While using an USB number pad, every key strike shows an on-screen display for NumLock. How do I disable this feature?
  • 823 Answers
The number lock key is located on the right side of your keyboard near the extra number keypad. it is in the top weft hand side of the number keypad. it says " Num Lock" on it and has an arrow pointing upward (usually). If you start with the last key on the right side of your keyboard it should be located four keys over.
Press it to turn on and off the number lock feature.
Posted on Mar 20, 2011
How to turn on number pad
Press the NUMLOCK key a couple of times till you get it working. Usually the NUMLOCK key disables/enables the 10-key number pad.
-GWOOD
Jul 18, 2014 | Gateway Computers & Internet
Lenovo p580 numlock off
What options have you tried ??
Number Lock on IBM Laptop Computers b> Laptop computers have the advantage being portable and self-contained, but among their drawbacks is a keyboard without a separate number keypad. While for most applications number keypads are unnecessary, they can be useful for data entry. Laptops sometimes provide a number keypad by giving certain keys double duty, allowing them to enter numbers rather than letters when a "Number Lock" setting is turned on. Number Lock, however, can get turned on accidentally, or enabled by an operating system by default, which can really mess up your typing. If typing "M" ends up displaying a "0" on your screen, Number Lock is probably the problem.
Try to locate the function key. On a T-series ThinkPad, it's in the lower left hand corner. It should be labeled "Fn," and the lettering may be blue, green or red instead of white. If your laptop lacks a "Fn" key, use the "Shift" key for Step 3 below instead. Locate the key labeled with "NmLk". On a T-series ThinkPad it shares a key with "ScrLk" which sits on the very top row between the "PrtSc" and "Pause" keys. On other IBM laptops, the "NmLk" key might share a key with "Delete." While holding down the "Fn" key or the "Shift" key, depending on your model, press the "NmLk" key. This should turn off Number Lock and restore your keyboard to its usual state. Number Lock on an IBM laptop is a "toggle" setting. You can turn Number Lock on by following the same steps.
also Examine your keyboard to ensure your "Number Lock" key is not activated. This activation is indicated by the key being lit up. If the key is activated, press it to deactivate the lock. The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor. In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
Jan 30, 2013 | Computers & Internet
Where is num lock key on Dell 5030
If there is no NumLock key then pressing the Fn (Function) buttonshould enable the number pad on the keys that have the Blue numbers onthem. On most laptops (dont know your model) there is a numlock key asthis allows the user to type numbers with two hands and not keep oneholding the Fn button. You would normally press the Fn button and theNumLock option to switch it on and every time you pressed the keys withthe numbers on it would use the number not the letter, pressing the Fnkey with NumLock on would normally allow the letter to be used withouthaveing to disable the NumLock.
This assumes of course that the normal letters are stamped with thenumbers on, if not it is most unusual, I don't think I hav eseen alaptop keyboard without numbers or the NumLock / Fn options. There areUSB number pads available that you can buy, these simply plug in to anavailable USB port and it is like an extension of your keyboard.
Please, please, please, we need to know how we aredoing! Please rate our help to you and leave us a comment so we could go onhelping people like you that need our assistance and expertise! Thank you and, Thankyou for using FIXYA! Bestregards,
Junior
Sep 18, 2011 | Dell Inspiron M5030 Laptop
Iwant to be ablleto balance check book usig the right side calculator pad
try the combination of
Fn Key and NumLock Key (both Fn and NumLock will be of a diff colour on the Key board) and you will have the numeric key pad available
and the same function again after your work will unlock the nummeric key pad also
hope could be of help
Mar 28, 2011 | Dell 0Y3740 Keyboard
My IBM think pad is giving me a problem I am trying to use the k key the l key and it puts the number instead of the letter that i request the numbur lock key is not on i have pushed every button and it...
if the U, I, O, J, K, L, M buttons are also displaying numbers when you type, then your number lock is turned on, use the FN-key + Numlock to turnit off, or just the numlock key alone should fix the issue
Sep 22, 2010 | IBM Computers & Internet
How do I change the extension names and numbers
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number.
Enter extension number you want to change the name on.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name.
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
Aug 23, 2010 | NorStar M7324 Telephone
How can I change a name on a display screen for the telephone model M7310?
Aug 20, 2010 | NorStar Meridian M7310 Phone
My computer keyboard is typing numbers instead of letters.. any suggestions on how to fix it
This is because most notebook keyboards have a number pad incorporated into the right-hand side of the keyboard. Numbers are being typed because the NumLock is active.
To disable this function press the NumLock key (might be marked NumLock or have a symbol that looks like a calculator on it) on the keyboard (you might need to press the Fn function key and the NumLock simultaneously).
http://www.pcdoctor-guide.com/wordpress/?p=2446
Nov 25, 2009 | Compaq Presario 700 470024-192 Notebook
How do I change the name that is displayed on my M7208 Meridian Telephone.
Programming2.gif is done on 7310, 7324 and 7316 type sets.Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the name on.
Sep 30, 2009 | Lands Phones
Extra characters display when key pressed
Check the NumLock Key. If your keyboard isn't typing the correct characters, you may have the incorrect input language selected. Many laptops will convert most of the keyboard into a number pad if NumLock is enabled. Press Num Lock + Function or Function then NumLock to make sure its disabled.
Cheers!
J the Guru
Aug 12, 2017 | Microsoft Visual FoxPro Professional...
Computers & Internet Logo
52 people viewed this question
Alun Cox
David Payne
David Payne
