Question about Kodak Carousel 4400 Slide Projector
Focusing into slide transfer box
I am trying to transfer my slides. The projector doesn't focus closer than 2 feet and that makes the image too large for the transfer screen and the picture spill out over the edges. Any fix for this?
    President:
  • Kodak Master
  • 412 Answers
Yes, use a shorter projection lens. You didn't say what focal length your projection lens is, but Kodak and many of their OEM vendors made very short focal length lenses.
Posted on Jan 08, 2011
How do I open up a Rank Aldis 2000 Slide Projector to replace a bulb and free a jammed slide?
1. Prepare to turn projector upside down.
2. Unscrew & remove focusing lens.
3. Turn projector upside down & look from the base face of the projector towards the lens aperture - for a slot just under the lid lip. There is a black tab which can be slid with a screwdriver away from the slide path.
4. There's a similar slot at the back under the lid lip and the end of the row of vent holes.
5. After sliding these, the lid is loose - so while holding the lid in place, turn the projector back over onto its feet.
6. The lid now simply lifts off - first at the slides side, hinging away and then off.
Aug 27, 2016 | Office Equipment & Supplies
How do i turn off auto focus?
To strictly turn off the auto-focus, you have 2 options:
1. Some generations of 5600's have an Autofocus On/Off Switch. If so equipped, move the switch to "Off".
2. Remove the bottom cover. Locate the auto-focus motor and clip on of the wires that power the motor.
If repair is what you want to do, the problem becomes more complex and expensive! You will have to contact: www.micro-tools.com
You can order the 2 special tools, instructions and any other parts you need from them. When Kodak stopped supporting the slide projector business, micro tools bought out the remaining repair parts.
Feb 24, 2015 | Kodak Carousel 5600 Slide Projector
Why does autofocus keeps moving in and out on some slides
The autofocus system isn't really "autofocus". It is a measuring system - you manually focus the first slide, which sets the distance from the front of the slide in the gate to the back of the projection lens. By the focus motor moving the projection lens, subsequent slides will maintain that same distance. Continuous focus adjustment suggests that:
1> The curvature of the slide is changing because of the varying heat absorption rate of the transparency.
2> The autofocus system is out of calibration.
3> The autofocus system has a bind (it is being restricted from free operation).
About the only thing a user can do is to make sure ALL slides are oriented the same way in the tray. Beyond that, you will need a service manual and 2 or 3 specialized tools. Parts and tools can be purchased from: www.micro-tools.com
Good Luck !! jim
Jun 24, 2014 | Kodak Carousel 5600 Slide Projector
Kodak carousel 760h projector
The auto-focus system in Kodak slide projectors is really an auto-measurement system: One set manually, the system is supposed to maintain that distance on all subsequent slides. Correct orientation of the slides is that they are all placed in the slide tray in the SAME direction (the matte side of the transparency facing toward the screen). The measurement is from the FRONT of the slide transparency to the BACK of the projection lens. REPAIR calibration of the system requires 2 special tools: a RANGE SLIDE and a TARGET SLIDE. These tool slides and the calibration procedure SHOULD be available from: www.micro-tools.com They purchased all remaining repair parts from Kodak when Kodak stopped supporting slide projectors. Good Luck !! Jim
Apr 30, 2014 | Office Equipment & Supplies
Can't get slide projector to focus with lens in projector
Check the lenses inside the lens tube and see if they are loose or out of place
Feb 05, 2014 | Kodak 4200 Slide Projector
Kodak 5200 focus slide not working
The auto-focus system requires adjustment / set-up with special tools if the auto-focus no longer functions correctly. Before ordering the tools from: www.micro-tools.com
check a couple of things:
1. Is the "Auto-Focus on-off Switch" in the "ON" position?
2. Put a slide that is as dark as possible in the slide gate. Power on, lamp on. Look down into the gate, on the front side of the slide. You should see a "S"-shaped light near the center of the slide.
If you have validated both of the conditions above, then I would contact my friends at micro-tools for the special tools. They should be able to provide you with adjustment instructions.
Good Luck !! Jim
Oct 18, 2013 | Kodak ATS Ektagraphic Slide Projector
Neither of the "trademarks" you mention were used by Kodak, so the lens must be a non-Kodak lens. First of all, remove the lens and look along its side - it should have a rectangular "rack" (dimensions of the "rack" are roughly 1/2 inch by 3 1/4 inches) with gear teeth that will connect with the corresponding gear (inside the projector) on the focus knob shaft. If the lens does not have this "rack", then you should try to find a lens that does. (One source for lenses is www.VineValleyImaging.com). Verify that the lens is on the focus knob shaft and does not appear to be damaged. If the gear on the focus shaft is damaged (or slipping) you will need to contact a Authorized Repair Dealer to see if parts are still available for your specific model. Let me know if you need anything else! Good Luck !! Jim
Oct 25, 2011 | Kodak Carousel 4600 Slide Projector
I have a braun Novamat 515 AF-m slide monitor. when the first slide is shonw you have to manually focus. Thereafter the auy=to focus takes over for remaining slides. problem the auto focus does now not...
Apparently you are not using glass slide mounts and your slide is popping in and out of focus. If you feel that it is working abnormally you can send it to service. In the USA Braun service is: HP Marketing Corp. PO Box 715 16 Chapin Rd. Unit 908 Pine Brook, NJ 07058 800-735-4373
Sep 07, 2011 | Office Equipment & Supplies
The auto focus won't focus on images from far away, 2 feet. It only focuses at 2-3 inches
Most CMOS web-cams have a focusing ring round the lens which rotates to give you basic adjustment - after that the auto-focus should sharpen up the image
Feb 10, 2011 | Avermedia AVerVision CP155 Portable...
Kodak Carousel 4400 Slide Projector Logo
126 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
