Question about Video Game Consoles & Games
Keep getting 800 error stating network error and it disconnects. ps3 is 2 feet from access point, 100% signal and I have reset modem twice and have a signal booster in the house?
  • RH09 Mar 03, 2009
    i also get this 800 error but not as regular as i used to... most days i just get signed out of playstation network at around 4pm but it will sign back on 2 to 3 hours later, also anytime i tried to use my ear piece the connection just goes right down...
    Problem Solver:
  • 16 Answers
If you are using wireless connection that could be your problem. Wireless isnt to stable for connection, but it depends on your environment(where you live). You could have a slow internet connection in your environment.
Posted on Aug 05, 2008
  • ishmaellamso Aug 05, 2008
    I forgot to say that another problem could be is that your internet server(Comcast,DSL, etc.) has your firewall on on your internet use. Call them to help you turn off the firewall.
Computer won't recognize driver
Turn the modem off. Disconnect the electrical power.
Reconnect the electrical power. Turn the modem on.
This "resets" the modem, and you should be good-to-go.
Or, telephone your Internet Service Provider's "Help Desk", and get them to trouble-shoot.
Apr 20, 2014 | ASUS Cg5275 Drivers Restore Recovery Disc
I have mtnl connection with D-link modem (502T) My connection get disconnected in between download so is there anyway that my modem could restart it self when it looses internet connection.
Signal strength drop or fluctuation are common causes of RF interference.
Try these basic troubleshooting steps:
  • Change the channel on your access point or wireless router.
  • Change the location of your wireless products. Subtle changes (2-3 feet) can make a big difference. Do not put the access point or wireless router in a cabinet or enclosure.
  • 2.4GHz phones, X-10, and bluetooth devices will interfere with your wireless network. Change the location of the base for your phone, or downgrade to 900Mhz phones, or upgrade to 5.8GHz phones.
  • The wireless signal will degrade (or die completely) when going through brick (fireplace), metal (file cabinet), steel, lead, mirrors, water (fish tank), large appliances, glass, etc.
If your wireless connection is only dropping during large file transfers or when a large number of wireless clients are connecting, change the preamble on all wireless devices to short.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 21, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
My belkin wont keep connection
1. Powercycle your equipment (unplug the power to your router and your modem)
2. Wait 15 seconds then plug equipment back in.
3.If your Modem runs off signal from a tower try and get more signal simply by moving modem closer to a window.
4.Check your connections to the modem and to the router, ensure the wires are plugged all the way in.
5.Using your wireless signal from your computer pc or laptop ensure you have sufficient signal you may have to move closer to the router, once in a while you will be to far from your router to have a good connection.
6. Make sure the ventilation slots on modem and router are not blocked.
7.Check to see how far your modem is away from any electrical equipment your modem should be away at least 3 feet away.
8. If you are able to keep connection directly plugged into your modem from your computer most likely there is an issue with the router, In this case you can always reset your router there may be a configuration error in your router, To reset simply press and hold reset button on the back of the router for approximately 15 seconds or until router restarts, Caution by resetting your router will reset back to factory default and your router will be unsecure once again.
9. When your are disconnected from the internet make sure that the Connection itself isnt still connected if your connection itself is connected and you are unable to get online you may need to renew your ip address. usually your ip address automatically renew's once the router and modem have been powercycled (unplugged and plugged back in) however you may need to manually renew your ip.
10.Windows Xp: Start/Run/CMD and press ok
A.Type ipconfig /release
B.Type ipconfig /renew
Windows Vista/7 Start/All Programs/Accessories/Right click on command prompt and hit run as administrator.
B.Type ipconfig /renew then restart your computer
If you are a Mac user:Here is a link to show you how to renew http://support.apple.com/kb/TS1920 If your continue to get disconnected contact your ISP (Internet Service Provider) Check and ensure that it is not an issue on there end
Nov 15, 2010 | Belkin (F5D5231-4) Router
I have the Linksys WRT54G router hooked up thru Ethernet to my desktop PC with Windows XP. I go thru a cable modem to the internet. I have 2 laptops, both with Windows Vista on, wirelessly linked to to the...
Low or poor signal is mainly caused by the following major factors:
Going Around Physical Obstructions
Wireless networks are also susceptible to obstructions that may lead to low signal. Often, the signal gets reflected, refracted or absorbed by the obstruction.
Common obstructions are:
  • Cabinets
  • Mirrors
  • Glasses
  • Metal objects
  • Thick walls and ceilings
If you have any of these objects between your wireless adapter and access point, consider relocating your access point somewhere high to get around the obstruction.
Aug 05, 2010 | Linksys Wireless-G WRT54G Router
DSi White Console: can not connect to internet promble error code: 02...
Error Code: 020100The Nintendo DS is unable to connect to an Access Point. What to do will depend on where you are connecting from:
Connecting from a wireless home network:
  • Make sure that the DS is within 30 feet of the wireless access point and facing in its general direction.
  • Make sure that any other interfering devices, such as microwaves and cordless phones, are turned off.
Connecting from a Hotspot
  • Ensure the Hotspot location does not require an internet browser to setup an account, accept a use agreement, or enter a password before accessing their Wi-Fi serice. If the location requires any of these items, you will not be able to connect to the Nintendo WFC.
  • Make sure that the DS is within 30 feet of the wireless access point and facing in its general direction. Signal strength can vary, depending on where the access point's signal is coming from. (Please do not sit or stand in places that will interfere with the location's customers or staff.)
  • Orientate the Nintendo DS so that your body or other objects (such as walls, plants, furniture, and other people) are not blocking the signal. Also, make sure there is no interference from wireless phones (cell phones are okay).
  • If the connection continues to fail, this Hotspot may have their router set up in a manner that is not compatible with the Nintendo WFC. We recommend trying a different location.
May 16, 2010 | Nintendo DSi White Console
Got wireless signal but no internet connection
You can try to power cycle your entire network (refresh).
This often happens when you have a large network.
  1. power down ALL Computers and disconnect the desktop from the D-Link Switch.
  2. turn off all SLAVE AP's first.
  3. Turn off the Master AP and disconnect one end of the Ethernet.
  4. Turn off the D-Link Switch and disconnect one end of the Ethernet.
  5. Now, turn off your modem.
Leave them for about 10 to 15 minutes, depending on your urgency.
Turn on and connect all devices in the EXACT order.
  1. Turn on the modem. wait 2 minutes.
  2. Turn on the D-Link Switch and wait 1 minute. Then connect the Ethernet to the MODEM.
  3. Turn on the Master AP and wait 1 minute. Then connect the Ethernet to the D-Link Switch.
  4. Turn ONE of the Slave AP's. Turn on your Laptop. try to connect to the Internet. If successful, Disconnect from the network on the computer and proceed to turn on the rest of the Slave AP's, Laptops, and Desktop. If its NOT successful, power on the Desktop and try to connect to the internet.
  • If the desktop connects to the Internet, Check your D-Link's homepage "192.168.1.1" (default) for any wrong settings. If it does not connect, check your DSL Modem's settings.
If the above does not work, post what you did the day before this happened. Probably something small might have messed with the network.
Aug 15, 2008 | D-Link AirPlus DI-524 Wireless Router
Internet disconnections
Are you getting good signal from your wireless network?
Does it disconnect when you leave it a while?
Does it disconnect when you use a public wireless access point?
Are there other wireless networks that are stronger than yours?
Mar 25, 2008 | Computers & Internet
Maximum advertised distance
D-Link Air lets you access your network from anywhere you want. However, keep in mind, that range is limited by the number of walls, ceilings, or other objects that the wireless signals must pass through. Typical ranges vary depending on the types of materials and background RF noise in your home or business. The key to maximizing range is to follow these basic principles: 1. Keep the number of walls and ceilings to a minimum - Each wall or ceiling can rob your D-Link Air Wireless product of 3-90 ft. of range. Position your Access Points, Residential Gateways, and computers so that the number of walls or ceilings is minimized. 2. Be aware of the direct line between Access Points, Residential Gateways, and Computers - A wall that is 1.5 feet thick, at a 45 degree angle, appears to be almost 3 feet thick. At a 2-degree angle it looks over 42 feet thick! Try to make sure that the Access Point and Adapters are positioned so that the signal will travel straight through a wall or ceiling for better reception. 3. Building Materials make a difference - A solid metal door or aluminum studs may have a negative effect on range. Try to position Access Points, Residential Gateways, and Computers so that the signal passes through drywall or open doorways and not other materials. 4. Make sure that the antenna is positioned for best reception by using the software signal strength tools included with your product. 5. Keep your product away (at least 3-6 feet) from electrical devices that generate RF noise, like microwaves, Monitors, electric motors, UPS units, etc. 6. If you are using 2.4GHz cordless phones or X-10 (wireless products such as ceiling fans, lights, and home security systems), your wireless connection will degrade dramatically or drop completely. Anything using the 2.4Ghz frequency will interfere with your wireless network. For the average home, range should not be a problem. If you experience low or no signal strength in areas of your home that you wish to access, consider positioning the Access Point in a location directly between the Residential Gateways.
Feb 16, 2006 | D-Link Air Xpert DI-774 Wireless Router
Feb 16, 2006 | D-Link Air Xpert DI-774 (DWL-774) Wireless...
Range problem
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Video Game Consoles & Games Logo
49 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
