Question about Kenmore Dryers
Kenmore DWSR-ele-2406028 CV54 Model 110.62802101 Dryer won't work at all. History: Dryer works fine. Moved Dryer from one house to the other, switched from 3-wire to 4-wire plug. 220V Electric. No problems. A few weeks later "Dryer not working at all". I show up and fiddle with the timer and it starts working. When Moving I cleaned lint out of exhaust and under (and got $20 in coins). Although the unit was working I wanted to find the Cause. The 4" dryer vent went strait up in the wall into attic. I disassembled the vent (3") and found the flap on roof vent seriously clogged with lint. I cleaned out as much as possible and left it. Today I get a call that it has stopped working again. My theory is that the restricted pipe diameter and blocked exhaust flap caused poor air circulation. The element kept overheating and turning the heat off/on which caused increased drying time. So to solve the problem, replace the Vent pipe with 4", but why is it not coming on? Door switch seems like a coincidence. Would the timer have suffered from overheat? Would the Overheat switch cause the timer not to function?
  • 5 more comments
  • John Guilfoyle Mar 20, 2011
    No, I am getting ready to go back to the house. I don't know if there will be a diagram in the unit. Thermal Fuse should be @ heating element. Is it a resettable fuse or a traditional (needs to be replaced) fuse? Also, would this fuse cause the timer and motor to stop working or just the heat?
    the fuse is the part with two blue wires . it measures three tenths ohms in one direction and three ohms in the other. on the two hundred ohm scale.
    it started heating and runnin once. whilei blue wires were hooked to fuse. how do i test push to start switch
    I am at my wit's end. The Fuse looks good. (blue wires) The other unit in your picture is the thermal cutoff. There is power going through the Red/Red-White wires. There is continuity throught the Violet wires. I have checked the Push-to-Start button and it is getting continuity through it when I press. Any other ideas. It has started once today. But I don't know why. What other items could cause it to NOT run at all?
    The Door switch looks like it's shot. The Black Plastic tip is broken off. I have looked it up online.
    How do I bypass it for tonight/testing? White/Orange/Blue wires on Plug in.
    Done. I was over-thinking the problem looking for a Cause and effect explanation. It Was the Door Switch. plain and simple. If the Light had been working inside, I might have noticed it sooner, but the bulb was blown. Thank you for your assistance.
    Very helpful, Very patient.
  • Kenmore Master
  • 2,605 Answers
Welcome to FixYa.
First and most importantly, have you checked the thermal fuse ?
Let me know and we can go from there.
Regards,
Macmarkus :)
Posted on Mar 20, 2011
  • 3 more comments
  • Mark MacDonald
    Mark MacDonald Mar 20, 2011
    Hi John,
    No on that particular design of dryer the fuse is a non-reset type unfortunately and it is located on the blower housing at the back.
    i.e.
    When it trips/opens it will terminate power to all the functions/devices and will need to be replaced.
    If you're experienced you can simply use a jumper wire or join them together to confirm or dismiss ...asisde from ohming it out of course.
    Let me know how you make out and I'll try to help in whatever manner I can. Good luck.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    That shouldn't matter, all that is important is continuity usually checked on X1 setting. If you feel comfortable join the wires (blue, yes) and see if it starts. I'll also take a look to insure the belt isn't broke or off thereby activating the "kill switch".
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Hello again John.
    If you look at the switch you should see a small illustration on the side showing which contacts should be closed (unless you have a wiring diagram, I do not) when the button is pushed "in".
    i.e.
    With your ohm meter you should be able to determine if the contacts are indeed closing when you depress the switch.
    I'll watch for your reply if that doesn't do it. You haven't mentioned whether you ruled out the belt switch, door switch, etc. What about the timer itself ? You mentioned that seemed to be a culprit previously...that kinda raises a flag.
    Let me know, good luck.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    John,
    I know diagnosing something like this can be tedious, (especially trying to follow suggestions from afar) but what about the door switch ?
    You also said the unit did start at one point. it sounds like a contact closing sometimes but not closing at other times...including now.
    Based on this I'd certainly think it was a contact in a switch like the door or in the timer, but there is also a chance of a wire broke inside the insulation...it's just a matter of tracking it down. Do you have a diagram ?
    The door switch can certainly trick people into thinking it's OK, because it serves as a safety, but also a light switch so when you open the door the light comes on and it won't allow the dryer to start if the contacts inside the switch don't close...even if the door is closed.
    Let me know if this is something you can confidently rule out.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    John,
    Looks like we where posting at the same time.
    If you jump white to blue or white to orange should do it. Anything but orange to blue.
    White is neutral, the blue either goes to the light or start. The orange same goes. One is for light, the other for start.
    I don't have a diagram, but it's just a matter of jumping either of the color to white.
    Macmarkus :)
  • 212 Answers
SOURCE: kenmore dryer model:11060832990
sounds like start switch on motor bad.
Posted on Jun 24, 2009
jan mczeal
  • 632 Answers
SOURCE: dryer will not start...checked belt and is
If the lid switch is defective, the washer will not function or work at all. It is located inside the washer main housing near the door frame. When you close the door, the switch is activated by an actuator. You have to raise or open the top or front panel of the machine to reach the switch. Replace if found defective.
Posted on Sep 26, 2009
heatman101
  • 43501 Answers
SOURCE: our kenmore dryer 600 series,model
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Posted on Jan 18, 2011
markfreedman
  • 312 Answers
SOURCE: My Whirpool dryer Mod. LEN
The Hum most commonly means that the drum belt on your dryer is probably broken
There is a simple way to test for this.
1 remove the clothes from the dryer.
2 put your hand inside the drum and turn it. If it is easy to turn, the belt is broken. If it is difficult to turn, the belt is good. You may be looking at motor problems.
Almost all of the time, it is a broken belt.
The link below has the full procedure for changing the belt.
Hope this helps,
Best Regards,
Mark
http://www.fixya.com/support/t6322596-get
Posted on Jan 19, 2011
heatman101
  • 43501 Answers
SOURCE: DRYER WILL NOT START. WHIRLPOOL MODEL WED5821SWO
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Apr 23, 2011
Dryer stopped working
Look for an issue with the door switch. It could have even become unplugged, but these are generally good captive connectors.
Feb 27, 2018 | Dryers
Have a Kenmore Elite Dryer that won't start. Mod 110.65962401 Ser MS0303258 Type DDOT-ELE-2406028-CV54
heatman101
Aug 22, 2011 | Kenmore Elite HE4 Electric Dryer
My Whirpool dryer Mod. LEN 2000LWG, type DWSR-ELE-2406028-CV54, Imperial Series, was working fine, but after the second medium sized load it stopped drying the clothes. I finally noticed that the inside...
Hope this helps,
Best Regards,
Mark
Jan 19, 2011 | Whirlpool Dryers
Our kenmore dryer 600 series,model #110-67622600; ser #MUO91116; type: DWSR-ELE 2406028-CV54 less than 3 yrs old, lite comes when door opens, otherwise no action at all. drum turns manually, no clogs,...
Dryer Repair - The
Dryer Repair - The
heatman101
Jan 18, 2011 | Dryers
I have a Kenmore Series 70 Dryer. It starts but runs constanly never shutting off and not getting hot. Model number 110.62702181 Serial number MM0609310 Type DWSR-ELE-2406028- FM54
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 13, 2010 | Dryers
Dryer will not start...checked belt and is good...dryer does have power source but no other visible problems seen...mod#: LEQ8000JQ2...ser#: MM3713012...type: DWSR-ELE-2406028-CV54....Thanks
Sep 26, 2009 | Whirlpool Dryers
Dryer wont start just clicks.
could be start switch bad,main fuse bad,door switch bad,or a weak motor,you need to call an honest appliance repair shop(not sears$$$$$$$$$) I DON'T WANT YOU TO HURT YOURSELF,THE DRYER IS HIGH VOLTAGE(220)MIKE
Sep 13, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
1,880 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
