Question about SanDisk Sansa Clip MP3 Player
My sansa wont turn back on and it says my fat is coruppted what do i do?
    Scholar:
  • 57 Answers
Try right-clicking the sansa drive under My Computer when it's plugged into your computer.
Select Properties.
Click Tools
Under Error Checking- click check now.
Select automatically fix file system errors and select Scan for bad sectors
Click start
Please leave feedback for this answer, thanks.
Posted on Mar 20, 2011
How to fix a sandisk fat is corrupted please recover fat
You could try the following:
Start with the Clip turned OFF. Slide the power switch down to the HOLD position. Press and HOLD the center button depressed until it is recognized by the PC- give it a few seconds.
The Clip's display will state "connected" with the device now in MSC mode.
You can now repair the File Allocation Table (FAT) using Windows' chkdsk utility.
Open My Computer and find the Clip a listed under "devices with removable storage" as a flash drive. Let's say it displays as E: SANSA CLIP for example. Our assigned drive letter is E:
From the Run box under Start, enter cmd and press Enter. You will get a DOS window.
Enter chkdsk E: /f and press Enter. The /f toggle tells the utility to fix the errors.
After clicking on the Safely Remove icon in the taskbar, or right clicking on the Clip and selecting Eject, unplug the Clip.
Try powering it up again, and see if all is well.
I found this at: http://forums.sandisk.com/t5/Sansa-Clip-Sansa-Clip/FAT-is-corrupted-On-Clip-4G/td-p/250798
Dec 31, 2014 | SanDisk Sansa Clip MP3 Player
How do I recovery my mp3 data it says load main image failed switch to recovery mode and wont go to recovery mode? What can I do
Ok use getdata back for Fat file system or get data back for ntfs
If you need help let me know
Regards
uttam109@hotmail.com
Jan 02, 2010 | SanDisk Sansa e260 MP3 Player
I have a sansa fuze 8 gigs, FAT is corrupted, can it be fixed?
Hi, dont worry your player is probably fine, you just need to refomatt it. Checked out the sanza forum and they were pretty helpful
This guide should be useful
http://forums.sandisk.com/sansa/board/message?board.id=sansafuse&thread.id=11867
Jul 20, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa fuze FAT error
Plug your Fuze into your computer. Open "My Computer," right click your Fuze and click "Format," a window will pop up with settings on how you want to format it, make sure it's set to FAT, then click "Format."
May 09, 2009 | SanDisk Sansa Fuze MP3 Player
I'm trying to down load some songs,but it doesn't let me it reads FAT is corrupted. please help me.
Go here >
http://www.sansa.com/support
click on your player's picture.
There are help items there.
May 06, 2009 | Audio Players & Recorders
I turn on my sansa mp3 n it says fat is corrupted please connect device to pc and recover fat what do i do
You might need to change the file format or if you have Rhapsody, you need to renew the files.
Apr 04, 2009 | SanDisk Sansa Fuze MP3 Player
My sansa fuze is not working
Hi and welcome to FixYa,
Appreciate the direct "Ask Me;.
Offhand, the message indicates that the Sansa is requesting that the internal storage be reformatted using the PC. This would require that the Fuze be connected to the PC through USB. Thereafter, the computer would recognize it as an external storage device. Steps required to format:
  • connect Sansa Fuse to USB of PC;
  • double click on "My Computer";
  • it would show probable as an "E";
  • right click on the "E" and click on "Format...";
  • a new window will pop up;
  • under the "File system" pls select FAT or FAT 32;
  • verify that "Quick Format" is un-checked;
  • click on Start button.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 21, 2008 | SanDisk Sansa Fuze MP3 Player
Sansa stuck on finalizing update
Remove the battery for at least 3 minutes and then put it back in.. be sure it''s fresh and fully charged
2. VERY IMPORTANT...Turn the "Hold button" ON.. (slide it to the right)
3. Now, plug it into the computer, it would be better if you used a USB 2 port that is located on the back of the computer (it''s on the motherboard)
4. Go to "MY Computer" and see if it shows up as a "Removable disk"
5. If it''s there, then reformat it to ...FAT32...not FAT.if you need help with reformatting let me know.
EDIT* When I called Sandisk on 1-3-07, the tech I spoke with instructed me to reformat to FAT32. Now (2-14-07) I get this from them..."(select "FAT" if the capacity of your Sansa is less than 2GB. For larger players, select "FAT32"). I found I lost a few megs when I formated to FAT32 on my m240, but didn't notice any other difference.
6 Unplug it and let it finalize. Give it lots of time.
7. Return the "Hold button" to off.
I hope that help
Please rate accordingly
Thank you
Computerrep
Nov 17, 2008 | SanDisk Sansa m240 MP3 Player
Wont let me transfer osngs
2 possibilities. Most likey you need to upgrade the firmware for your device so that it is compatible with WMP. Go to the sandisk website. find product support and download the latest fimware. install it on your player. then try using wmp again. if that doesn't work you may need to reformat the device. open your 'my computer folder' with the device connected. right click on the device icon. click format. set to FAT format if allowed. click quick format. unplug device and then power it back on. it should reboot itself.
Jul 30, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
60 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
