Question about InFocus Proxima DP6155 Multimedia Projector
DP6155 Shuts down after short time
I have two DP6155 projectors. They seam to both have the same issue. They will work for about a minute and then shutdown. If I setup the projector upside down with no inputs and turn it on it runs for a long time with the white default screen. Is this a power supply or heat issue?
Thanks,
Steve
  • 3 more comments
  • caliboy_eso Sep 30, 2008
    I have a DP6155 and untill i replaced the blub and reset thr projector it was the best thing since sliced bread, but now it wont saty on long enough for you to go to the bathroom and back before it shuts down. I replaced the fan in front of the blub, it runs alot faster and seems to keep the blub cooler.
    But the new fan still dose not help the "shuting on and off problam".
    Any help would be nice.
  • Anonymous Oct 12, 2008
    I experience the same problem. and i hear a sound likes my bulb is going out
  • etomp10291 Nov 10, 2008
    having same issue with philips cbright xg2, changed bulb and reset counter. Projector runs fine with no input. But with video input it shuts down after a few minutes. Took apart and cleaned, had no effect on problem.
  • david601 Feb 12, 2009
    Just picked up a dp6155. Plug in the power and it clicks, sounds like from the speaker. Then the yellow power comes on and I press the power switch and shazaam it fires up to the white proxima screen. 60 seconds maybe then it shuts down and starts clicking again.
    Seems like when it's cold (50 degrees) it would run a little longer.
    Also seems that as soon as I apply VGA to VGA 2 it shuts down if it is running long enough to get to that.
    Nice bright projector if you want to see the proxima logo for a minute or 2.
    I'd love to fix this.
    Thanks
  • Anonymous Apr 10, 2009
    Same problem here. Shuts down when it locates an input. The power supply side seems warmer. Must be a cooling issue, but will search more.
tinamarie49
  • 34 Answers
SOURCE: the picture become upside down
You need to change it to front/ceiling in the menu function of the projector.
Posted on Dec 05, 2007
  • 5 Answers
SOURCE: i have an alignment problem with colors and i've found a little mesh screen
yr previous buld is it burn out or explode ?
if explode might be the tiny glass neeed to service (cleaning)
please do a tilt correction
do manually
Posted on Jul 10, 2008
SOURCE: White vertical line on left side of screen
omg, I just figured out why OUR projector was doing this! There was an adaptor plugged into it that we use to hook it up to cable to watch games/tv shows sometimes...once I unplugged that from the projector the lines dissapeared!
Posted on Oct 02, 2008
  • 105 Answers
SOURCE: lcd projector projects images upside down???
if you go through the projectors setup menu you will find the option to invert / flip and rotate image adjust as required
REgards Al "alastech"
Posted on May 29, 2009
projdoc
  • 2237 Answers
SOURCE: projector lamp shows blue on white screen
the red is cutting out. white=blue+green+red. without red, you get blu+green, or cyan. if this was an lcd projector, i'd say it's a burnt light filter, the red lcd, or the lcd has come unplugged. but since this is a dlp projector, you have either a dmd board issue or a main board issue. either way, it'll be pricey.
Posted on Aug 18, 2009
What could be the issue if my projector turns itself off after only running for 1-2 minutes?
It maybe a problem with your lamp as they can run for a short while then shut down.
When it shuts down do you get the lamp or temp indicator coming on?
Feb 01, 2013 | Sony VPL CS1 Multimedia Projector
Keeps turning off
So, Shutting down to protect itself. The error light says it needs service, Cycling power makes it work for a few more minutes, then the Panasonic safety circuit shuts it down. Projector shuts down when bulb life gets to the danger zone, and also when its heat sensor says there is a problem.
So you have a bulb life issue or you have a dirty projector / fan cooling issue??
I say clean it up with some compressed air when it is cool, then check the # of hours the bulb has on it (in the menu).
Lastly brace yourself, the bulb is gonna hurt you :-$
Jun 27, 2010 | Panasonic PT-AX200U Projector
My proxima dp6155 projector after any time looks with a vertical purple line in the right side, whats the problem
reset the settings to factory default. there may be a resolution issue. make sure it matches the source. if the line is straight and goes right along the pixel line, you may have an lcd issue. if it's blurred, it could be a bad polarizer.
Dec 16, 2009 | InFocus Office Equipment & Supplies
Need part number for DP6155 blue polarizer
unfortunately, parts are no longer made for that model and the fried polarizer is a common problem. there aren't many of them out there anymore. you might check ebay, but chances are they'll all have the same issue. good luck.
Dec 05, 2009 | InFocus Proxima DP6155 Multimedia...
Shut down
maybe there is a things that cover the exhaust fan some kind of a book or your laptop, or something... then check also the air filter maybe it so very dusty.
Oct 28, 2009 | InFocus Proxima DP6155 Multimedia...
Powers up but shuts down right afterward
there is a edge connector on the power supply board that goes into a socket on the main board. this connector gets corroded after a while and needs to be resoldered. you could do it yourself (if you're handy with a soldering iron) or send it in for repair to an infocus authorized service center. try av solutions in ny. they're pretty good.
Oct 21, 2009 | InFocus Proxima DP6155 Multimedia...
Viewsonic PJ556d shuts down after 30-60 seconds
My solution sounds dumb, I had the same issue. Took the lamp cover off the bottom. The screws were loose holding in the lamp. Maybe they heat and expand and eventually work their way out and the lamp doesn't make good contact. Just tightened mine up, the unit would power off after 45 minutes prior. Been on now for 5 hours, no trouble.
Sep 15, 2008 | ViewSonic PJ556D DLP Projector
ALIGNMENT Problem - InFocus Proxima DP6155 Multimedia Projector
if the lcd panels have become misaligned, it is time for a new projector, the parts are no longer available for this unit, and it needs the most expensive part, the LCD block
Jul 19, 2008 | InFocus Proxima DP6155 Multimedia...
InFocus Proxima DP6155 Multimedia Projector Logo
201 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
