Question about Acer Aspire 7110-2069 Notebook
Cannot open disk 1-2- 3 for system recovery, this file does not have a program?
  • 76 Answers
You will probably find that you have to boot up the laptop with the CD in. Put the recovery disc in and restart your laptop, if asked during boot up press any key to boot from CD, do so and follow the instructions.
Hope this helps and let me know how you got on
Posted on Mar 20, 2011
How to factory reset without recovery disk
When you need to recover part or all of the files on your Acer Veriton M460 desktop computer, Acer makes it easy to do by offering a built-in recovery program called eRecovery Management.
This option uses clean operating system files, usually stored on a separate partition of your hard drive, to correct errors or return the system to its original factory settings.
You can also use this program to write separate hard copies of the eRecovery program onto CDs or DVDs in case of hard drive failure.
Create Backup Disks
If your M460 did not come with separate recovery disks, and many machines don't in recent years, you can create your own through "Acer's eRecovery Management" program located under the "Start" menu.
Click on "Backup," select "Create Factory Default Disk" and follow the on-screen directions.
The program will inform you of the number of CDs or DVDs you need and help you through their creation.
Recovery with Disks
To use your created disks for recovery, place the first disk in the optical drive and reboot the system. As it boots, hold the "ALT" key and tap "F10" repeatedly until the computer boots and you see a screen titled "Starting Acer eRecovery."
You will see three options for recovery: to factory default, from user backup or from CD/DVD. Choose the option you desire and follow the on-screen directions to initiate the recovery sequence.
Recovery from the Hard Drive
Since Acer places the eRecovery Management program directly onto the computer, you can run the recovery option while in your desktop.
Open the "Acer eRecovery Management" program under the "Start" menu and click "Restore." You can choose to restore the computer to factory defaults and lose all the personal data stored on the hard drive or only restore the operating system and leave your data intact.
Select "Yes" on the confirmation screen and then "OK" to start the program.
Recovery Vs. Restore
When performing computer problem solving, the term "recovery" is often used interchangeably with the word "restore."
In some cases, "recovery" can mean to simply correct problems, such as replacing corrupted operating system files with good ones.
The term can also refer to "recovering" the system to its fresh-from-the-factory state, which is what "restore" means as well.
Restore Drivers or Applications
Acer's eRecovery Management program also offers the option to reinstall drivers or applications, which could become corrupted or damaged over time.
This option allows you to replace the current drivers for your Windows operating system with the ones originally installed on your system.
Under the "Restore" tab of the "Acer eRecovery Management" program, click "Reinstall Drivers or Applications" to see the content list and select the files you'd like to recover.
http://supportforacer.iyogi.com/veriton/factory-settings-6.html
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireE360/AspireE360faq40.shtml
http://support.acer.com/product/default.aspx?modelId=477
Aug 26, 2013 | Acer Veriton Z290G Desktop Computer
My computer recognizes my iomega usb hard drive, but cannot open the files.
here is the best way to get back lost files.
1.) Stop using the hard drive IMMEDIATELY! Do not drag or create any files on it.
2.) Download asoftech data recovery program: http://www.asoftech.com/adr/index.html
3.) Install and run the data recovery program against the hard disk
Good luck.
Sep 01, 2011 | Iomega (34959) 500 GB USB 20 Hard Drive
How to set HP Pavilion ze4400 to factory setting
You can try one of the solutions to see if this helps your issue:
HP Recovery Manager can be accessed from the Start Menu, or by tapping F11 key as soon as you power on the laptop. Recovery Manager is used to reinstall back to factory specs_also used to make a Recovery Disk set.
http://tinyurl.com/2y4rub
  • Click Start c01403500.gifand enter Recovery in the search field. Select Recovery Manager from the list when it becomes available. Allow the action to continue, if prompted. The HP Recovery Manager opens. Alternately, click Start c01403500.gif, All Programs , Recovery Manager , and then Recovery Manager . Allow the action to continue, if prompted. The HP Recovery Manager opens.
  • Click Advanced options , System recovery , and then click Next . The PC will restart and reopen the recovery manager. Alternately, if Advanced options is disabled, click Next , and then System Recovery . The PC will restart.
  • When the PC restarts, select the System recovery option and click Next .
  • If prompted to use the Microsoft System Restore program, click No , and then click Next .
  • When prompted, select the Back up your files first (recommended) option, and then click Next . Follow the on-screen instructions.
  • When prompted to Recover without backing up your files , please STOP before clicking Next . WARNING: This is the final opportunity to change your mind about recovering the PC and deleting all the files and programs. Once you clickNext , the restore process cannot be stopped
  • If you are satisfied that you want to begin the recover process, click Next . The PC immediately begins formatting the hard drive and destroying all data.
    1.Right-click on "Computer" icon and select manage.
    2.This will launch the Microsoft Management Console.
    3.On the left side of the MMC, click on "Disk Management" and it will show you all of the partitions.
    4.Right-click on the "HP Recovery" partition and select "Mark as Active Partition."
    5.When the warning prompt appears, select "Yes" - Reboot and it will automatically boot into the Recovery Manager (without pressing F11).
  • Aug 23, 2011 | HP Pavilion ze4400 Notebook
    I used the LG smart recovery and backed up my files by clicking system back-up. Then after it changed my files that will open only to window shell commor.? Any idea how to open again my files I badly need...
    So did you mean you performed a system restore after you back up your system?If so,you can try a data recovery software to recover your files.I have succeed to recover files after system restore with Tenorshare data recovery.It can recover data after deeply scanning your hard drive to look for lost data.
    Anyway,you can download a trial version and scan your hard drive for free to check out whether your files can be recovered.http://www.any-data-recovery.com/index.htm
    Jun 25, 2011 | LG Computers & Internet
    When i open my laptop, then boot, it goes to this windows 98 startup menu which has following options: reboot to windows xp, recover windows xp w/ full hd, recover xp w/ 2 partitions, and recover xp w/ 1...
    first, recover your files. You will need to use something like this data recovery program.
    I've had to use it many times in the past but in this case you need to plug that drive into another system as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
    After you get back your files, you can then format the drive and reinstall your system.
    Apr 03, 2011 | ASUS W7J Notebook
    My computer is running slow.
    Many factors may cause your Windows 7 running slow: lack of memory, useless programs, wrong startup settings, junk files, registry redundancies, viruses or spyware and more.
    If you computer is running slow or starting up slow, you may visit this article to learn more.
    Jan 09, 2011 | Computers & Internet
    Down loaded msn explorer 8 pc will not start up TMGR missing
    The "TMGR" is a Windows Operating System component file.
    This error might occur if the TMGR file is corrupted or missing.
    However, as this is a Operating System Component file, you may resolve the issue by performing the below steps.
    First, you may try performing the SFC Scan.
    Performing the SFC Scan will automatically fix any damaged files or any errors in the Registry.
    Steps to initiate the SFC Scan:
    1) Open the RUN command window.
    2) In the RUN command window, type "cmd" and press Enter.
    3) In the Command prompt, type cd
    4) Then. type cd Windows and press Enter.
    5) Then type sfc /scannow and press Enter.
    6) This will start the SFC Scan process.
    The Computer might also ask for the Windows Operating System Disc.
    Peforming the SFC Scan should resolve the issue with the TMGR file.
    If the issue still persists, initiate the Disc checking process.
    For Windows XP:
    support.microsoft.com/kb/315265
    For Windows Vista:
    http://windows.microsoft.com/en-US/windows-vista/Check-your-hard-disk-for-errors
    For Windows 7:
    Jul 05, 2010 | Acer Aspire One PC Notebook
    Recovery partition full error
    Please go to Start + Run and type cmd
    Type chkdsk d: /F /X /R
    It will dismount and check for any errors after the system restarts
    follow the method to clean the disk space.
    ) Open Internet Explorer and click on Tools
    2) Click on Internet Options
    3) On the General Tab, in the middle of the screen, click on Delete Files
    4) You may also want to check the box "Delete all offline content"
    5) Click on OK and wait for the hourglass icon to stop after it deletes the temporary internet files
    6) You can now click on Delete Cookies and click OK to delete cookies that websites have placed on your hard drive. To clear the Internet History in IE:
    1) Open Internet Explorer and click on Tools
    3) On the General Tab, in the middle of the screen, click on Clear History
    4) Click OK
    To clean up other temporary files on your computer in Windows 98 or higher:
    1) Click Start, Programs (or All Programs), Accessories, System Tools, Disk Cleanup
    2) Choose the correct drive usually C:\
    3) Check the boxes in the list and delete the files
    Dec 10, 2008 | Gateway 2520915 Keyboard
    The file system of my hard drive become RAW.
    http://www.z-a-recovery.com/unformat-tutorial.htm
    This tutorial describes the procedure to recover one volume when
    • the volume was accidentally formatted
    • Windows reports the volume is "raw filesystem", or "not formatted"
    • An external drive failed, either flash (so called "thumb drive") or an hard disk connected using USB or FireWire enclosure.
    • MFT is corrupt on the NTFS volume, rendering filesystem partially or completely unreadable
    The recovery is done in seven steps, requiring about eleven (11) mouse clicks. Note: The older than current versions of ZAR might have been used to create the screenshots in this tutorial. We did not update the screenshots if there is no significant difference between older and current versions. If you see some option in the program which is not described in the tutorial, just leave it at its default setting.
    plashkablue_left.gif Step 1 - Get, install, and start ZAR
    plashkablue_right.gif box-top-l.gif box-top-r.gif Download and install ZAR just like you do with any regular program.
    When you run it, ZAR displays the window like the one below:
    1. Click "Next >>"
    plashkablue_left.gif Step 2 - Select processing mode
    1. Select "Recover data from a simple volume or from a functional RAID volume"
    2. Click "Next >>"
    plashkablue_left.gif Step 3 - Select physical device to recover
    1. Select the appropriate hard drive
    2. Click "Next >>" for a list of volumes (logical disks) on this hard drive
    Nov 19, 2008 | Western Digital My Book Essential Edition...
    Backup and recovery
    Delete the System Recovery Files folder located at C:\System Recovery Files then try to run the backup.1.exe program again. I also found the you have to have the Backup.2.fbw file burned to a DVD before it will restore the files.
    Rayna
    Jun 10, 2008 | Microsoft MediaRecover File Recovery...
    Acer Aspire 7110-2069 Notebook Logo
    18 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
