THE PCB RJBX0272AA SHOWS SIGNs OF BEING OVERHEATED, BURNED...WHERE I CAN GET A REPLACEMENT
Faulty Countax PCB with burned out resistor and no Circuit Diagram
You are right to be cautious as it is unlikely the resistor committed hara kiri. The circuit of the board would be fairly simple to puzzle out and draw but I feel the board represents only a small part of the whole circuit of the machine and the reason for the burned resistor could be far from the board.
Circuit boards can be refurbished or more likely an exchange is offered with a refurbished board, but in this case with such a simple board it is likely they will provide only new ones.
The value of the resistor could be calculated by any competent electronics engineer - if he has the will to do so.
I feel you need the circuit diagram of the whole machine or the services of a good white appliance engineer. I suggest you visit the manufacturer's website support section to enquire further.
Jun 16, 2015 | Dryers
When driving the car surges or kicks and bucks
Classic signs of transmission trouble. First I would inspect the transmission fluid. It should be pink or light red. If your transmisson fluid is ok, then its probably the transmisson control module. Dark fluid with a burned smell indicates worn clutches/overheated transmission. Changing the fluid and filter might help, but the transmission is already severly worn and will not last very much longer. Transmission replacement is definatly in order.
Dec 08, 2013 | 2003 Pontiac Grand Am GT
2003 ford focus headlight plug burned out
this sounds like the wires in the plug have shorted together at times and overheated the plug.or the wiring near the plug touched and overheated,look at the wiring from the plug back a ways and see if it looks like it has gotten hot or signs of melting,you may need to repair the wires when the plug is replaced.check the headlight bulb as well for signs of getting hot at the base of the bulb or just replace the bulb.
Mar 25, 2011 | Ford Focus Cars & Trucks
WHIRLPOOL COMBIMATIC WASHING M/C PURCHASED IN 1999 -PCB IS BURNED. POSSIBLE TO GET IT REPAIRED OR MODEL IS OBSOLETE?
I doubt you will be able to repair the pcb, but you should have no trouble getting a replacement, most manufactures keep spares for a period up to 10 years
Contaci the maker direct.
Feb 01, 2011 | Washing Machines
What are signs of a burnt out coil in sub
Check the bronze-colored coil underneath the foam cover. Note whether it looks worn, burned, warped or distorted. This may be the cause of your sub sounding fuzzy or muffled, which means it needs replacement.
Look at the fuse inside the speaker and test it if you know how. This is a likely problem that causes your sub to power up improperly, play sounds at about half the volume or intermittently fade in and out. If the fuse is discolored or shows a short, you'll need to replace it
Dec 13, 2010 | Kenwood KS-706HT System
Overheating after head gasket replacement
signs your water pump isnt workin i had same issue
Aug 01, 2009 | 1993 Toyota Camry V6
Where, in the UK, can I obtain Amcor replacement parts?
the thermal break is there for a reason, the motor has overheated, if this was due to a towel or other item covering the unit great remove the the obstruction and replace the thermal break. however the major cause is that the bearings have dried up on the motor and it has started to seize, which means replacement.
Mar 31, 2009 | Amcor MD250 Dehumidifier
Burned resistor, need value for replacement
I re-drew the schematics from the PCB-layout and did some backward engineering to determine the resistor value. The machine is now again in excellent working order.
Jan 20, 2009 | Sewing Machines
Car overheating
thermostat stuck close, was your cooling fan on while this was happening?
Dec 23, 2008 | 1999 Subaru Legacy
Need some parts for BNT1500AP
If you can find a manual - you probably will not find parts- total board replacement or unit replacement is your only route Do come back to tell me I am wrong - it will be invaluable info for all of us.
May 17, 2007 | Powercom (BNT-1500AP) UPS System
62 people viewed this question
 Grubhead
Grubhead
