Speed Queen SC18 Washer-Extractor, (clothes washing machine) Machine no longer reverses direction during wash cycle, is intermittent on spin, and sometimes does not fully pump out water during extract cycle, (no clogs). I suspect contacts on dual clock motor cycling timer...? Any suggestions? Thanks, Daniel
  • earlgrey463 Aug 04, 2008
    This is a converted commercial washing maching, - FRONT LOADER, no lid switch, and door interlock has long been disconnected.
    I think the problem lies in the timer mechanism,-dual clock motors, lots of contacts switched by rotating cams. All manual, no computer, lots of relays and contactors to energize the washer motor and water pump.
  • earlgrey463 Aug 06, 2008
    I am not sure your experts have read the previously posted problem description. The drain hose has nothing to do with the cycling problem, - no leaks and it is open, the pump works properly when being switch on by the timer and relays.
    I cleaned the contacts on the timer with contact cleaner, - the washing cycle does not turn on the agitation cycle, but does go into spin cycle at the end as it should.
    Is the timer alone responsible for the wash cycle forward and reverse of the drum as well as the spin cycle, or are there other components in play. the Heavy duty contactors that actually switch the motor on and off are working, but in wash cycle, it is not starting the motor as needed. I looked at the contacts, they look OK, and the contactor is working at the appropriate time.
    What function does the small PC board on the back wall of the machine do? There is a small relay on it, as well as an IC and other electronic commponents. Any way to test it?
    Again, this is a converted commercial speed queen washer extractor, SC18 model.
    I would like to get a little more informed replies to my questions this time.
    Genius:
  • 1,665 Answers
HERE is your Speed Queen parts catalog.
Check if given part numbers assemply control motor are same with yours.
Posted on Aug 07, 2008
    Genius:
  • 1,269 Answers
It's a timer problem. The metal contacts might be dirty so you need to clean it manually. Check the timer wires or some wiring if they are still in good contacts. Re-soldering or changing wires might fix it.
Posted on Aug 04, 2008
    Guru:
  • 1,894 Answers
Have you check the drain hose for any leaks?
this can happen due to some damage in drain hose
  • 796 Answers
Check the lid switch...it must be faulty and unable to sense the direction of the spin....
    Master:
  • 521 Answers
Replace the timer and see
Posted on Aug 11, 2008
We have an Ultima washing machine and creases the cloths very badly any suggestions please
The amount of creasing you will get is directly related to the speed you select for the final spin dry cycle and the spin after the first wash cycle which occurs prior to the rinse cycle. The higher the speed and the longer it goes for the more the clothes will crease.
Experiment with different spin speeds on your machine for clothing that is subject to the creasing problem. Also do not put too many items in the machine for a wash as many people do as this will contribute to creasing. Always under load your machine for every wash cycle.
Spin drying is a compromise between creasing and maximum water removal. If you want less creasing you will need to select a more gentle spin dry speed but you will also have the clothes coming out of the machine with a higher water content and they will take a bit longer to dry. The spin time on the program may also be shorter.
In my own machines I use a gentle wash and spin cycle for all clothing that I don't want heavily creased. Running it on a wash cycle with a high and longer spin speed when the machine is spinning the clothes after the initial wash, and then again after the final rinse, will thoroughly crease the clothes every time.
Also bear in mind that different fabrics that are suitable for machine washing will perform differently and some are just too subject to creasing even if you use the most gentle wash, rinse and spin cycle. Hence you can take 2 different 100% cotton fabrics out of a machine and hang them to dry and one will be almost crease free and the other will be thoroughly creased. With these fabrics that are just very subject to wash creasing, it is better to hand wash and rinse them. Then after rinsing drip dry them or put them in the machine and spin them for 1 -2 minutes maximum just to get some of the water out and hang dry them.
Dec 28, 2015 | Hotpoint Washing Machines
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
After the spin cycle the clothes are still pretty wet
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 09, 2011 | Speed Queen AWS48NW Top Load Washer
Coin-operated Speed Queen washer: Model swtt21wn
speed queen double front load washer spinning without stop,please give some idea,thanks alot
Feb 21, 2011 | Speed Queen SWT921 Top Load Washer
My Speed Queen washer shakes and walks during the spin cycle. I have leveled the machine and ajusted the amount of clothes in subsequent loads and it still shakes. How do I solve this? Thank you!
Did you remove the shipping bolts from the back of the washer? They are located on the back, usually very clearly marked "REMOVE" and have a red or yellow plastic washer/bushing. This is a fairly common problem with front load washers, from what I understand.
They're big suckers, and they keep the drum suspension from absorbing any vibration (so the drum doesn't slam around during shipping). Good luck!
Jan 27, 2011 | Speed Queen CTSA0AWN Front Load Washer
Speed queen top load washer does not agitate properly
you need to see if the motor turns one direction during wash and the other during the spin. If so, your gearbox is faulty and needs replacement. If motor only goes in one direction at all times, then very possible, the timer is faulty.
May 29, 2010 | Washing Machines
SPEED QUEEN TOP LOAD WASHER HA4011W. Motor trips at SPIN start
I would call whoever repaired the washer back out and have them diagnose.
Jan 23, 2009 | Speed Queen AWS52NW Top Load Washer
Washing Machines Logo
244 people viewed this question
Top Washing Machines Experts
