Question about Samsung PN50A550 50 in. Plasma TV
We have a samsung television that is few years old. All of a sudden we had thick green and purple vertical stripes over the picture and sound was fine. However, playing the xbox or watching a dvd, it looks perfect. I found that when we unplugged the power cord, it would be fine for a while. But now that isn't even helping. Today it seems that the sound went as well! Time for a new one-or simple fix?
  • 718 Answers
SOURCE: sound yes, but no picture on tv
If you have sound on the stations this is a problem in the display. Take bright flashlight and hold it against the screen. Look for an image around the edge of the flashlight. If you see an image then it's one of three problems;
1) The inverter board is bad.
2) The CCFT (cold cathode fluoresent light) are bad.
3) The power supply to the inverter board is bad.
Someone knowledgeable in electronics can replace the bad part(s).
Posted on Mar 10, 2009
SOURCE: Pink picture with no green
take the color to b/w and retune
Posted on Apr 23, 2009
  • 99 Answers
SOURCE: tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
Posted on May 22, 2010
  • 11361 Answers
SOURCE: when i turned the tv
Youy may have bad T-CON, Power supply, LCD panel.
Learn about T-CON/LCD panel failure mode:
PDF download:
Inside the TV:
Try this when the screen goes black:
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors pictures:
Learn about bad caps:
Capacitors kit: he can make you a set of caps.
Or, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Jun 10, 2011
  • 5568 Answers
SOURCE: My LG 37LH30-UA has a vertical black stripe aboue 4-5'' thick that goes away after a few minutes. I took off the back but don't see any obvious damage.
You can still use the freeze spray Donald mentioned to cause the fault to come back once it is gone.Using this stuff carefully and allowing each component to 'soak' for 20-30 seconds before hitting another should allow you to narrow it down.
If it is in fact one of the board-edge parts of the display (which it could well be), the whole display may be the only 'part' LG will replace and you will shudder when learning the cost of it.
If you do find the right part or area and it is the display, you might try the site below to save some bucks; this company buys overruns and parts out units:
Shop Jimmy
Posted on Nov 16, 2011
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from
Samsung LCD Loud Noise and Green Vertical lines at Start up ... > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Green and purple horizontal lines
You will most likely need what is called a scan converter/scaler. It will convert your source signal to the desired signal for you. You can find these online.
Nov 21, 2012 | Mitsubishi Televison & Video
Tv is about 4 years old. Suddenly developed two
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
Green vertical stripes over marginal picture
sounds like screnn is faulty, hair line crack will do this - if still on warranty send it back-or some hse.insur. will cover the cost of a new t.v. to the same value.
Aug 07, 2009 | Samsung DLP HL-P5663W 56" TV
Half screen showing
keep tv off.
it will only get wors
if sumon dosent work on it soon
the problem you are having in the vertical section of the tv
hav a repairman resolider all conection on the vertical IC and check the serounding componets for falts.
regards daniel.
PS the repair takes me about 15 min.
Jan 13, 2009 | Samsung TXG2746 27" TV
Samsung HLR5067 flashing green
Thank you!!!! Our power was off due to new transformers being installed in the area and we had no clue how to fix this. I called around and no one seemed to know the answer (not even Samsung, who only wanted to tell me my TWO year old tv was out of warranty),so I tried this and it worked perfectly!!! You saved me a bundle! Thanks!
Jun 13, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Green and purple vertical stripes on our TV screen
The cause is one or more shorted transistors either on CRT board or on main or both. The colors are red,blue and green, you have a transistor for each and a bias trans. check each there are 6 in all.
Sep 14, 2007 | Televison & Video
Samsung TXN3275HF 32" tv - purple picture
Chuck the TV - probably It depends on the repair facilities available where you live. In big urban areas the cost of staffing a repair shop is such it can cost nearly as much per hour just to look at an item is it does to buy the next one-plus you get all the latest features.
May 21, 2007 | Samsung TXN3275HF 32" TV
Thick multicoloured stripes accross the screen
Some condesator gone bad.. remote control IR eye needs 5V voltage but now it's not there so i think you need to replace bad condesator.
May 30, 2007 | ViewSonic N3000W 30 in. HD-Ready LCD...
Samsung PN50A550 50 in. Plasma TV Logo
44 people viewed this question
Jerry Greenberg
Jerry Greenberg
