Question about HP Computers & Internet
When i touch a key wrong characters appear, and runaway
    Genius:
  • 1,542 Answers
Hi
do you by any chance have the nulock key locked
its worth trying to press the FN+F11 key
good luck
hope this sorts it for you
Posted on Mar 20, 2011
I need an 8 character referral key. You may find that referral key on a white sticker on the outside of your product packaging. This key is optional. If you have it pls provide it to me. I have downloaded...
The key should have been supplied when payment was made . they should email the key to you. the key is different for every download . You will have to get in touch with them and ask for a key.
Mar 13, 2015 | The Computers & Internet
Letter characters won't change
You need to re-calibrate the touch screen. It is in the settings menu to reset touch screen. Done.
Cheers,
Embroidery Services
San Diego, CA
Sep 24, 2014 | Baby Lock Esante
Brother p-touch model 1880 label maker- how do you change the font size
To change the font size, do the following:
1. Press the "Function" key
2. Press the "Left Arrow" or the "Right Arrow" key until the display shows "SIZE".
3. Press the "Function" or the "Return" key. The current selected size setting is displayed and a triangle indicator pointing a sample of the character size above the display.
4. Press the "Left Arrow" or the "Right Arrow" key until the desired Size is displayed.
* SIZE1 equals Standard Size.
* SIZE2 equals Double Width.
* SIZE3 equals Double Height.
* SIZE4 equals Double Width & Double Height.
* SIZE5 equals 4 x Width & Double Height.
* AUTO, the machine will automatically adjust the characters to the largest possible size according to the width of the tape installed in the machine.
Press the "Function" key or the "Return" key to select the characters size.
I hope this helps.
Aug 09, 2010 | Brother P-Touch 1180 Label Printer
My touch screen does not operate properly. When I attempt to press/touch a character another character appears. Example when touching 1, 4 apperars on the screen. How can I correct or reset the touch...
The touchscreen portion of your display is severely out of alignment. Try finding the utility(use hardware keys) to align the display (under settings). Try to align it. If it is too far out of range, it will kick out your "presses". If this happens, you *might* be able to try a reset, but it likely will not work. Otherwise, your only recourse will be replacement or repair.
Jun 23, 2010 | Samsung Behold Cell Phone
My toshiba laptop is typing wrong characters but my wireless tevion keyboard is o k. Is there a solution to this ?
Sounds like the laptop keyboard went bad and thats why its typing wrong characters. Best way to verify this is to use a USB keyboard on the laptop, if the USB keyboard is typing the correct keys then you know the laptop keyboard is bad. If the USB keyboard is typing the wrong keys as well then you know its a setting in windows that is causing the keys to type wrong characters.
Apr 28, 2010 | Toshiba Satellite P105-S9312 Notebook
How do i make a character that looks like a 7 but vertical portion is straight
The answer is ALT + 191
To obtain an ALT Character:
  1. Make certain that the Num Lock key has been pressed to activate the numeric key section of the keyboard.
  2. Depress the Alt key.
  3. While the Alt key is depressed, type the proper sequence of numbers (on the numeric keypad) of the ALT code from the table above.
  4. Release the Alt key, and the character will appear
Found here... http://www.tedmontgomery.com/tutorial/altchrc.html
You will find all the special characters there.
Thanks,
John C.
Sep 17, 2009 | HP Pavilion dv9000z Notebook
The keyboard characters does not correspond to what appears on sc
Does it type " by any chance when you press the @ key? if so this is usually because keyboard input is set to the wrong language in the regional & language settings are wrong in the control panel. try pressing the left alt key & shift at same time first this is a quick key to change between input languages.
Feb 27, 2009 | Dell Inspiron 500m Notebook
How to delete
For Editing Data: Retrieve the file to edited; touch [Shift], then either [< delete] or [> insert] to move the blinking cursor to the character or number to be edited.  Touch [Shift] [< delete] for deleting or [Shift]  [> insert] for inserting a character, digit, or symbol.
For Deleting Data: 1) Find the Data to be deleted. 2) Touch [Shift][CE/C] ([CE/C] only depending on model) key. *DELETE?* is displayed. 3) Touch [Go]. *DELETE!* is displayed for 3 seconds then the data is deleted.
Note: If [CE/C] has been touched in error, simply touch any other key except the [GO] key to avoid deletion.
Mar 01, 2008 | Royal DM3070
CHR SIZE AUTO?
Press the Return button and the machine will automatically print the size the tape will allow! :) Title:
What does the error message "CHR SIZE AUTO?" mean? Description:This message appears when the selected character size is too large for the width of the tape cassette installed.
You have the following options:
  • Press the "Print" or "Return" key to allow the P-touch machine to automatically select the maximum character size that fits the tape width.
  • Press the "BS" key to clear the message, and then install a wider tape cassette.
  • Press the "BS" key to clear the message, and then select a smaller character size by following these steps:
    1. While holding the "Code" key, press the "Size" key. The display will show the current character size.
    2. Keep the "Code" key held, and press the "Size" key until the desired size is displayed.
      If you select "AUTO", the P-touch machine will automatically adjust the character size to the largest possible size.
    3. Release the "Code" to apply the setting.
If you have the correct size tape installed and still get the error message, please try removing the cassette from the machine and reinstalling it. Also, check that the tape cassette is seated firmly in the compartment.
Note
    The following table shows the maximum character size that can be used with each tape width.
    Tape Width Maximum Character Size 1/4" (6 mm) 12 points 3/8" (9 mm) 18 points 1/2" (12 mm) 24 points 3/4" (18 mm) 42 points
Related Models PT-1900
Feb 17, 2008 | Brother P-Touch 1900 Label Printer
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
