Question about Garden
Briggs & Stratton Quantum 120000 Lawn Mower; After sitting all winter with an empty fuel tank the mower after priming will start easy for 3 seconds and quit and repeating the process quits after 3 seconds.
  • 4,350 Answers
This sounds like restricted fuel flow. Items suspect are pick up screen (in the tank), filter, hoses, and the carb itself.
You have to open it up to find out where the issue is.
Posted on Mar 20, 2011
Need to know where the fuel filter is located
FAQ: Fuel Filter Replacement ' Briggs & Stratton Engines
www.briggsandstratton.com/us/.../fuel-filter-replaceme...
Briggs & StrattonWith this Briggs & Stratton FAQ, you'll learn how a fuel filter works in small engines ...properly strain the gas before it reaches the carburetor in your lawn mower, snow ...and uneven operation; Clean filters conserve the amount of gas you need ... The fuel filter will be located either inside the fuel tank or fitted into the fuel line ...
Servicing the fuel filter - Briggs & Stratton
www.briggsandstratton.com > www > Support > FAQs
Briggs & StrattonIf you still need help, you can submit your question by clicking the Ask a Question tab.... Some filters are located inside the tank, others are fitted into the fuel line between the tank ... The size of the holes in the filter will determine the largest particles that can get through the filter, and the number of ... Lawn Mower Engines ...
Lawn Mower Engine Fuel Filter Installation - Briggs ...
Jan 01, 2016 | Garden
Starving for fuel runs fine on starting fluid
Make sure gas tank and gas line isn't plugged. Also, make sure the gas itself is good, might have water in it.
Apr 25, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
Starts then stops
a plugged jet inside the carb
Aug 27, 2012 | Briggs & Stratton Briggs Stratton...
How do I fix my push mower with a Briggs & Stratton engine?
Its obviously a fuel starvation issue, so there is still some blockage in the carb, re move the carb and see if your frendly local dealer will clean it in there sonic cleaning tank, if not soak with carb cleaner and blow the jets through.
May 11, 2012 | Garden
Does the 650 series 190 cc lawn mower have a fule filter & carborator, because mower starts and quits in about 5 secounds, where are these parts located on the motor
The carburetor should be on the right side of the engine, opposite side as the exhaust. Do you have to prime this engine to start it? If so, it is running on the prime and therefore it is not getting fuel into the carburetor or picked up by the main jet. Either way, the carburetor has debris in it and needs to be cleaned out. If the carburetor sits on the fuel tank, change the diaphram while you have it apart.
I hope this helps get you going.
Aug 04, 2011 | Briggs & Stratton Lawn-Boy Insight Series...
Push mower starts, then dies, ad nauseum
Guessing you have a briggs and stratton motor with a tank mounted carb.Remove the tank and carb. from the mower and replace the rubber diaphram between the carb. and tank and clean it while its off
May 09, 2010 | Mtd 22" Yard Machine Push Mower
Mower wont start
About the only suspect is water in the fuel - even after you drained it. If your Masport has a 'Quantum' style engine with a float type carb, undo the bowl nut and allow the float chamber to drain. Odds on there's water in it. A single drop will block the jet. If it's a 'carb-on-the-tank' engine, chech for water droplets in the bottom of the tank. They wll be obvious if present.
Mar 11, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Poulan Pro lawnmower (Briggs and Stratton 128 cc engine) will start when primed but will not stay running. New Lawnmovewr, < 3 months since purchased at Walmart
IF IT IS A BRIGG & STRATTON ENGINE YOU CAN GO ONLINE TO BRIGGS & STRATTON.COM AND ASK THEIR TECH SECTION ABOUT THE PROBLEM. FOR 3 MONTHS OLD SOUNDS LIKE DIRT OR WATER MAY HAVE GOTTEN INTO THE TANK. WHEN YOU PRIME THE MOWER YOU ARE FORCING GAS INTO THE CARB AND ENGINE AFTER THAT THE ENGINE SHOULD PULL THE GAS IN THE ENGINE, I WOULD SAY THE CARB MITE NEED REBUILDING BUT NOT AT 3 MONTHS
Sep 17, 2009 | Poulan Garden
Garden Logo
552 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
