Question about Refrigerators
Fridge stopped working
SOunded like the fan has being having problems for a good 6 months - horrible sound now and again but nudge the fridge and it stopped.
Today fridge stopped wroking and temp flashes at 4 degrees.
You mention removing a back plate (obviously with the power disconnected) - is this inside the fridge itself? (Sorry to sound dim) - is the fan easily visible? Should I be able to simply buy a replacement or do I need to "GALMI" - Get A Little Man In?
    President:
  • 1,462 Answers
Don't know your make or model so this is general. also bear in mind i am in UK not US so may not be familiar with your appliance
back plate i refer to is inside freezer and is usually held in with a few screws or plastic clips. it is normally easily removable. you will then see evaporator pipework and fan.
there are many arrangements but the usual is a single fan at the top. this fan is used to drive cold air round the freezer with some of the cold air going to the fridge.
the usual problems are.
fan jammed by ice build up - this can be preceeded by a noisy fan when the blades are hitting ice
excessive ice build up on the evaporator pipework which causes poor airflow and hence temps rise. a temporary cure is to melt the ice off with a hairdryer
take backplate off and let me know what you find
Posted on Aug 03, 2008
Freezer fan only run sometimes
If you nudged the fan and it started working it could be defective and needs to be replaced or it could be freezing up because of freezing condensation. Be sure that all the coils under and behind the fridge, if there are any,
are free from dirt and dust. If this is a refridg/freezer be sure the air vent between them, on the inside, is not blocked by anything. The airflow is necessary for proper temp control.
Apr 20, 2014 | Whirlpool Washing Machines
RS267LBSH The refrigerator stopped working. The technician came and replaced the compressor. It works for 1 1/2 month and failed again. He came the second time and replaced the evaporator. A month
your getting ripped off try the defrost timer sounds like it is getting stuck, it operates on a 24 hour basis cycling between defrost, and turning compressor on and fan to cool the fridge
Sep 02, 2012 | Samsung Refrigerators
Four year old amana side by side has stopped cooling. Sounds like compressors is not kicking on. what's wrong?
Unplug it for 30 minutes to an hour and it should start up again. Problem is your compressor is no good. Get ready for a new fridge in 3-6 months.
Jul 25, 2012 | Amana Refrigerators
Hi, I have an LG refrigerator, the top freezer works fine but the fridge section has stopped cooling, I turned the unit off and next morning there was a large puddle of water on the floor, when I turned it...
When the fridge is not cooling that means the fan are not working or not working properly, need to replace or check if their is an ice bothering the fan to turn. ok
Feb 15, 2010 | Refrigerators
Maytag msd2456dew not cooling / not freezing after noisy fan
my Matytag msd2456dew fridge fan is running, no ice bulid up on coils in freezer section, but no cold air to freeze anything in freezer section or cold air in fridge section. what can be the problem?
Sham
Feb 15, 2009 | Maytag Refrigerators
Warm refrigerator/freezer
very good chance it is the same problem or possibly a leak of refrigerant due to joint failing where compressor is joined to pipework
Jun 05, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Top Freezer and Fridge not working
WHEN ITS NOT WORKING DO YOU HEAR A CLICKING OR BUZZING SOUND (IF SO BAD COMPRESSOR OR OVERHEATING)SEE BELOW
ALSO CHECK THE CONDENSOR FAN IN BACK IS IT RUNNING WHEN THE COMPRESSOR IS RUNNING
Feb 18, 2008 | Frigidaire FRT8IB5EW 30" 18.2 Cu. Ft. Top...
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
