a Mechanical sound like a loose bearing the HDD is probebly damaged betond repair. If it was a couple of beeps, that is the power on self test failure. I think you press F2 while the system boots to acces BIOS. Then you can configure and check the disks. Hope this helps.
  • WillW18 Mar 20, 2011
    What kind of sound could you hear coming from the HDD?
  • Dashing Rahi Mar 21, 2011
    ive tested that hdd in many pc but its nt working or opening.A sound (tik tik) came from it when i conect it and swich on my pc
    Scholar:
  • 58 Answers
You should make sure the fault is with the drive by going into the BIOS settings. There should be a list of devices. Depending on the computer you have, you may need to move through a few menus to find this. If there is no PATA port/device listed at all, then there may be a problem with your motherboard. If there is a place for a PATA device in the list, but BIOS says there is no device present, then the problem is almost definitely your hard drive. Physically repairing hard drives is a very tricky process, and it is almost always more cost-effective just to buy a new drive. It certainly should not be attempted by someone with no previous experience in the subject. Hopefully your important data is backed up.
Posted on Mar 20, 2011
Asus a8000b-nw
just go to bios and enable it via advanced configuration selections and use HDD modes or search for SATA/PATA configuration just enable BOTH Mode
Feb 05, 2012 | AMD Athlon 64 3500+, 2.2GHz...
My Intel D915GAG mobo works OK with one PATA HDD. But when I try to connect a SATA HDD mobo behaves strangely: sometimes it hangs up sometimes windows (in PATA master) won't start What I...
Intel D 925 has sata 1 controller , therefor your sata 2 or 3 drive can be malfuncton with this old controller , pls connect the jumper to sata 1 speed limit position in your hard drive near the data connector
Sep 25, 2017 | Intel D915GAV Motherboard
Hi, I'm having K8V-MX Asus mother board with AMD 3000+ processor wih 1GB DDR ram, with 80 GB PATA Segate HDD connected. After adding 500GB SATA HDD to this mother board, my system performance is very...
You can get free online remote Support by mailing this problem to googolplexcorporation@gmail.com .
This may be due to two problems
1. Due to Virus
2. Due to Insufficient RAM .
You can mail for free remote Support for Viruses
Jan 27, 2011 | ASUS K8V-MX Motherboard
I am connecting my 40gb PATA HDD, but my PC doesn't start. There is no problem when i connect my 80gb PATA HDD in same PC. My 40gb HDD had detected once but it gave symbol S@ in the BIOS setup. Can U...
You did not indicate that the 40 Gb hard drive had Windows installed on it and whether it was the original hard disk for this computer.
There is a possibility the 40Gb hard drive is faulty.
Try installing the 40Gb hard drive as a slave drive with the 80Gb drive as the master drive (don't forget to set the jumper on the 40Gb hard drive as Slave. Check the BIOS to see if it detects the 40Gb hard drive, and when the computer boots up, if it can see the 40Gb hard drive and opens the various folders and files, then the hard drive is OK.
Sep 19, 2010 | Computers & Internet
Trying to install a Samsung PATA 160GB HD in my recently bought ued Solo 5300.I see no cables etc, just some pins at the back of the HD slot. Do I need to take the whole unit apart to get at any cables?...
larry, is your motherboard PATA capable? meaning, are there 4-8 red female connectors on your motherboard?
If there is no compatibility with your PATA/IDE Motherboard, you can purchase at any local computer shops PATA-IDE converters... ranging $15USD.
This converts the PATA DATA+Power to your motherboard.
The HD you have requires Jumpers. Hence why they look like card slots on the back.
Before purchasing any cables, be sure to notice if your motherboard is PATA capable and relieve less stress on you :)
Aug 27, 2009 | Gateway Solo 5300 Notebook
I hav d same motherboard which was workin fine but now it stopped detecting my pata hard disk which was primary. but sometimes it detects it n den while i m working, suddenly my pc turns off n it doesnt...
this is the connection problem. there is loose connector betn cable and your hdd. first remove the harddisk, connect cable, be sure that it is connect correctly. do connect it loosly. i hope. then your hdd work.
May 13, 2009 | ASUS P5RD1-VM Motherboard
Maxtor external HDD not detected by Vista
try to format it.it might need a quick format for you to use it. if still doesnt work check for the sata,pata cable that connects your motherboard.
Apr 30, 2009 | Maxtor Hard Drive
Help me out in connecting a second PATA hard disk
Ntldr is file important for boot up and is present in main boot drive, so you can copy it from your sata hard drive to pata, it would at least boot up, also sometimes there may be a req of changing more than one bios option to boot from other drvi, try it
Jan 03, 2009 | Computers & Internet
Keeps restarting
if you have another pc with updated antivirus
troubleshooting:
try to take your harddiskdrive to the other pc and set it as 'slave'{you can see how to set it at the front of HDD}
then start windows;scan your HDD by antivirus,and delete the detected virus!
antivirus: kaspersky or avira will do.
hope it will help you. tnx 4 using fixya!
Oct 15, 2008 | E-Machines eMachines Desktop PC
Sata hdd not detected.
Check the bios to see if it made the pata drive primary. If it did the system will try to boot off of your backup drive and you could think that it is not seeing your sata drive. If that is the problem you must go into the drive configuration and make the sata primary.
Nov 21, 2007 | Toshiba Portege 7100 Notebook
Computers & Internet Logo
127 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
