Question about Presto Kitchen Appliances - Others
Presto Digital Deep Fryer 0546208: the unit will not turn on. No digital lights. There is a reset button we have pushed a couple times but didn't do any good
SOURCE: Rival Wing-It deep Fryer
NEED THE OWNERS MANUAL
Posted on Apr 13, 2008
IrishDruid
  • 2712 Answers
SOURCE: Deep fryer power cord
You can contact Rival HERE.
Mailing Address:
Rival
c/o JCS/THG, LLC
13120 Jurupa Avenue
Fontana, CA 92337
Telephone: 1-800-323-9519
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 17, 2008
SOURCE: cleaning deep fryer
You can not remove the reservoir because if you clean it out with a hot soapy spange or rag. turn the frier over and remove the plate you will see why the reservoir wont come out.
Posted on Aug 05, 2008
SOURCE: magnetic breakaway power cord for rival deep fryer
I have a Rival CF-250 cool touch deep fryer. Where do I get the magnetic breakaway power cord, filters, and filter cover.
Please let me know.
Thanks.
Ken Cooley
Posted on Oct 08, 2008
SOURCE: comercial deep fryer pilot light goes out
This problem could be caused by a few different things. You should check the condition of your pilot and the thermocouple, if the pilot is weak due to being dirty you will not generate the optimum Millivolts to run the fryer, you may need to dissassemble and clean the pilot. The thermocouple needs to be correctly placed in the pilot assembly, if it has dropped down to where it is not in the flame it will not work correctly. You may need a new thermopile as it may not be generating millivolts as needed. Gas pressure can cause this as well, if the pilot goes out then the main burners come on you should check the gas pressure. One more thing to check is the hi-limit thermostat, if this is cutting out early your pilot will go out. Imperial uses a self-resetting limit, after a few minutes your fryer will relight and work until if cuts out again. If your fryer pilot stay on with the thermostat off for long periods of time and does not go out immediately when the burners come on and the pilot is clean, you may need a hi limit. This is a lot of info, I hope it helps.
Posted on May 26, 2009
I turn on the power and before I can set the temperature I get a flashing "err" message and can't do anything.
You are not alone. We have the same problem. Unit worked fine for 2-3 years. We still have the manual. This is not a user error- we know how to use it. The sensor switch is fine- it would not power on without that working ok.
The red power light comes on, and when we turn it ON it says "200" for about 2-3 seconds... then "Err". Nothing is possible after that, the unit has to be powered off.
We can push Temp Mode and start setting the temp higher but after 2 seconds it just goes to Err. It does not matter what buttons you push- you don't have to push anything at all and it says "Err". Reset button does nothing- this is not a heat temp overload issue. This unit worked at Thanksgiving, and then not at Christmas! We tried powering it on 10-20 times... nothing. Then the next day as we were about to put the turkey in the oven I tried the fryer again... and presto it worked fine!!! Now today it does not work again. Tried it 10 times, no go. Unit was stored in pantry (in house) so it is not a cold/warmup issue. I think it is something messed up in the electronics- a weak solder joint, a bad chip, who knows. It's like the unit fails a "power on self test". Unfortunately, I do not have a solution yet. Don't want to buy another Masterbuilt for sure... only use this 1-2 times a year. Will share if I find anything.
Nov 26, 2010 | Masterbuilt 20010306 Deep Fryer
Find a manual for presto cool daddy deep fryer
You can download the manual for your 05442 CoolDaddy Fryer on the Presto website:
http://www.gopresto.com/products/manuals.php
Hope that helps!
Jun 15, 2010 | Presto 05442 CoolDaddy Deep Fryer
I have a tefal family pro fryer, when i switch it on the green light comes on instead of the red and it will not heat up. why?
Look for a reset button on the unit, Push it, you will hear a "click' then the unit will work. If not, there is an electrical problem, the element, or temp control is bad.
Apr 11, 2010 | Tefal FR4008002 Pro Fry Deep Fryer
Looking for owners manual for presto gran pappy fryer
Manuals can be downloaded on the Presto web site www.gopresto.com. Down load the model 05411, it is the same unit.
Apr 04, 2009 | Presto 05410 Granpappy Deep Fryer
Does not power up
Reset button on rear in a hole or the control unit has to be in the grooves on the rear of the fryer and pushed all the way down. there is a safety switch in the groove on the control unit.
Hope that works.
Apr 01, 2009 | Bravetti K4305H Deep Fryer
Light comes on but oil does not heat
check timer or power button,level oil.
Feb 05, 2009 | Presto 05442 CoolDaddy Deep Fryer
Lighting the fryer
If this is a milivolt unit, meaning no solid-state or computer/digital controlled. You would need to turn your gas valve to the pilot position, then press in and hold until you can light the pilot using a lighter (this may take several minutes, to bleed the air from gas supply) once there is a pilot flame present, you will need to hold the valve button in for about 45 seconds to heat the thermalpile. Once pilot is lit, thene turn to on position and proceeed to turning thermostate to set temp.
Scoota
Jan 25, 2009 | Pitco Frialator SG14 Deep Fryer
Deep fryer won't turn on
I had the same thing on a Presto deep fryer. I removed that back cover and traced the wires from the AC inlet. One lead goes to a switch that activates when you slide the heater into the case so the heating element will not turn on if it is not in the case. I removed the switch, pushed it in and out a few times, verified that it works with a multimeter, reassembled everything, and "presto", it works. Maybe I was lucky, but it worked for me.
Aug 21, 2008 | Kitchen Appliances - Others
Presto Digital ProFry Deep Fryer Reset Switch
Call customer service at 800-877-0441. Have the complete model and series number found on the back of the heating unit.
Jul 23, 2008 | Presto 05460 ProFry Deep Fryer
Please help
the the safety its pretty common on deep fryers with out that man i would be in trouble i leave mine on sometimes so its not a bad thing
Jul 08, 2008 | Wells LLF-14 Deep Fryer
Kitchen Appliances - Others Logo
91 people viewed this question
Top Presto Kitchen Appliances - Others Experts
Paul Bade
Jim Goldsmith
Jim Goldsmith
Are you a Presto Kitchen Appliances - Other Expert? Answer questions, earn points and help others
