Question about MSI (PC11B2) Wireless Adapter
My wireless cardbus cb11b2 use to work on my laptop, but now my computer not register it and also the little lights on the end not flashing
Does this devise pick up internet on laptop or desk top either one
Hi cfisherman8
This is a PCMCIA Wireless Adapter Card.
It slots into the large PCMCIA Port that almost all larger laptops and notebooks have.
This device can also work in a Desktop computer but requires a PCMCIA Cardbus Adapter to be installed in the Desktop Computer for it to slot into. There are different types of Desktop PCMCIA Cardbus Adapter. Some types internally connect a PCMCIA Wireless Adapter Cardbus to an empty Motherboard PCI Slot and others externally connect a PCMCIA Cardbus to the computer via its USB or Serial Ports. See here for examples:
http://www.amazon.com/StarTech-com-Port-CardBus-PCMCIA-Adapter/dp/B000BMMN7K/ref=sr_1_21?s=electronics&ie=UTF8&qid=1316320335&sr=1-21
http://www.amazon.com/Startech-Cardbus-Adapter-Transfer-115-2kbps/dp/B004WGR6YG/ref=sr_1_12?ie=UTF8&qid=1316320098&sr=8-12
http://www.amazon.com/Quatech-PCD-X-U142--CardBus-adapter/dp/B001BEF3YC/ref=sr_1_28?s=electronics&ie=UTF8&qid=1316321566&sr=1-28
Other alternative internal wireless networking devices for Desktop computers include a PCI Wireless Network Card. See example here:
http://www.amazon.com/Sabrent-Wireless-802-11n-Network-Adapter/dp/B002DYIZ2Q/ref=sr_1_14?s=electronics&ie=UTF8&qid=1316320278&sr=1-14
Once installed, it is able to send and receive data wirelessly between the computer and any Wireless Router/Modem to which the computer is configured to connect.
This device is most easily used with a Laptop. An easier solution for a Desktop PC would be a USB Wireless Adapter.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa
Sep 18, 2011 | D-Link Air DWL 650 802.11b Wireless...
Problems with d-link DWL-G650 wireless cardbus adapter pcmcia
You can try downloading the latest driver for this card from Dlink web site and then remove the previously installed software and install the one that you have downloaded and then check if everything is working....
Dec 14, 2009 | D-Link AirPlus Xtreme G DWL-G650 108Mbps...
Can't connect wirelessly, "link light" not blinking
Please check,,Are you able to go online with Modem,If yes Then re-configure your router and restart your comp and check...i hope you can connect to internet..
May 21, 2009 | D-Link DWL-650+ AirPlus Enhanced 2.4GHz...
I have bought a laptop from someone and it has a edimax EW-7305Pg wireless LAN Cardbus. I am having problems connecting it to a netgear wireless router supplied by sky. I have sky broadband. I uninstalled...
is the mac address registered through your wireless router, your router maybe running wireless mac filter, if not try registering your wireless mac address on your router then try reconnecting your computer to your router.
Feb 01, 2009 | Computers & Internet
Ive Recently got myself a laptop but unfortunately it had to be rebooted as it picked up a virus.Since then my wireless cardbus adapter hasnt been working correctly.The link and act lights are not lighting...
You need to make a note of the EXACT make and model of your wireless cardbus adapter.
Then use an internet-capable computer to download drivers for it-from the manufacturer, if you don't already have them, which is what it sounds like. Save these drivers on a disk or USB flash drive or memory stick.
Then transfer those saved drivers to the computer that needs the drivers.
Then type "device manager" in your Windows search area
Then find your cardbus adapter listed and right click on it, and select PROPERTIES
Then click on update driver
When it asks where to look for the driver, browse it to your specified location where you saved the drivers.
You might need to restart.
Hope this helps.
Dec 16, 2008 | Computers & Internet
WPC54GS Wireless Notebook Adapter
If thsi adapter wont fit fiine to the cardbus slot of your laptop , the best thing that you can do is to replace this device I suggest you replace with a WUSB54GC a wireless adapter that will be connected to a USB port.....
Nov 09, 2008 | Linksys (WPC54GS) 802.11g/b Wireless...
External hard disk and pcmcia cardbus
There may not be enough power from the cardbus to run it. That bus is very low current to power it up so you will need the power cord.
Try reinstalled the card drivers.
Aug 04, 2008 | Computers & Internet
Compaq evo n610c
You need a PCMCIA Wireless adaptor, (this model you are getting has two slots that it will fit in) - and you must make sure you have a wireless router in your house to broadcast a wireless signal for it to recieve.
Mar 28, 2008 | Compaq Evo N610C Notebook
Wireless cardbus pc card tew -601 pc
Hi..thanks for ur suggestion..my problem has been solved by opening my computer - properties - hardware and clicking on device manager and thr other device showing yellow question mark and i thought wirelss device doesnt work properly and i cliked on update device..a nd now my pcmcia card works fine
Thanking you
Neethan
Feb 11, 2008 | Computers & Internet
Computer freezes up
Your computer may not be able to handle the 2.0 USB cardbus.
Your PC maybe 1.1 USB. If this is the case you might want to add an additional PCI card with 2.0 USB drives. This way you are up to date with the 2.0 cardbus. Resolve this issue and you should be fixed from the PC freezing.
Nov 18, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
MSI (PC11B2) Wireless Adapter Logo
29 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
