Question about E-Machines eMachines Desktop PC
The computor beeps 3 times when switched on. - E-Machines eMachines Desktop PC
    Sergeant:
    Champion:
  • 239 Answers
I assume from your message that the machine will not start. The beeps are POST codes and they will tell an engineer about the machine and it's fault.
There is some guidance here
http://www.pchell.com/hardware/beepcodes.shtml#phoenix
unless you know what you are doing I suggest you consult a computer engineer/specialist
Posted on Mar 20, 2011
    Master:
  • 325 Answers
The consistent length beeps usually refers to faulty memory, check that your ram is correctly seated.
  • 604 Answers
Turn it off (if on) unplug the comp from the power source. open the case, touch the case ( to discharge any voltage in your body). pull your memory chips out and put them back in, plug your comp back in and start it up. If you still get the "beeps" chances are you have a bad memory stick.
GA-H77M-D3H 6 beeps on POST and then restarts
Check timing between each beep---Make sure It's 6 Even beeps--Not 3+3--1+5--2+4 ect----Timing between beeps will tell you---let me know.
Mar 01, 2014 | Gigabyte GA-H77M-D3H Socket 1155/ Intel...
3 Beep Warning
Staying in the freeze cycle too long. Usually about an hour. Several things can cause this. Look for water running even if machine is off. Possible stuck float switch. And more.
Nov 08, 2013 | Hoshizaki KM-61BAH 49 Pound Self-Contained...
My compaq presario sr1000 computor won't stop beeping from the inside and it says no signal on the monitor
1 short beep and 1 long beep means its a memory problem.
Shut down your computer, then open your computer case and replace the memory module.If you have 2 or more modules ,try starting the pc with one.If it fails, try a different single module.
2 short beeps and 1 long beep repeating for 5 times means its a graphics card issue.
Shut down your computer, then open your computer case and unplug the graphics card, then plug it again.If this doesn't help, try with a different(confirmed working) graphics card.
Mar 13, 2011 | Computers & Internet
PS3 will not switch to HDMI cable. 1) Tried holding power button. Will not beep 3 times. Just shuts off. 2) Tried using both cables and changing display settings to hdmi.
try holding poew buton again let it beep 3 times
then hold it a second time and it would beep once solid beep and then listen for two short beeps then release the power button you will see a screen marked connect controller with usb and press ps button to continue you are now in service mode then just restore default settings and you should be up in hdmi
Jan 12, 2011 | Sony Playstation 3 (PS3) Console
When switch computor on it bleeps 3 times
possible causes:
memory module
graphics card
solution:
re-seat the mentioned parts.
Nov 27, 2008 | NEC Computers & Internet
Dell dimension 3100
remove RAM from the slot then put it again, then start and check
Nov 02, 2008 | Dell Dimension 3100 PC Desktop
My computor has blck out
no error code????or no beep sounds????how old youre pc?? check the prossecor....
Jun 19, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
106 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
