Question about Woods InWall 7 Day Digital Programmable Timer (59018)
Just installed the programmable timer and had programmed the clock and on off times. Then realized that it was set for AM instead of PM. Hit reset and now can't set the clock or program. Just blinks 12:00 AM Monday.
I test timers.
Some arrive defective, and some go bad quickly.
Industry standard is 1 year limited warranty.
All these timers have reset button that should restore functionality.
You posted under Woods digital programmable.
Open link to download on-line manual and read ez wiring steps.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
This timer is reset by pushing reset button, without pushing any other button.
Some timers require on-off button to be pushed while pushing reset button.
I suggest turning off power to timer and see if that 'resets' timer.
Otherwise open link below and run through troubleshoot checklist, and also double check wiring.
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
If timer will not function correctly, then exchange for new timer.
Resourceful do-it-yourselfer can buy similar timer at Home Depot located near light fixtures and doorbells.
GE15086 -or- GE15071 with daylight savings time.
Advantage is ez exchange if problem occurs, and you give yourself extended warranty.
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 20, 2011
Why is my IIIWoods 50013 outdoor 24 hour timer switching to OFF regardless of setting? How do I fix it?
First start with the reset button, clears out all past commands.
First the clock has to be set to the proper day and time, It might be in the 24 system versus AM and PM you can find this out by stepping through all the hours when the time comes on. To set clock press Set and see what is flashing, if it is the day, scroll to the right day and hit set, now time should flash scroll to right hour, press set, right minutes, press set, right seconds, press set; Now the clock should be set.
Next you do the programs you want again go through same process, hit program 1 should flash press set, now the days should flash, scroll through till you have the right combo of days, one day, all days of week, Sat, Sun, then last the whole week will flash, if that is the one you want then press set, now press set and the times should flash for hour.
pick the time you want to come on, hit set for hour, minute, second, then hit set again now hit the program button again and it should say off, go through the same steps and set hour, minute second then hit set for last time. In a few minutes it should change to reading the time on the screen. Then you have to wait and see if it works. To do a mini version, see if it will work get a lamp plug in set all the above but use a very short on off time like 4 or 5 mins, then you will know if it is going to work right. then set for the correct time. good luck hope it helps. If it all messes up just hit reset and start all over, REMEMBER it can't so anything until the time of day is set right that's the starting point.
Dec 04, 2016 | Hardware & Accessories
Find manual for woods 59028 programmable timer switch
1) Set current time:
Press reset button to clear all programs , display should flash 12:00 AM Monday
Press and hold CLOCK button.
Press Hour, minute and day buttons until current hour minute and day display.
Release Clock button.
Next step is to program the timer
Example shows how to turn on at 5PM each day and turn off at 11 PM each day.
2) Programming review: Each program requires ON time to be set, and then OFF time to be set For example you set Program1 ON 5:00PM for ALL days. And then you set Program1 OFF 11PM for ALL days. Minimum on-off set time is 1 minute.
3) Programming steps: Press PROG button until Timer 1 ON appears on display Use Hour button to set 5 PM Use MIN button to set :00 Default selects ALL days (If you want other days, press DAY button until display shows correct block of days) Press PROG button again to save Program1 ON 4) Now for Program1 OFF 5) To set Program1 Off Press PROG button until Timer 1 OFF shows in display. Use Hour button to set 11 PM Use MIN button to set :00 Default selects ALL days (If you want other days, press DAY button until display shows correct block of days) Press PROG button again to save Program1 OFF 6) Program 1ON and Program1 OFF have been set ... so press the CLOCK button to return to current time. If you want to set another program, press PROG button until Timer 2 ON displays 7) After setting programs, press Clock button so current time shows. 8) The manual shows one more thing ... if you program the timer during the hours 5-11pm, and the timer should be ON during those hours, you have to 'tell' the timer to turn ON by pressing the manual override ... after that the timer will operate normally.
Nov 21, 2011 | Woods 59028 Programmable Timer Switch...
I DON'T KNOW HOW TO PROGRAM THE TIMER I'VE LOST THE MANUAL. I NEED TO SET IT MON- SUN FROM 7PM TO 12PM IT SHOWS: 1 ON THIS IS WHERE I HIT HOUR & PUT 7:00PM THEN I HIT PROGRAM IT SAYS 1 OFF I HIT...
You posted under Intermatic HB88RC timer
If you have different timer, add a comment
HB88RC timer manual:
http://waterheatertimer.org/pdf/hb88rc.pdf
Here's HB88RC programming from the top:
Remove batrery from back of timer to reset timer and clear everything.
Re-install AA battery in timer so display will show, and you can program
Set clock:
Hold down clock button.
Press day button until current day displays.
Press Hour button until current hour displays.
Press min button until current minute shows.
Release clock button
Program timer:
Press PROG button until 1 ON displays
This is Event1 ON
Press Day button until selected day or days displays for event1 ON
If you want all week long, then press day button until all days show: MO TU WE TH FR SA SU
Press Hour button until 7pm shows >> this is event1 ON
Press Min button until :00 displays for event1 ON
Press PROG button until 1 OFF displays
This is Event1 ON
Press Day button until selected day or days displays for event1 OFF
Match days with ON time: so press day button until all days show: MO TU WE TH FR SA SU
Press Hour button until 12pm displays >> this is event1 OFF
Press Min button until :00 displays for event1 OFF
When programming is finished, press clock button to display current time
When programming is finished, press MODE button to select MODE > you want AUTO for timer programs to operate
Press MODE button once and this is manual override, and lights come on.
Press MODE button again and RDM displays, this is for random timer operation
Press MODE button 3rd time, and timer is set to AUTO
After setting MODE to auto, press clock button to display current time.
Plug timer into receptacle.
Plug lights into timer.
Add a comment any time.
A lot of folks have written in about this timer going bad and they have been unable to program the timer. Of course most timers work perfectly fine.
Dec 18, 2010 | Intermatic HB88RC - 7-Day Programmable...
How to set the Nordik TM-065? It was bought for
The Nordik TM-065 timer looks similar to Woods/Noma N1506
http://www.advancedtimer.com/TM-065.html
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1506
Plug timer into outdoor receptacle.
Press Time button until correct time displays.
Dot on display is for pm hours
Nordik appears to be on the 24 hour clock instead of am-pm
Set operation of timer by pressing Mode button.
P flashes for program mode.
Press time button until starting time displays.
Press Mode again and E flashes.
Press time button until finish time displays
Press Mode button to exit programming.
Dec 17, 2010 | Woods Outdoor Lighting Timer
How do I program Woods digital timer 59203?
Link shows all Woods timers and manuals
If instructions below do not match your timer, look through timers on Woods page to identify, and then add a comment.
Manual for 59203
http://waterheatertimer.org/pdf/Woods-59203.pdf
Instructions below are for Woods 59203 & GE 59203 plug-in programmable timer with 2-prong polarized outlet:
Plug timer in until battery is charged.
If display will not show, then timer battery needs to be recharged, or timer may be busted, or electric circuit is tripped off, or electric circuit heeds to be tested with circuit analyzer.
Set current time:
Press HOUR and MINUTE to set correct time with am and pm.
Press Day button to set current day.
Release clock button.
Program timer:
Press PROGRAM button until "1 ON" displays. This is program1 ON.
Press MINUTE and HOUR buttons to set ON time for program1
Press DAY button to choose day or group of days for program1 ON
Press PROGRAM button until "1 OFF" displays. This is program1 OFF
Press MINUTE and HOUR buttons to set OFF time for program1
Press DAY button to choose day or group of days for program1 OFF
Press PROGRAM button until "2 ON" displays. This is program2 ON.
Repeat steps above to set ON and OFF time for 5 programs.
When programming is completed, press CLOCK button to exit programming.
Press ON/AUTO/OFF button until Auto displays.
Make sure lamp is turned on.
Make sure bulb is good.
Dec 11, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
Set timer for the 7-day outdoor timer i.e. 5:00 pm on and 9:00 p.m. off Also set the clock ~ should it be left 'on' for the timer to work? Have lost the manual our programmer
Outdoor timers
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers.aspx
HB88RC timer
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers/hb88rc.aspx
HB88RC Manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb88rc%20-%20english.ashx
Timer takes AA battery installed from back
Instructions say: Set timer to AUTO using MODE button. This will let programs run.
To override current program, press MODE once for ON-or-OFF override.
Press MODE again to enter RDM or random mode. RDM shows on display.
Press MODE third time for AUTO. Usually, AUTO will show on display.
Dec 05, 2010 | Intermatic HB88RC - 7-Day Programmable...
I have a HB88RC Intermatic 7 day / 7 event timer. I have followed the "easy set instructions" I have program 1 set to turn on X-mas lights at 4:30 PM and go off at 11:30 PM. For all seven...
Just program it as noted previously and put the timer in Auto. Set the clock to 1 min BEFORE your earliest timer program is set to come on. When the clock hits the correct time, it will turn on. Then set the clock to the correct time and you're golden.
Dec 03, 2010 | Intermatic HB88RC - 7-Day Programmable...
I have a IIIWoods timer #59203WV and have trouble programming it to turn on and off exterior lights. Thanks for your response.
Manual:
59203 plug-in timer: your outdoor lights have to plug into side of timer.
If you want a timer to replace outdoor light switch: buy in-wall timer Aube T1032 or Lowes sells Utilitec 0192773.
http://waterheatertimer.org/Programmable.html#Aube
Add a comment for more help with in-wall.
Here are instructions for 59203 plug-in timer:
Plug in the timer until battery is charged.
Unplug timer so you can program easily.
Press R reset button with paper clip to clear.
Set the time of day:
Press and hold clock button
Press hour button until current hour shows
Press minute button until current minute shows
Press day button until current day shows.
Program review:
Write out ON-off schedule showing hours minutes and days
For example: timer turns ON 6:00 pm all days of week.
Timer turns OFF 1:00 am all days of week.
First step: Set program1 ON > hour, minute, and day.
Next step: Set program1 OFF > hour, minute, and day
If needed, go to next step: Set program2 ON > hour, minute, and day
Next: Set program2 OFF > hour, minute, and day
How to program timer for ON at 6:00 pm and OFF at 1:00 am all days of week:
Step 1: Press PROGRAM button until display shows 1 ON (this is program1 ON)
Press hour button until 6 pm shows
Press minute button until :00 shows
Press day button until all days of week show (MO TU WE TH FR SA SU)
Step 2: Press PROGRAM button until display shows 1 OFF (this is program1 OFF)
Press hour button until 1 am shows
If you want to set another program, you will repeat same steps for program2
Press PROGRAM button until display shows 2 ON
If you are done programming, press clock button
Press ON/AUTO/OFF button until AUTO displays
Nov 13, 2010 | Woods INDUSTRIES 83660 OUTDOOR SECURITY...
Clock is set properly. I want to turn on outdoor lights at 5PM everyday. In addition I want to turn off the lights each night at 11PM. Problem - When I go thru the process of turning on the lights it...
I answer questions for free.
I know timers and electrical devices, and have tested most of the brands.
You posted under the Woods 7-day timer 59018 or 59028.
Here is the manual:
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
There are several programmable timers today that look like Woods, and each brand has different programming.
If you do not have Woods, add a comment and I will walk through programming your brand
1) You have the clock set correctly which implies the wiring is correct. Good job!
If you need more assistance, add a comment.
If instructions help, give it a 4-thumb
Nov 10, 2010 | Woods InWall 7 Day Digital Programmable...
Hi i lost the instructions and don't know how to set the clock. please give me step by step once i reset the unit.
You posed under Aube T-1032 7-day programmable.
Aube makes a list of timers and each timer has different instructions.
For your convenience, I posted the Aube timers and manuals :
http://waterheatertimer.org/Aube-timers.html
I am more than happy to write out the long list of instructions from the manual.
But the instructions apply only to the T1032.
They don't apply to the T-1034, T-1035, T-1052, T-1054, T-1070, T-1073.
If you would like me to write out instructions for one of the other timers, add a comment and tell me which timer.
T-1032 Manual
Set current time on T-1032:
Press and hold reset button
Display should be visible
Press Hour button to set current hour with AM or PM
Press MIN button to set current minutes
Press DAY button until current day shows (for example TU for Tuesday)
Close cover and press cover to confirm times
Programming overview:
Make a chart of your programs before starting to avoid conflicts in programming.
You can set 7 different programs
Program1 program2 program3 through program7
Each program has ON and OFF
First you set program1 ON with times and days of operation
And then you set program1 OFF with times and days of operation
Programming:
a) program1 ON
Press PGM button until the display appears as below:
P1 ON means you are ready to set program1 ON
Press the Day button to select days of operation for program1 ON
Press Hour to set hour am or pm for program1 ON
Press MIN to set minute for program1 ON
b) program1 OFF
Press PGM button until display shows: P1 OFF
The display will also show the the same Days you selected for program1 ON
Press Hour to set hour am or pm for program1 OFF
Press MIN to set minute for program1 OFF
c) To set program2, press PGM button until P2 ON displays
Repeat steps above to set all 7 programs.
d) To finish programming, close cover and push in cover
e) Select operating Mode.
Press and hold the cover until AUTO displays.
f) Press in cover for manual override.
Nov 10, 2010 | Honeywell Aube by TI0323W5U 7Day...
Woods InWall 7 Day Digital Programmable Timer (59018) Logo
201 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
