Question about ASUS RTG32 Router
Where do u connect phone cable from router to? my pc does not have a phone cable outlet
    Sergeant:
  • 194 Answers
RS232 PIN WILL BE IN THE LEFT CORNER
Posted on Mar 20, 2011
Internet connectivity problems HP pavilion a6230n desktop pc
1.Unplug all phone, fax and satellite TV cables from the wall phone jacks.
2.Plug the double DSL filter into the wall phone jack where the 2701HG-B will be located.
3.Plug the phone wire (for phone, fax, etc.) into the jack on the filter labeled "Phone."
4.Plug the gray phone cable into the other jack on the filter labeled "DSL."
5.Add the single DSL filters on all remaining phone jacks in the same manner, plugging the device phone cables into the filter. The single filters only have one jack.
Ethernet Connection
6.Plug the power adapter into the power port on the back of the 2710HG-B router and then plug the other end into a power outlet. This will cause the power light on the front of the router to turn green.
7.Plug the free end of the gray phone cable into the port on the back of the router labeled "Phone Line."
8.Plug one end of the yellow Ethernet cable into one of the four ports on the back of the router labeled "Ethernet."
9.Plug the other end of the Ethernet cable into your computer's Ethernet port. The Ethernet light on the router should now be green.
Wireless Connection
10.Plug the power adapter into the back of the 2701HG-B and the wall power outlet.
11.Plug the gray phone cable into the jack on the back of the router labeled "Phone Line."
12.Open the Network and Sharing Center on your computer by right-clicking the Internet connection icon in your taskbar.
13.Click "Set up a new connection or network" and follow the instructions provided by the wizard to set up the wireless connection on your computer.
14.Enter the SSID and WEP key when prompted. The SSID is "2WIRE" followed by the last three digits of the router's serial number, which is located on the bottom side of your 2701HG-B router. You will also be prompted to enter a WEP encryption key, also found on the bottom side of the router. The WEP key is the 10 digit number that appears in brackets under the first bar code.
Sep 12, 2012 | HP PAVILION A6230N DESKTOP PC
Http://192.168.0.1/
286520a4-ee13-4d09-80b0-c6808ea917d3_15.pngA modem and router properly plugged in
  1. Plug the modem into an electrical outlet.
  2. Plug one end of a phone cord or cable into the modem, and plug the other end into the wall jack. (DSL users: Do not use a DSL filter on the phone line.)
  3. Plug one end of an Ethernet cable into the modem, and plug the other end into the wide area network (WAN) port on the router.
  4. Plug the router into an electrical outlet.
  5. Plug one end of an Ethernet cable into the local area network (LAN) port on the router, and plug the other end into the networking port on the computer that you want to connect to the Internet. (If you are connecting wirelessly, skip this step.)
  6. Start (or restart) the computer.
  7. Open the Connect to the Internet wizard by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_47.png, clicking Control Panel, clicking Network and Internet, clicking Network and Sharing Center, clicking Set up a connection or network, and then clicking Connect to the Internet.
READ http://www.fixya.com/support/r7900574-general_router_setup
Nov 26, 2011 | Computers & Internet
Wht should i do to conenct to internet
1. Uninstall or disable all Internet-sharing applications, proxy software and security software such as anti-virus programs or firewalls. Although every program is different, if you choose to uninstall one, you can typically do so by clicking "Start," "Control Panel" and "Add/Remove Software" and then selecting the software you wish to remove. Because Homeportal 1000 comes with its own versions of these programs, this step is essential to avoid conflicts.
2. Connect Homeportal's AC power adapter to the back of your router, and then plug it into a power outlet. The green power light should come on.
3. Connect the router to your
computer. If you're using Ethernet, connect the Ethernet cable to both the router and the Ethernet jack on the back of your computer. If you plan to use USB, follow the same procedure using the USB cable and ports, instead. For a wireless connection, ensure that your wireless card is correctly installed on your PC.
4. Connect the phone cable to the back of your router and then plug it into a phone jack. This will allow the Homeportal 1000 to receive DSL signals from the phone company.
5. Place the Homeportal 1000 installation CD into your CD drive and follow the on-screen instructions to install the necessary software and until finish installation.
We are now ready to browse a website.
Dec 22, 2010 | 2wire HomePortal 1000 Router
How do i connect a netgear wireless router to comcast modem
Unplug your Comcast modem from your electrical outlet. Connect the Ethernet cord from the back of your Comcast modem into the Ethernet port labeled "Internet" on your new router. Connect an available Ethernet port from the back of the new router to the Ethernet port on the back of your computer.
Plug your cable modem into an electrical outlet. Plug your new router in an electrical outlet.
Reboot your computer. Click on "Start," then "Control panel." Click "Network and sharing." Select "Set up a new home network."
Click on the option for a router or cable modem when prompted by Windows to select your hardware. Your computer will attempt to access your new router. When the brand name for your router is listed, double-click it so your computer can configure itself to the new router.
Create a new name for your home network and create a unique password to prevent unauthorized users on your network. Your computer may reset your Comcast modem and router so your new changes can take effect.
Nov 04, 2010 | Computers & Internet
Can't get router to connect to Dell Dimension 2400 desktop
Try turning OFF DHCP from services. This may fix your problem. Look for "DHCP Client", double click on it (or right click and choose properties), STOP the service, then set it's startup type to 'manual'. That'll kill it. See DHCP is what "Gives out/assigns addresses" and on the ONLY PC, it is the First one... 192.168.0.1... Both PC's will be assigning themselves as that, and that will cause a conflict. As the Router now does the DHCP work. Of course ensure you DO have DHCP set on router.
Feb 12, 2010 | Dell Dimension 2400 PC Desktop
I only have one PC in my house and it's not in the same room where the cable outlet is located. Right now I have a very long coax cable running from my cable modem to the cable outlet in the other room. Is...
Purchase either a USB stick that adds wireless capability to your laptop/desktop, or purchase a PCI wireless adapter-card for your desktop, and install it.
Then, you can move the cable-modem much closer to the cable-outlet, and then connect the cable-modem to a newly-purchased wireless-router ($20 to $70) to receive/transmit over your in-home wireless network.
Jan 24, 2010 | Gateway GT5654 Desktop PC
I need help connecting a westell 7500 router/modem,i want to get a notebook on line. i didnt receive any intsructions.i need help connecting the westell 7500 to my pc and notebook thanking you.
Westell makes a line of broadband home networking products that enable residential customers and users in small businesses to access and share broadband services. These inexpensive DSL router/modems offer multi-users Internet LAN access for home or business applications. The Westell router/modems allow you to have the benefits of the "always on" high-speed broadband Internet connection without losing the ability to receive voice calls over the same phone line.
  1. Step 1 288254_thumb.jpg Connect one end of the Ethernet cable to the computer's Ethernet port. Connect the other end to the Ethernet port on the back of the Westell router.
  2. Step 2 Connect the barrel end of the router's power cord to the connector labeled "12 v" on the back of the router. Plug the other end of the power cord into a wall outlet.
  3. Step 3 Connect one end of the DSL phone cable to the DSL line jack on the back of the router. Connect the other end to the wall jack.
  4. Step 4 Wait for the Ready and the Link LEDs to glow steady green. The router is now ready to use.
Nov 15, 2009 | Westell Wirespeed VersaLink...
When the cordless phone is in use the internet on the laptop cuts out can anyone help
Assuming you have DSL - Verify that you have a DSL filter in the phone line that leads to the base unit of the cordless phone.
Assuming your laptop connection is wireless - See if there is a frequency conflict with your wireless internet and the cordless phone.
If neither of these suggestions help, please reply with specific details regarding your internet connection (Cable/DSL) and the connection of the laptop
Dec 01, 2008 | Lands Phones
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
Belkin N1 Router connection drops when phone rings
You may have a phone line connected from the modem to a wall outlet. Count the number of cables coming out of your modem - you should have only three: the power cable (connects to the wall), Cat 5 (also connects to the wall), and ethernet (running from the modem to the router).
Nov 09, 2007 | Belkin (F5D8231-4) Wireless Router...
ASUS RTG32 Router Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
