Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Help! My Husqvarna YTH 2046 Riding Mower just died yesterday while I was running a pull behind sprayer. The sprayer battery connecter on the positive terminal was smoking b/c the clamps were touching and created a potential fire hazard. I disconnected, let the clamp cool down and wrapped it good with electrical tape, then tried to charge the mower battery, but the mower would not crank, and there is nothing happening when I turn the ignition to start (led screen does not even work). Today I purchased a new battery and installed, still nothing. What should I do now?
  • 2 more comments
  • mobaker Mar 20, 2011
    Kelly,
    Thanks for your reply. My Product number is 96045004; Serial number is 040207B012250. I have a Kohler Courage 20 engine. I do have the original Owner's Manual in my possession, and I really hope it just a blown fuse. What do I do now?
    Morris
    Kelly,
    This is actually a Husqvarna YTH 20K 46 model, not a 48 model.
    Morris
    Kelly,
    Thanks for your help. I found the fuse location after reading the owner's manual and spotting it just above the accelerator on the right side of the mower. The fuse wass 20 amp, and it was blown. I just replaced it with another 20 amp fuse, and the mower cranked right up with no problems.
    Yes--Kelly helped me by determining that the fuse had blown, which was the exact problem.
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly. I am looking for your service manual but beed to know if your mower has a number on in ending in 3300, 3301, 3302, 3303 or 3304. An example of the number I need would be like this: 96043003300 The 3300 series numbers above are just the first 5 of 10 models.
There are 10 different service manuals for this mower and my best guess is the model number is something like this: YTH20K46
I think you have a blown 30 Amp fuse but need to find the location in the manual so I can pass that to you.
There is the possibility that the engine alternator has also failed also but, you said the LED was blank and the mower does nothing so that in itself points to a fuse / wiring issue.
From what I can tell the fuse is a flat bayonet type fuse and should be located on the left side of the mower about 6 inches in front of the mower deck looking from the top. I just can not tell what elevation the fuse is at. This fuse is in the circuit between the battery and the Amp meter. A second look for the fuse and it appears to be in the exact area even with the left foot pedal. Look in that area vertically for the fuse.
Thanks for choosing FixYa,
Kely
Posted on Mar 20, 2011
  • Kelly
    Kelly Mar 20, 2011
    See if you can find that fuse and after that I hope you have a meter because everything I pass in future responses will require you to take resistance and DC voltage readings. Given the circumstances you passed before about the terminals touching I think the alternator blew the fuse.
    I think I have your manual but the 96045004 number seems to be missing the last digits. At the moment I think the electrical systems are the same. What I cam concerned about is the possibility of other wiring damage caused by the alternator before the fuse blew. If the fuse has blown then there should not be wiring damage. HV is pretty good about making sure their wiring harnesses are capable of withstanding a direct short. However... if there by chance was a chassis short on the positive lead from the alternator to the battery all bets are off.
    Kelly
  • Kelly
    Kelly Mar 20, 2011
    Gotta love it when you can solve what appears to be a major problem without hauling it to a repair shop. This made my day!
    Good for you!
    Kelly
Husqvarna YTH 21K46 Riding mower starts but dies after running about a minute
It is most likely a fuel problem of some sort. If I recall, these have the Kohler Courage engine and a fuel cut-off solenoid below the fuel bowl on the carburetor. Make sure fuel is getting to the solenoid and pull the bowl and check for fuel there. It could aslo be the fuel is old or contaminated.
I've had similar issues and it's usually been bad fuel and / or dirty carburetor. The jets could be clogged as well so a good cleaning may do the trick.
Jan 25, 2016 | Husqvarna Garden
Husqvarna riding mower engine dies when you engage blades
Check engine revs are to low and pullies underneath not seizing up.
Aug 16, 2014 | Husqvarna Yth 150 Riding Mower Illustrated...
Husqvarna YTH 180 transaxle fluid
If it is not leaking there should be no need to add oil, if it does not have an external resivoir you would fill throught the filler and leave a 1/4" air gap to allow for expansion.
Aug 10, 2012 | Husqvarna Garden
Husqvarna YTH 2448 shuts off when I let out clutch or engagae mower blades
Hi, check or replace the switch on the seat, basically its not telling the safety system that you are on the seat. Regards Phil.
Jul 07, 2012 | Husqvarna Garden
Husqvarna riding lawn mower yth 2448 cuts off as if running out of gas after 10 - 30 minutes
Mine would run for about 15 minutes and die. I pulled the carb off and thoroughly cleaned it. Inside the float bowl there is a plastic device held on by two phillips headed screws. Under this device are two tiny tubes with small holes in the side of them. Make sure these are clean. I used carb cleaner in a spray can and a tip cleaner. Make sure to wear eye protection if you use spray cleaner. I reinstalled the carb and, so far, it is working fine.
Apr 08, 2012 | Husqvarna Garden
I need the owners manual for Husqvarna YTH1542 riding lawn mower.
hi there
paul46 here
please find website address for yth 1542 owners manual for you to download and save
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2007/HOUS2007_O0702036.pdf
check it out
cheers pauly46
Apr 30, 2011 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
When first start my husqvarna yth 150 runs fine goes up hills plenty of power after running for while starts loosing power wont go up hills will stll move on flat surface
Hi, it sounds like the hydrostatic drive is getting too hot. Remove the battery and battery cradle and clean all grass and debris from around the hydrostatic drive and cooling fins. Also check the fan wheel on the hydro is not damaged. Regards Phil.
Apr 28, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
976 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
