HOW TO USE SPEAKER-S AS A MICROPHONE FOR SKYPE
  • 902 Answers
Only work with headphones. put them into the mic jack. ONE of the headphones is now a mic. let me know if that helps
Posted on Mar 20, 2011
When using my Skype to Skype, Why do I get Feedback ie. Echo ?
Hi Steven
Feedback is caused by the Microphone being too close to the Output speaker.
Feeding Back.... output to input.
Cover the microphone to see if it stops.
Echo may be something else...
Sep 13, 2015 | Computers & Internet
Cant enale microphone for skype
Check the settings on the skype for the microphone or speakers because most happens if your plug headset the default settings was the system microphone and speaker. So you have to manually configure then test your microphone and speaker also. Have a nice day
Jul 09, 2014 | eMachines E-Machine E525-2632 2.2GHz 2Gb...
How to turn speaker on acer d257
Make sure you have installed the Acer's audio driver for your model laptop. Test the audio by playing a music CD.
SKYPE MICROPHONE PROBLEM
If the person cannot hear you then, either your microphone driver not installed or not working OR the microphone is not configured in Skype.
To test your microphone then click on Start - All Programs - Accessories - Entertainment - Sound recorder. Then record your voice and then play it back. If this is OK then the microphone need to be configured in Skype.
To configure the microphone - Open Skype - Tools - Options - Audio Settings for the Microphone THEN click on Save.Also while you are in the Audio Settings select the your Audio card in Speakers.
Nov 10, 2012 | Acer Computers & Internet
The person I am speaking with does not hear me. The microphone function does not appear to be working. I have adjusted the volume and that's not the problem. I have plugged both jacks (microphone and...
The person I am speaking with does not hear me (He is deaf).
The microphone function does not appear to be working. I have adjusted the volume and that's not the problem (You must speak as well).
I have plugged both jacks (microphone and speaker) into my PC hard drive and am using my PC to talk on Skype (You cant plug even a single jack in the hard drive).
Problem solved!
Apr 14, 2010 | Logitech (980361-0403) Headphones
My computer says the microphone is working but skype says no
how about the speakers working? if working your speaker it means the microphone has problem, ( hardware problem,, did you try to change the setting on the property?
Sep 06, 2009 | Toshiba Satellite P105-S6104 Notebook
My internel microphone doesn't work with Skype -
You need to check the Microphone setting in Skype.
Open Skype, Click on Tools - Audio Settings, then in Microphone settings click the down arrow and select the built-in microphone then save the settings.
If the microphone you selected doesn't work then select a different one.
Jul 04, 2009 | ASUS W5Ae PC Notebook
Microphone not working
Hello.
1. Audio settings all versions
Skype:
Skype-->Main window…..>Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
You can also tick the ring pc speaker check box as this is a good backup to alert you even
if the main speakers are off or turned down.
Windows:
Start-->Control panel-->Sound and Audio devices
On the audio tab set the default playback device to your main soundcard (AC97/Audio-chip/add-on-adapter), etc.
Your installed audio device must be present there.
If not, reinstall audio device
2)Check if your micro (pink) and speaker (lime) jacks are really correct and fully inserted!
They sometimes stuck.
For test only you can use earphone instead of microphone for Line In.
Standard micro in Line In will NOT work.
Go to:
Start
Programs
Accessories
Entertainment or go to
Volume Control; right click on loudspeaker icon in Task Tray
Options
Microphone
Scroll down
Check "Microphone"
If the bar "Microphone" is available, the microphone is detected by Windows now go on
(If not, Windows has a problem with your microphone)
Just to check if your microphone is broken or bad, you can use your headphones instead. They really work!
Which one L or R is microphone now, I think it's L
Check "Advanced properties"
Check Micro "Advanced"
Open
Check "20db boost" or "1.MIC boost" depending on language version
Volume level can be left in any position.
Mute microphone!!!
3. Check audio now on windows base.
Start
Programs
Accessories
Entertainment
Soundrecorder
4. Once done, test with Skype Test Call echo123.
Good Luck
Please Vote.
Jun 17, 2009 | Dell Dimension 3100 PC Desktop
Camera works but skype tells me the microphone is muted.
Go to Tools | Options | Audio Settings which is how the audio and microphone settings are adjusted in Skype.
Your microphone might be muted in the Windows multimedia sound control panel - if you double-click on the speaker in the Windows taskbar you will get the mixer control panel - select Recording devices if the Microphone is not shown, make sure the MUTE checkbox is clear.
Dec 26, 2008 | Logitech Quickcam Chat Webcam
Skype
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
Oct 19, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
