Question about Hotpoint WMA46 Front Load Washer
Drums not turning at all! Fills with water and makes all the right noises just no movement from drum and belt is still on. Could it be the motor? Noticed when all lights on front were flashing like kit from night rider!!
    Brigadier General:
  • 6,277 Answers
It does sound as if the motor requires replacement unless the belt is slipping- but I think you would have heard that! It could be the controller but probably motor, especially if the washer isn't exactly new ;-0)
It might be suggested that just the brushes on the motor want changing; experience (of others) suggests that they may only last months rather than many years UNLESS the motor itself is refurbished. Refurbishment includes skimming the commutator on which the brushes run. Without skimming the brushes do not sit cleanly on the com, often causing excessive sparking and excessive wear on BOTH. Alternately a new motor! I changed the motor (and belt at the same time) on our 19+ year-old Bosch at a cost of GBP250 ;-0(
Clearly the choice is yours!
Good luck,
John C
Posted on Mar 20, 2011
Hoover 2300L 6.okg boss. Squeaking when agitating back& forth, not when spinning. Is this a bearing problem? & is it replacable. If so, from where in south australia? Or wherever.?
Washing machines don't usually run silently, but in most cases, a squeaking noise that occurs while the washer is agitating the clothing is not normal and signifies a problem. If the noise only happens when the washing is agitating, the problem is likely connected to the motor or your water pressure. Depending on the specific cause, you may feel comfortable fixing it yourself. Otherwise, call a professional.
Other People Are Reading
The Agitator
  • Agitators are located in the center of the drum, or basket, of top-load washing machines. Front loading washing machines do not use agitators -- instead, gravity moves the clothes from the top of the drum to the bottom. Agitators usually consist of a tall cone fitted with arms at the base. The purpose of the agitator is to rotate the clothes and soapy water around the tub to clean the clothes. The agitator itself is not usually the cause of the squeaking noise. It is powered by the drive mechanism, which consists of a motor, clutch and gears.
Motor Problems
  • A repetitive squeaking noise during the agitation cycle may signify a problem with the motor. Specifically, the belt on the motor may be wearing out. Some motors use rubber couplers, which also wear out easily. The belt is necessary for the agitator to turn, but over time, it wears thin, just like the belts in your car's motor. An easy way to test for this problem -- if you're handy -- is to take the belt off the motor and then run it. If the squeaking noise stops, the problem is indeed your belt. Of course, this means your agitator won't move. Replacing the belt should fix the problem.
Water Pressure Issues
  • The tub, or drum, fills with water right before the agitator turns on, and water continues to circulate throughout the washing process. As the tub fills and water circulates, you may hear a squeaking or squealing noise if you have high water pressure. This sound is caused by the force of the water moving through the pipes. To adjust this, turn the knobs on the hot and cold valves on the pipes that go into your washing machine.
Considerations
  • New washing machines may squeak at first as the parts "warm up," according to the GE Appliances website. The noise should disappear after five complete washing cycles have run on the machine. Unbalanced loads, overly heavy loads and loose items in the drum may also cause noise when the agitator comes on, but these things usually do not produce a squeaking sound.
Read more :http://www.ehow.com/info_12131280_washer-squeaks-agitating.html My Washer Squeaks When Agitating eHow
Jun 14, 2015 | Hoover Washing Machines
Machine is filling with water but the drum wont turn or spin
MOST LIKELY THE MOTOR IS SHOT OR THE BELT AROUND THE DRUM CAME OFF THE DRUM
Feb 06, 2013 | Washing Machines
Noise from machine
1.check if the bra wire is poking out of one of the drums.Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
2.clear the water pump from obstractions like coins or small objects there might be some coins stuck in it that are causing discomfort.
if all the above fails try to run the motor alone without the belt if you still hear the noise its the motor that has a problem
Oct 27, 2012 | Hotpoint Aquarius WD640 Front Load...
Miele w1113. Washer drum won't spin during wash cycle
I assume you are saying the machine is working except the drums not turning? - you need to see if the belt has come off because thats what i would check first if you hear the motor start/stop after it fills up with water.
May 30, 2011 | Miele Touchtronic W1113 Washing Machine
Dryer does not start. Drum does not turn by hand. Only makes a sound when switch is turned on.
If it is a sound like a loud hum, the motor is either fried or something is jammed preventing the drum from turning. It could be something like a sock. You just have to open things up and look around carefully, especially around the outside of the drum.
If the noise is a more normal one but the drum is not turning, check that the belt is around the drum and not broken. Some drums are just fairly hard to turn by hand, partcularly if the belt is still around the drum.
Sep 19, 2009 | Dryers
Washing machiene drum won't turn
it sounds like you've got an item of clothing jammed between the inner and outer drum
Jun 22, 2009 | Indesit W 123 Front Load Washer
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
If the machine pumps water inside but does not start :
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details , see: It doesn't spin
See also a general diagram here: redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Jan 06, 2009 | Hotpoint WMA30 Front Load Washer
Washing machine repair
Hiya .. It is probably the bearings on the drum at fault, may have collapsed... is the drum making a noise when you turn it by hand?
Regards Faggly
Mar 23, 2008 | Washing Machines
Drum not turning (WFL 2260)
possibly the belt is off/broken? can you hear the motor turning when the drum is supposed to be revolving? If not supect the motor carbon brushes, or some other fault with the motor/and /or circiut, at best it may be a burned out wire to the motor
Oct 21, 2007 | Bosch WFL 2063 Front Load Washer
Hotpoint WMA46 Front Load Washer Logo
145 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
