Question about Frigidaire Electric Dryer
I have Frigidaire Electric Dryer Model# AEQ6500CFG0. It was working alright, quietly, but I have noticed it is making noise (Grrrr Grrrr) while running. its not constant noise but you can hear the difference like Grrr sound goes "wown wown wown...." If you know what I mean. It is loud, and so much so that I cannot use it at night time when electric rates are low :( I read it here that It could be motor. I am ready to buy motor but how can I be sure it is before I spend? Motorl part# 131560100.
  • manjiggy Mar 20, 2011
    I forgot to mention its Frigidaire "Affinity" and one more thing.
TheMobilian
  • 8220 Answers
SOURCE: my Frigidaire dryer makes a banging noise
What you have here is a drum bearing issue. Read my award winning essay on this subject right ova HERE
Posted on Jun 09, 2009
hunter19_46m
  • 7482 Answers
SOURCE: electric dryer runs quiet initially
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch.
Then remove the top of the dryer.
Remove the lint filter, and the two screws that hold the lint filter housing in place to the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt.
Remove the drum and belt and this will expose the drum rollers, idler arm
pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the
idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go
to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Posted on Jan 15, 2011
SOURCE: loud squeaking noise coming from back center when drum tumbles
I am having the SAME issue. I try to put up with it, but the sound is horrific!!
FDE216RES2
Posted on Feb 12, 2011
heatman101
  • 43501 Answers
SOURCE: My Frigidaire electric dryer, when is running,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on May 10, 2011
heatman101
  • 43501 Answers
SOURCE: i have a fridgedair electric
heatman101
Posted on Aug 23, 2011
My dryer makes a really shrill sound when drying. Could it be a bearing going bad?
Hi jaglassburn
Yes your noise is quite possibly a bearing.
Go to the following webpage for parts and a breakdown schematic for your dryer.
Please take time to rate me
Bud
http://www.appliancepartspros.com/search.aspx?model=gleq2152es
Oct 13, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Drum makes loud banging noise.
Maybe the heat in your dryer over time has melted weak glue and loose components are hitting against the drum
Jan 16, 2012 | Frigidaire Electric Dryer
Frigidaire electric dryer (model # LEQ1442ESO) is making a loud noise. It's like a loud humming or vibration. Is it the motor?
heatman101
Sep 08, 2011 | Frigidaire FEQ1442ES Electric Dryer
I have a fridgedair electric dryer m#fer311fs0,making a constant noise and gets louder the longer it is on.not a high pitch sound.i pressed on idler pully and it seams to quiet down?
heatman101
Aug 23, 2011 | Frigidaire GLER341A Electric Dryer
My model # gler341cco electric dryer is making a
The only way to know for sure what is going on is to inspect the innards. I have assembled some photos to assist you: HERE
Jan 15, 2010 | Frigidaire GLER341A Electric Dryer
Clicking/tapping noise back of dryer
heatman101
fgj
Dec 27, 2009 | Frigidaire FEQ332E Electric Dryer
Frigidaire Dryer making loud thumping noise in back.
Some things to check.
Worn rear drum rollers, idler pulley, or drum front slide kit.
Click here for illustrations.
Hope this helps.
Aug 12, 2009 | Frigidaire GLEQ2152ES Electric Dryer
My Frigidaire dryer makes a banging noise
Jun 09, 2009 | Frigidaire GLER642A Electric Dryer
Frigidaire  Electric Dryer Logo
74 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
