Question about Acer Aspire One PC Notebook
My battery will not charge unless it is plug into the outlet. what it the problem?
  • renowiccan
    renowiccan Mar 20, 2011
    Need more details as to what battery you are trying to charge.
  • 902 Answers
That is the only way for the battery to charge.
Posted on Mar 20, 2011
How do we charge this chair?
off board chargers plug into the front of the joystick. after 10-12 hrs the chair should be charged, Unless the batteries are bad, or the charger is bad. Plug into joystick before power cord into wall outlet. also charge every night!
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Mar 15, 2016 | Health & Beauty
My Everstart Maxx Jump Starter 500 amp will not charge and it beeps every 5 seconds unless I pull out the fuse? What is the problem?
I don't think they read the problem right. His charger will not hold a charge, not the car. I'm having the same problem. My charge will not charge when I plug it up to a outlet.
Dec 02, 2012 | Cars & Trucks
Charging does not charge
If your Notebook computer battery is not charging, try the following:
  • Reset your computer's power manager. For information on how to do this with your specific model, search Apple Support.
    • Make sure your AC adapter is properly inserted into your laptop.
    • Connect your computer to its AC adapter, shut it down, and then let it charge overnight. If it does not charge, it's likely you have a hardware fault in your computer, battery, or adapter, and you should have it repaired.
    • Test your AC outlet. See if your battery will charge if you plug it into a different outlet, or see if another electrical device will work in your original outlet.
    • Test your AC adapter. Try connecting a different AC adapter to your computer and see if it recharges.
    • If it's removable, test your battery. Try using a different battery with your computer and see if it will recharge.
    • In some of the early PowerBooks, the battery will not charge unless the computer is turned on. If you have an old PowerBook and your battery isn't charging while it's turned off, power it on, put it to sleep, and then see if it recharges.
    If you go through all of these steps and your battery still won't charge, or you can't narrow down the source of the problem, you will probably need to have your computer repaired. However, it may be worth your time to consult Apple Support first. It contains entries on problems with specific computer models and versions of the operating system, including battery recharge issues.
Aug 10, 2010 | Apple MacBook Air Mac Notebook
My charger is not getting a ground connection when i plug in to charge
If the outlet is properly grounded and connected and the battery charger is properly connected I would look at the Power Supply being bad unless you've had damage to the plug.
May 11, 2010 | Gateway 6510GZ Notebook
Laptop will not turn on unless it is plugged in but the battery is charged
I suspect your battery is bad. Test the battery, try another, or test your's on another notebook. Batteries Plus, or some other outlet can perhaps help you.
Nov 20, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
The battery will not charge unless the computer is off. it runs on the battery even if its plugged in why? if i unplug the the adapter then plug it in it charges for a few seconds and then stops and then...
1. First remove the Battery, clean the Battery contacts with the pencil eraser and insert the Battery in the Computer.
2. Connect the AC Adapter (Battery charger) securely to the Computer and the Power outlet.
3. If the issue persists, try connecting the AC Adapter to different Power outlet.
4. Make sure that both the connecting points (DC IN port on the Computer and the Power outlet plug) are securely connected and not loose.
5. If the issue persists, try with different AC Adapter.
Good Luck!!!!!!!!!!!!!
Nov 18, 2009 | HP Pavilion zd8000 Notebook
Battery????
that would be the battery. Unless prongs are not getting good contact in outlet.
Aug 27, 2009 | Acer TravelMate 6410 Notebook
My Magellan Roadmate 1412 does not seem to charge. I cannot use the device unless it is plugged into a wall outlet or car charger. Does this model not have a battery? Please help. Thanks!
does it appear to be charging when its plugged in....go to the system folder then the power option..the power bar should be moving left to right...if its all green and its not scrolling left to rigth , its receiving power but not charging. possibly because the charge port is damaged or the battery is either shot or disconnected.
Jun 24, 2009 | Magellan RoadMate 1412 Car GPS Receiver
Camcorder problem
you need a new battery
Nov 06, 2007 | JVC COMPACT VHS-C CAMCORDER
Acer Aspire One  PC Notebook Logo
16 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
