Question about Sony KV-27V55 27" TV
My Sony KV-27V55 27" TV has not picture
When I turn on my Sony KV-27V55 27" TV has not picture appear but it sounds.
what is the problem and what can I do.
Thank you.
Jhony R.G.
    Sergeant:
    Champion:
  • 346 Answers
Does the screen light
Posted on May 24, 2010
    Champion:
  • 317 Answers
Look for vertical hold.
Posted on Aug 03, 2008
Sony kv 27s22 sound works but no picture
Hi Solaiman,
Loose connection on circuit board.
specially neck board.
regards,
nuwan
Oct 02, 2012 | Sony KV-27S22 27" TV
Sony FD Trinitron WEGA KV-32HS420 32" TV.....Turns
Sounds like a diode may have burnt up or if your really lucky it might just be the fuse.!!! You might want to get a secound opinion .But if you know what to look for , which is any component on the motherboard that appears as if had caught fire sader it out amd replace with exact same component which can be ubtained at radio shack.GOOD LUCK TOO YOU!!!!!!!!!
Dec 23, 2010 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony KV-32S42 (See Description)
It may be a fruitless effort. The main reason this occurs is that the Picture Tube is drawing too much current and the AKB circuit will not let the video circuit diplay the picture. Outside
of replacing the Picture Tube there is no fix.
You can varify this by turning the screen control up. This is usaully located on the HV transformer and is marked. the other location it may be is on the CRT board. It also would be clearly marked. If you adjust this slightly and the picture appears, the Picture Tube is the problem. I'm betting 100% it's the Tube.
Hope this helps,
Skyassoc
Jun 16, 2009 | Sony KV-32S42 32" TV
Sony KV-35S42 35" TV
Check first for bad solder on the vertical IC, Im not sure for your set as I do not have the service manual, but it may be location IC301. If after resoldering it does not fix it you may have to replace it and you should replace the electrolytic capacitors in the vertical section. Hope this helps. Don
Jul 31, 2007 | Sony KV-35S42 35" TV
Setup codes for a sony kv-20fs12
i have sony kv 14 gmr1mk r2ks always shorted and the other 1 appear like a lightning in midle of screen.. kv 21gmr1mk when adjust the brigth and contras it shut down the picture and blinking..can u help me how to troubleshoot this problem? what remedy you sudgest..thank you...
May 03, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony KV-27V55 no picture sound ok
I have a KV-27V55 and when I turn the TV on the picture and sound is good for about 30 minutes and then the picture goes off, but the sound is still on. It will come back on after a while.  What do I do?
Hog_mama
Jan 14, 2007 | Sony KV-27V55 27" TV
Sony kv-32s26 32 inch tv
video card went out in the tv. You are saying you need a schematic. Be real careful getting into tvs. They have very large capacitating capacitators in them that can electrocute you. You need to take it to a repair specialist and have them run a check on it. Sounds like the video card to me though.
Sep 18, 2006 | Sony KV-32S26 32" TV
Picture takes hours to appear
Spounds like the b+ feed filter capacitor off the flyback that supplys voltage to the three drive transistors on the crt board is bad.
Apr 16, 2006 | Sony KV-32V16 TV
Televison & Video Logo
241 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
