Question about Mitsubishi Televison & Video
I replaced my convergence chips in my mitsubishi projection tv, the convergence is still out and does not move at all when I try, also there is still the bow tie - the top and bottom center pull in. Did i get bad chips or could the power supply be bad? not sure please help??
    Novelist:
  • 99 Answers
Hard to say what might be the problem, but I would be checking for the following:
a) verify all fuses (pico fuses) are not blown. They look like yellow, or green resistors typically and should be marked with some sort of "Fxxx" designator
b) Verify resistors around the STK chips are of the right value
c) Verify your soldering connections
d) It is possible the part you installed was defective. Verify you cannot move any color in any direction. (horizontal or vertical)
e) Try to verify if power is getting to the IC - if so, then likely an IC problem. If not, likely a fuse problem.
f) Finally get a schematic and verify the pinout from the STK chip to the red,blue, green connectors to ensure you did not accidently remove a surface mount resistor.
Posted on Mar 20, 2011
Testimonial: "thanks for the help"
The picture on my tv seems to look like what my kids say 3D what could be the problem?
The problem of your tv is the convergence. Use the original remote then go to setting menu then you will see the convergence section. Try to adjust the color, you should move them left,right and up,down. If this color does't move far enough the convergence chip is defective and must be replace. This convergence chip is located inside the tv t has a large aluminum plate cold the hit sink and the chip has a marking of STK---followed by numbers if you are handy in electronic trouble shooting I can guide you but be sure to unplug the unit first or you can contact a technician to do it for and save you from stress. Good day and best regards.
Jul 28, 2011 | Mitsubishi WS-55907 55" Rear Projection...
On my HD1080 Mitsubishi projection flat screen 55809 the picture is bowed on top and bottem and it look as if the projectors themselves are offset, but the picture is clearer as you come toward the center....
It could be one of two things: Either a bad solder joint or convergence IC failure.
Convergence IC failure is very common. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
When you notice the symptons Use this simple test to verify.
Go to the users menu on the tv.
Look for the converge option probably under setup or video setting. Converge is short for convergence to align the red and blue colors to the green color.
If you cannot move the red either horizontal or vertical, then the STK chip has failed for red section.
If you cannot move the blue either horizontal or vertical, then the STK chip has failed for the blue section.
If you can move both in each direction then the problem is something else.
Note if one STK chip fails, you replace both regardless
Feb 20, 2011 | Mitsubishi WS-55809 55" Rear Projection...
When my 65 inch Mitsubishi tv is on for about 10 minutes the colors get al blury and almost looks like 3D without the glasses.It is nine years old Model number WS-65819.It doesn't clear up
Your Convergence ICs are likely failing or it is a bad solder joint related to that area. It is very common on rear projections. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
Note if one STK chip fails, you replace both regardless. There may only be one STK chip in this set. If there are two, they will be right next to each other.
Feb 20, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Tv is showing double images, not lining up
Your Convergence ICs have failed. Replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu.
Look for the converge option to align the red and blue colors
Feb 20, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Picture is no longer working properly. Picture is blurry and colors are all wrong. Ghost image. Happened all at once not gradually. What needs fixed mitsubishi 65" medallion series. appox 7 yrs old
Your Convergence ICs have failed. It is very common on rear projections. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
Feb 19, 2011 | Mitsubishi WS-55819 55" Rear Projection...
62" mitsubishi tv wavy picture
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jun 07, 2010 | Mitsubishi WD-62525 62" Rear Projection...
SAME TV(mitsubishi HD1080 series)-- corners of screen are bent
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 21, 2009 | Mitsubishi WS-55805 55" Rear Projection...
Convergence problem--blue lines won't line up
  • Screen looks 3D
0667c5f.pngSOLUTION
Jun 19, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Distorted picture
  • Screen looks 3D
0667c5f.pngSOLUTION
Jun 18, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Picture curved in
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
May 22, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Open Questions:
Televison & Video Logo
135 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
