When I start Die Hard Nakatomi Plaza, I can see the video presentation, but after the last video I did not see the main menu and the game crashes.
LithTech.exe opening the file in the folder where I installed the game I get a message saying "Error copying cshell.dll"
I have Windows 7 Home Basic. How can I fix this?
Instructions1
Verify the application you are
attempting to run is trustworthy, and you have downloaded and/or
installed it from a valid source.
Click the start button, right click on "computer", then select properties from the list.
Click "system protection", click the "advanced" tab, click the settings button in the performance section, and then click the Data Execution Prevention tab.
There should be two selections,
and "Turn on DEP for all programs and services except those I select"
should be selected. Click the Add button and navigate to the folder that
your game/application is installed to (usually found in the program
files folder). Click on the .exe file in the folder that launches the
application.
ok so some times you can do this from the service menu on the game its self but most of the time you have to do it on the dip switches on the pcb board
If there's no way for you to retrieve the password the last resort will be the hard reset to be able to access your game console
Here
Knowing how to reset a Wii allowsyou to move quickly from video game to video game. You can reset your NintendoWii from your Wii Remote or on the actual system, depending on which you preferand if your Wii Remote is actually working. Luckily, resetting your Wii fromeither the system or from yourWii Remote is an easy process. Instructions 1 Start playing a Wii game. In orderto reset the Wii and go back to the main Wii menu, you have to be playing avideo game. Click on the game you want to play and allow it to boot up. Onceyou are done playing the game, you can reset your Wii.2 Press the "Home" Button. Located onthe WiiRemote, it is a button between the "+" and "-"button with a picture of a house on it. This will bring you to a menu thatallows you to reset the video game that you are playing. You can only accessthis menu when you are playing a game.3 Press the button on the actual Wii. You mayhave to reset your Wii from the button on the system if your Wii Remote is outof batteries. Simply go up to your Wii and find the button that is nearest tothe top of the system. It will be the button that is lit up. Press the buttonand your Wii will reset. Please follow the instruction and it will resolve the problem .Thhank you and have a great day
Try and start with hard drive removed. This may rset ip address and allow you to get to main menu. Start it without then reseat the hard drive and restart. Good Luck.
Sometimes, the movie video suddenly gets muted during the playback and some prompt-up message shows on your screen, like "Audio outputs temporarily muted". Actually, this is caused by Cinavia Message Code 3.
