Question about Smeg STX2 Dishwashers
Keeps showing check water - Smeg STX2 Dishwashers
    Sergeant:
  • 194 Answers
As you know E9 is linked to the water inlet problem.
There are two scenarios here - 1) Are you using the Aqua-Stop safety system? If this is trigerring then it can shut the inlet water. The reason it can trigger is if the flood device located at the base of the dishwasher under the tub is seeing water. Now it is possible the 2 weeks wait for the technician caused the water to dry out and the dishwasher worked on his arrival. But the leak could have started again when it worked once again. So you could have a leaky hose or the door gasket.
2) going by the description of the error codes in this smeg document, I can foresee the error E9 is linked to the water level system which is not able to detect the level required for the dishwasher to start wash cycle. Possible cause is gunk around the sensor that detects the water level in the tub.
Refer a possible solution reported at this forum site.
What I am not clear is why is the dishwasher not doing anything now when you press the start button. Maybe try one thing at a time.
Please post a comment to confirm which way it progressed.
Posted on Mar 20, 2011
How bleed coolant line on a 2005 chevy avalanche
You need to start this when it's cool not hot take your radiator cap off start the engine start adding water into the radiator keep checking it with your finger and keep adding when the water turns warm to the touch keep adding water if it's taking it and squeeze your upper radiator hose continuously to burp out the air keep adding water try that and see how it works
Oct 03, 2017 | Chevrolet Avalanche Cars & Trucks
Ge electric water heater. 3 years old. keep tripping reset. both elements show 13 ohms, with no gronding out condition. help!
Have you replaced the thermostat they will short out and keep tripping to they go bad. Check the ends of the elements also for any bad places. Ran along this a few times and it ends up being a bad thermostat causing it to trip. You will reset it and it may last a day or more and keep resetting it and eventually it will short out or burnt out. So please check it out and this helps you.
Mar 13, 2011 | General Electric Water Heaters
I can not get water level to show nin the site glass. I keep adding water and nothing shows up in the site glass. It has no auto feed everything is manual,
are you sure your not waterlogged?if you keep adding water and its not showing that is the first thing i would wonder
Feb 05, 2011 | Heating & Cooling
The Samsung washer (Top Loading) WA80V3WE not switching on and water drains out continuously. The display shows time 22 and I ve selected quick wash mode and extra low water level. I ve checked the child...
if water just keeps draining check the drain hose,if it's down to far into the stand pipe the water will just keep siphoning out,if that's ok,when it starts let it run for the first two minutes and then it should reset and start,also try unplugging it for like 5 to 10 minutes and plug it back in,that will reboot the computer board.
Feb 09, 2018 | Washing Machines
Water keeps dripping in the tank, but the tank doe...
This description is a little vague, but I will do my best to help. The first question I would ask is. Is this water going down into the bowl? This can be checked by adding a couple drops of food coloring to the water in the tank and waiting a little while before looking for colored water in bowl. If there is colored water in bowl than the most common problem would be a faulty flapper or flush gasket. If no colored water shows up than the ballcock valve may need to be adjusted or replaced. I hope this helps.
May 20, 2010 | Home
Washer does not work!
NF = No Flow (water).
1.Is the water turned on? 2.Check inlet hose screens for restriction.
3.Check wire connections in harness leading from machine control board to pressure switch.
4.Check water valve.
5.Check inputs and outputs at machine control board.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
First my washer was showing a code E10 now it is showing an E70 Can you tell me how to fix this problem or what am i doing wrong
ok you have a water issue,,,check for kinked fill hose,,check and make sure you have enough water pressure,,,check and make sure your hoses are not reveresed..keep me posted..onthejob
Dec 28, 2008 | Frigidaire Affinity ATF7000E Front Load...
Water not draining from my bosch dishwasher
there will be something jamming up the drain pump empty the water out of the appliance if you study your operating instructions there will be an intsruction in it as to how to remove the drain pump cover and clear the impellor be carefull ill bet is a piece of glass
Dec 25, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Smeg STX2 Dishwashers Logo
298 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
