Question about Dryers
How does the belt attach to the motor - Dryers
    Top Expert:
  • Dryers Master
  • 9,472 Answers
Here is a link to the diagrams for dryer belt routing. I did not see your model number posted but it should be listed.
Posted on Mar 20, 2011
Motor hot and smells
Step 1:
Please LUBE the deck belt+rollers bearing INMEDIATELY and proceed according see the video attached.God bless you
Step 2:
test the motor drive belt for loose
+ test the input voltage motor and see my personal TIPS for motor help.
Step 3:
test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram attached. use the VOltmeter.
Jan 03, 2013 | Keys Fitness Ht502 Treadmill Motor...
I'm trying to hook up the belt which came loose from the drum. While trying to loop it around the motor pulley, the motor pulley came free and I can feel a spring attached to the motor pulley and the...
the idler pulley keeps tension on the belt itself, and is a complete unit,, it slides into a grove,, and once the belt is correctly installed ,, thats what holds it in place, heres a good reply from another question that may help you with pictures
http://www.wikihow.com/Change-a-Clothes-Dryer-Belt
Aug 03, 2010 | Maytag PYE2300AY Electric Dryer
Blender attachment does not work
It could be the drive belts. There are three. One for the motor to the belt drive. one from belt drive to bowl mixer spindle. one from belt drive to mixer spindle. mine started to do the same thing. I ordered the belts from Bosch.
Jun 08, 2010 | Bosch 700 Watts MEK7000 Concept Series...
Replace the belt on a upright vac
There is a very small wheel attached to the motors drive. Belt goes around the motor drive wheel and then around the drive roller assembly
Feb 22, 2010 | Kenmore 34612 Bagged Upright Vacuum
Stopped spinning
There is a several list of things
start with power
is your dryer getting power to it
check and see if the belt is attached
make sure the motor spins
if belt is attached and motor is spinning check to see that the pulleys are not slipping and the belt is grabbing them.
Jul 07, 2009 | Whirlpool Dryers
I have a 10' Craftsman table saw model 315-218290. I ordered new belts I removed the motor how do you attach the belts, I tried to stretch it won't work
Jun 20, 2009 | Craftsman 10" Table Saw
MY VACUUM IS NOT PICKING UP
Hi This is quite complicated but I'll try and simplify this for you:
If this is a Panasonic upright then there are two drive belts as you know. Once you take off the sole plate (where the beater bar is) by undoing screws and the beater bar is looking at you, you would have to take off the smaller belt motor pulley first before putting on a new larger drive belt. If the smaller belt is still intact and you only need to replace the larger belt, you'll still have to take off both belts to put on the new drive belt.
Motor pulley belt has to be taken off first then the old drive belt, then grasp the beater and slide on new larger drive belt before having to attach the motor pulley belt and then the larger belt onto the motor pulley. Once all belts have been attached ensure that the beater bar is pushed in correctly before you screw the sole plate back on.
Apr 03, 2009 | Panasonic Vacuums
Tricity Bendix Condensor Dryer
the belt needs to go over motor rod first this means you have to take cover off then release the spring that attached to the motor so there is some play with the belt ,then pull the belt around the drum,quiet tight but you can do it,then pull the motor spring back into position to tigthten the belt put back together.... job done
Jan 19, 2009 | Tricity Bendix TM310W Electric Dryer
I have a kenmore 90 series dryer, the drum belt broke, bought a new one, but cant figure out how to get it on, too much slack in the belt, not sure where it goes on
REMEMBER BELT GOES AROUND IDLER PULLEY AND ATTACHES TO MOTOR SHAFT ,PULL BELT W/ HANDRUN BETWEEN ROLLER, AND PULL BACK AND ATTACH ON MOTOR PULLEY AND THAT ITS
Jan 02, 2009 | Kenmore 64952 Electric Dryer
Sears Kenmore Dryer. Model/stock no. 76691100 belt is broken, and a pulley attached to a spring steel L with a 90 deg bend is unattached from the machine. Joe
RE ATTACH IDLER PULLEY TO GROUNG ONLY 1 WAY TO FIT RUN BELT THROUGHT PULLEY IDLER AND BEND BACK TOWARDS MOTOR TILL IT ATTACHES TO MOTOR THAT ITS
Nov 29, 2008 | Kenmore Dryers
Dryers Logo
358 people viewed this question
Top Dryers Experts
