My machine is showing some problem n its showing locked sign in display ow to solve that
  • 3 Answers
Th
e washing machi
ne door is closed
but wont let you program any thing in
Posted on Mar 20, 2011
TK1300 SHOWING E19 AND I DONE THE FFFFF AND WHEN 19 COMES UP AND STARTS BEEPING.
Sounds like an initialization error
You can perform a Flag Clear to clear errors but it must be done exactly as below
If the sequence is not followed exactly - you could erase your program
This as a Non Destructive Reset for Most programmable Casio Tills - Please Check your manual first
Flag Clear:Please do this at your own risk
Turn the mode key to OFF position - Put the OW Key in the mode lock
Press and hold the RECEIPT FEED key down ( top left corner of keyboard )
Turn the key to PGM position while the RECEIPT FEED key is held for 5 seconds -
Release the key -
FFFFFFFFFF will appear on the display -
( If this does not happen then turn the power off for 2 seconds and ON again while holding down the RECEIPT FEED key for 5 seconds and then release the key )
While FFFFFFFFFF is on the display -Press the Subtotal key once - A Receipt docket will print with the MAC Code
Return key to REG and sign Clerk on as normal
If MAC Code Prints out as 000000 or you get another error code on the display - Call your Dealer
Source - http://www.gettech.co.nz/casioer.html
Feb 23, 2017 | The Computers & Internet
My machine shows a key ow i cant wash my cloths how to un lock this
If you mean error OE, it means you have debris that is plugging the pump, the tub to pump hose or the drain hose. Please check those and remove it. If not, please for my clothing trapped between the tub and th spin basket.
Oct 25, 2015 | Washing Machines
Washing machine SF-110LJ sign Fd on display
My washing machine Model SF-110LJ does not working and show Fd on
display. Please assist.
Nov 30, 2012 | LG Hitachi Washing Machine Lint Filter...
Flash FDL code
Fdl error code means a "door lock error code".
This error shows up because the door cannot be locked. The door will try to lock six times before displaying the error code. In order to solve it, your door lock switch needs to be replaced.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day
Dec 19, 2011 | Washing Machines
'Ld" sign is showing in
Hello.
What this code means indicate that the door of your washer is not well close .
L= LOCK
D=DOOR
So what you need to do to solve the problem is to open the door of the washer then close it properly.
Good luck.
Thanks for using fixya
Sep 06, 2011 | Washing Machines
F16 showing on display
F16 measn a problem with your door lock.
The machine senses the door is open and will stop. The door lock isn't that expensive and should solve your problem. If that doesn't solve it then you may have a faulty control board.
Try the first choice. Good luck.
Aug 24, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Washer no working - KEY SIGN SHOWS ON DISPLAY
child lock is activated check handbook for info on disarming usually have too hold a button for 4 secs or more different on different models so cant be more specific hope this helps
Aug 05, 2009 | Bosch Classixx WFL 2066 Front Load Washer
An error signal "DL" - door lock signal keeps coming on
Check for loose wires from the door lock to the control board.If no loose wires,
Replace the door lock switch.
May 23, 2009 | LG WM2277H Front Load Washer
Won't start, key symbol in display panel
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently. Means the machine is locked, for children. I think if you do it again it locks.
Pl rate me 'very helpful' for the free help, thanks
May 16, 2009 | Audiovox Bosch 718 World Cellular Phone
CASH REGISTER CASIO CE 3115 DISPLAY E 03 AND ALARM
This ino might help: Cleaning ERRORS: ______________________________
1.- Turn the Mode lock to OFF
2.- Press down the RECEIPT FEED button
3.- Turn the key to PROGRAM
4.- Lift up RECEIPT FEED button (FFFFFFFFFF)
appears on the display panel
5.- Press SUBTOTAL (wait for receipt to issue)
6.- Turn Mode Switch back to REG and use as Normal.
Also another bit goes like this:
RESET: _______________________________________
1.- Insert the OW key and turn to OFF
2.- Hold down the JOURNAL FEED button and turn the key to PROGRAM mode
3.- Release the JOURNAL FEED button. The display should shows "00000000".
4.- Turn the key to OFF
5.- Turn to REG1. The display shows "INIT" and "0.00"
6.- Press the number 10801 and then press SUBTOTAL. Initialisation is completed when the printer stops operation. The display shows: "_ 0.00"
Hope this helps in restting to factory settings................................sodeep
May 12, 2009 | Casio Parts Cash Register PC Desktop
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
