Question about Bosch DHL755BUC Kitchen Hood
Hi, I am installing a DHI645KAU I think it is. It is an under the cupboard slide our 60cm range anyway. It is going into a new kitchen. The electrician said I had to cut the lead off and run a line back to the meter box. In the past I have simply plugged it into the power point in the cupboard. I suspect he is qouting the commercial code of Western Australia. This is a domestic situalion. Should I ignore him?
    Champion:
  • 235 Answers
A domestic rangehood simply gets its supply from a power point in the cupboard above. A commercial rangehood would be on a designated circuit. The same wiring code covers Australia and NZ. Ignore him.
Posted on Mar 21, 2011
When in self clean mode latch will not lock latch has been replaced what do you think is causing this
If you replaced the entire lock assembly and it still does not work, the control board was originally at fault.
I assume there is no latching action when you call for self clean?
Double check you installation before you go buy a new control board.
Also check wire harness connection from new latch assembly to oven control board.
Oct 23, 2013 | Electrolux 30" Self-Cleaning Slide-In...
My range will not go all the back and it is not hiting anything
It is difficult to give an exact solution to this situation, but things you could at, could be;
Depending on the floor surface, the sliding of the range back and forth may have creased the covering and it has formed a crease and one of the feet/s (sic) it preventing it from sliding.
There may be no feet as such and the "buttons" underneath have worn a hole in the surface, preventing the sliding motion of the range.
If the range is in between cupboards, maybe the range is trapped/stuck by friction on the sides.
These are some ideas as you have clearly mentioned that it is not from hitting anything.
Do not force it, there has to be a reason it is not moving and be careful of gas/electric connections when moving appliances.
Best of luck.
Feb 27, 2010 | Electrolux EW30GS65GS 30" Slide-in Gas...
Heating element in my electric Jenn-air oven
This is one of the most simple repairs you can make on your range. And it's so affordable that you shouldn't think about replacing it!!
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
with your complete model number and we provide part removal/installation instructions for you when you purchase your parts through us.
We want to get you cooking again soon, so call us asap.
We look forward to working with you! Thanks, Ella
Jan 07, 2010 | Jenn-Air SVE47100 Slide-In Electric...
I want to remove a faulty westinghouse range hood to replace it. Its mounted between two cupboards. I've removed the filters and looked inside. I can't find the mounting screws. Pls provide procedure....
Some are mounted from the cabinet interior, check that as you will have to open the portion of the cupboard containing the vent tube or chimney to remove the old and reattach the new one. Some Westinghouse were slide in and had a side locking bolt running into adjacent cabinets
Nov 22, 2009 | Kitchen Ranges
Help.
Unplug the range.
Remove the oven racks.
Remove 2 screws holding the element to the back wall.
Slide the element towards you carefully. Remove the wires and install them on the new element.
Reattach the element to the back wall.
Mar 06, 2009 | GE Spectra JBP78 Electric Kitchen Range
Re Smeg 60cm electric oven model SA370 EB/1. I need new door glass and rubber seal for glass door.
I have one for sale I am jus putting it up on ebay buy it and replace yours.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=110291356746
Jun 23, 2008 | Smeg Kitchen Ranges
RELAY BOARD JENNAIR RANGE 1200/693
yes check your warrenty i think that bd is under a five year warrenty so the installer if he is an authourized service tech for jen air or whirlpool should not have charged you for the part and any new part you bought should have came with a full year warrenty call cust relations not cust service at whirlpool as they are not the same branch
Mar 28, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Broan allure fan and light
Check that you have not accidentaly switched the wall socket off in the cupboard above the rangehood. The slide switch could also be faulty.
Oct 30, 2007 | Broan-NuTone Allure® I WS136BC Kitchen...
Bosch DHL755BUC Kitchen Hood Logo
288 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Jim Thurston
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
