Question about Dryers
When I run the dryer, there is a very high pitched, loud squealing noise. I have the back cover off and can't figure out where it's coming from.
  • Dryers Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Mar 20, 2011
High pitch grinding noise coming from motor when starting idling or driving
Seven ways to pinpoint that high-pitched, whining noise
www.losaltosonline.com/special-sections2/sections/on-the-road/45742-
Oct 2, 2013 - I recently had new fan belts installed after hearing a high-pitched, ... Do you hear the noise when the engine is running and the vehicle ... Just replaced water pump (and timing belt) yesterday and squeal ... When driving it make a noise but change out and caught speed the noise is coming from driver side.Missing: 1999 ‎plymouth ‎breeze
What is causing that irritating noise? ' DSMtuners
Troubleshooting Strange Sounds Coming from Your ...
www.dummies.com/.../troubleshooting-strange-sounds-coming-from-yo...
You hear a high-pitched squeal that stops when you shut off your engine: Readjust or replace the belt. These belts should have about half an inch of play and ...Missing: 1999 ‎plymouth ‎breeze
Nov 25, 2015 | 1999 Plymouth Breeze
STOP HIGH PITCHED NOISE IN LG DRYER
This could be a bearing failing. these can make squealing noises, but may continue for years.
Feb 14, 2015 | LG Dryers
Dryer was making high pitched squealing noise and now won't run
Please supply the model number so we can help further.
May 20, 2012 | Hotpoint Dryers
Dryer makes squealing noise when running. What's wrong?
the idler or tensioner wheel that your belt rides on has a bearing in the center of it. This bearing is going out causing the high pitched squeal your hearing
Jan 23, 2011 | Fisher and Paykel DGGX2 Dryer
The dryer is squeaking/squealing during operation. It is a high-pitched noise that is rather loud. It is also getting very hot. We vacuumed the lint bucket area behind the cover, which fixed the...
I am having a similar issue. I had a tech out to look at it and he recommended replacing the drum bearing and idler jockey pulley. ($419.95) Ouch. I am going to do this on my own. I ordered the part from paykelfisherparts.net. Part # 479332 Drum Bearing Kit $79.91.
Check here for more info. This was exactly what I found on my machine (DGGX1) http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/731-fisher-paykel-dggx1-top-load-dryer.html
I did not totally trust the repair dude. He was wierd and not very thorough. I can tell the bearing is bad, if there are still noises I will order up the jockey pully thing and see if I can figure that out.
Here is a link to the service manual. (https://docs.google.com/fileview?id=0B5If-wTgYWH5OGNkY2RmZDEtMWU4OS00MjgwLTg3OWEtMmRlZjY0N2I5MzYy&hl=en)
Good luck
Jan 17, 2011 | Fisher and Paykel DGGX1 Electric Dryer
Maytag electric dryer is making a high pitched noise
The squealing noise is from the belt tensioner. Replace the pulley only on the tensioner along with a new belt. The bearing in the pulley is causing the squeal. Sears will sell this in a kit. The top and the front panel of the dryer will have to be removed to replace these parts
Jul 16, 2010 | Maytag Dryers
High pitched squeal when running. Capacity Plus Gas Dryer ten years old.
tumble dryer / twin tub is making a loud rumbling noise when running, unplug it, take the rear cover off and remove the drive belt. Then turn the inner drum by hand. If there is a grating noise, the bearings will almost certainly need replacing
Mar 09, 2010 | Dryers
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
1998 GS 400 - Loud high pitch noise on the inside cabin
never had that problem with my GS400 but on my 95 maxima, i used to have that same high pitch squealing noise... i used some belt dressing that i got from R & S Strauss for a few dollars and sprayed it on my belts and pulleys that ran around the alternator, compressor, etc. and never heard the noise again. hope your problem is as simple and cheap to fix as mine was
Jan 19, 2009 | 1998 Lexus Gs 400
Squeeky noise
I own a Frigidaire Heavy Duty Dryer The Model # is FDE436RES1. It is 10 years old. When running the dryer it makes a very loud squealing noise although the heat and the dryer still work. Is this a belt or roller problem or does it sound like something else. It is very high pitched and can be heard throughout the entire home. I do not know much about dryer troubleshooting so your help would be greatly appreciated. Thank You.
Oct 17, 2007 | Frigidaire GLER642A Electric Dryer
Dryers Logo
96 people viewed this question
Top Dryers Experts
