Question about Sony Playstation 3 (PS3) Console
Where is the save destination on my ps-3 - Sony Playstation 3 (PS3) Console
    Filmmaker:
    Uploaded 5 video answers.
  • 84 Answers
File formats that the PS3 doesn't recognize as something that it can play can only be saved to a USB storage device, or a memory card. You can't download anything to the PS3 hard drive via the browser that you couldn't copy to it from a USB storage device. That is what the error message means. You have to connect an external storage device, because the PS3 won't store this file format on the internal drive. This protects the integrity of the system. If you connect a USB drive or memory card (you will need a USB adapter for the memory card if you don't have a launch PS3), then you can download anything that you want using the PS3 web browser.
Posted on Mar 22, 2011
I cannot scan my documents. I got a message from Scansnap: La destination specifiee (dossier d'enregistrement des images) est incorrecte. Specifiez une nouvelle fois la destination.
Go to the settings of Scansnap and look for save folder or destination folder. The error message usually appears when the destination folder has been deleted.
Mar 28, 2017 | The Computers & Internet
Connect storage media at save destination
How much free memory is left, and how are you tying to download your data? Via internet, media server, or usb? For the bluetooth devices, they may not have the same signals as your ps3.
Sep 26, 2013 | Sony PlayStation 3 (120 GB) Black Console
Saving commandos 3
hey
i had this problem with my commandos 3 too.
i had a commandos 2 installed in my pc. i copy a folder named output and its files to the main folder of commandos 3 and the problem just solved. i hope it works for you too.
good luck
Jan 18, 2012 | Eidos Interactive Commandos 3 Destination...
How to set multiple destinations?
Some garmin satnavs allow you to save routes which have multiple destinations. The 265WT does not so the only way to set it for multiple destinations is to use via points. First press WHERE To and enter your last destination. Press GO and then while that is active pres MENU and WHERE TO again. Enter your second last destination and press GO. It will ask if you want this to be a new destination or a VIA point. Select VIA point. Continue to add other destinations in the same way with the destinations nearest to the end going in first and the closest to the start going last.
It's not ideal especially as it cannot be saved for future use but unfortunately for some strange reason Garmin do not include the option to store routes on all their satnavs.
Jun 11, 2011 | Garmin n?vi 265WT Car GPS Receiver
It says connect storage media at the save
connect storage media at the save destination. how do i connect
Jan 28, 2010 | Sony Playstation 3 (PS3) Console
My F4240 will print and copy but wont scan
Hi
I am providing you steps for Windows XP if your O.S is other then please reply.
Solution ;
Try copying if copying is fine then Scan through WIA.
If the scanning is successful, proceed with step 3. If scanning was not successful then I request you to perform the step given in step 4 and then perform step 3.
Step 3: Manually check for DIM
The digital imaging monitor must be running for the scan to function to work. The digital imaging monitor normally appears in the system tray in the bottom right-hand corner of the computer screen, next to the time.
If the digital imaging monitor appears in the system tray, go to the section Populate Destination List.
NOTE: If hpqtra08 is not on the list in the Startup tab, this indicates that the driver was not correctly installed. Uninstall and reinstall the driver.
9. Populate the Destination List with following steps:
a. Open the HP Solution Center.
b. Click on Settings --> Scan Settings --> Button Settings.
c. In the window opened, select "Scan to button" tab
d. Click the Destination List tab.
e. Click on each of the programs you want to appear in the scan to list.
f. Click the Add button. This moves the selected programs to the Front Panel Destination List.
g. Click OK.
h. Now try the scan to function from the all-in-one.
To save the above changes I request you to perform steps given below as Dest test.
1. Close all applications including HP Solution Center.
2. Open and run the DESTTEST file from the location:
C:\Programfiles\hp\digitalimaging\bin\Under Destination:
a. (Optional) Set the Category for the Destination List scroll
down menu on WEB_APP.
2. On the 5th option "Close Dest Test After sending to Destination", put a check mark and click on Save Results Before Exit.
3. Click on Exit in the bottom.
4. Now Open the HP Solution center, Click on Settings -> Scan Settings & Preferences -> Scan To Setup.
5. You will see all Button settings on the right side under the front panel destination List. In Case If not, click on Restore Defaults, click on Apply and click on Ok.
6. Push Scan To button on the unit you will see all the Destination List on the unit. Select the appropriate one.
Oct 03, 2009 | HP OfficeJet 6210 All-In-One InkJet...
All leds light on panel
After installing the printer software you need to program scanning software.
Below are the steps to program scanning software:
To program the Scan To button:
Select Start/Programs or All Programs (Windows XP)/HP/HP Laserjet 3050, 3052, 3055, 3390, 3392/Scan
Click the Setup to open the Scan To Setup Wizard.
Select the Change the destinations that show up on the all-in-one control panel when I press the <Scan To> button and then click Next .
Check the Allow me to scan by pressing the Scan To button on the all-in-one check box.
Choose the destination by moving them from the PC window (the left window) to the All-in-one window (the right window).
NOTE: The All-in-one window might contain items set up by other computers that are connected to the all-in-one. You cannot make changes to these items.
Click Update .
To Create a destinations:
Follow steps 1-2 from the above steps.
Select Create a new destination with settings that I will specify and then select Next .
Select the Save it to my computer and then press Next .
Select the scan preferences and then select Next .
Select the scan destination folder and file format type and then select Next .
NOTE: If you wish to use a custom folder for your scan destination, you will need to create the folder prior to this setup wizard in order to browse to it.
Select the quality level you would like the file to be saved as.
Name the new destination on the computer, check the Send this new destination to the all-in-one check box, and enter a name for the display on the all-in-one. Then select Next .
Confirmation allows you to verify your settings. Select Save .
Once the new destination has been saved, the new destination will be configured as one of the Scan To destinations on the printer.
Apr 27, 2009 | HP LaserJet 1300 Printer
Ps-2 will not play any saved data from Gran Turismo-3
You can play your PS2 games on your PS3 and save your games on there
Feb 24, 2009 | Sony PlayStation 2 (PS2) Console
Saving Madagascar game on PS2
1. Click Start go to options and select save.
2. Click Start go to load files and save.
3. Reach a destination with auto save on, and the files should automatically save onto the memory card for you.
Feb 04, 2009 | Sony PlayStation 2 (PS2) Console
How to program a destination
In general, once you key in an address and then select a route, the name/route will be saved in "recent destinations." If you want to use that destination, just select it. If you want to add it to "Favorites", then select "Add Favorite" and all your recent destinations will appear. Select the one you want and rename it: E.g., instead of "220 W. Walnut St." rename it "Grandma's House" and it is set.
Oct 08, 2007 | Tomtom ONE GPS Receiver
Sony Playstation 3 (PS3) Console Logo
88 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
