Question about Bialetti Brikka Espresso Machine
I just bought a bialetti brikka pot and the espresso comes out with a slight burnt taste. i have tried turning the (glass top) burner up to high (before putting the pot on), boiling the water in the microwave before pouring it into the pot (both so that the pot is on the burner for as little time possible), and pouring it out as soon as it pops. Any ideas?
5 Suggested Answers
  • 2039 Answers
SOURCE: Coffee tastes burnt/No steam for froth
so i guess our expresso you dont have that creamy topping that lack pressure descalcify not with vinegar remove caicium in chunks have a chance of blocking everything descalcifier solution melt the calcium 1part solution 1 part water fill the water with solution open the valve if some come out close it leave the solution in it for 15 minute repeat untill empty rinse very good cheers
Posted on Feb 03, 2008
  • 7 Answers
SOURCE: Espresso irregularly spurts out the center post
It IS the gasket!!!!! Store the pot with the two parts screwed TIGHTLY together for about a week. Tighten it up as the new gasket compresses. Problem solved in two weeks or less. Funnel had NOTHING to do with my problem. Also cook on medium to low heat. High flame seems to make the problem worse.
Posted on Jul 17, 2009
  • 7 Answers
SOURCE: Bialetti sputtering after gasket replaced
Flame is too high and the top is not screwed tightly enough to the bottom. Also make sure there is enough fine ground coffee in the funnel.
  • 66 Answers
SOURCE: Need a copy of instruction manual for Bialetti
hey, screw the 2 parts tight and before that check if the filter plate is not clogged. See this guide that I wrote Avi
Posted on May 21, 2011
Bialetti mini espresso coming out very slowly
Hi there... have had this problem. sounds like you have minerals deposit problem. Put vinegar in water tank, then start machine to let all vinegar come out , it should clean it well. then do over again with water so next coffee doesn't taste like vinegar .If by the time the vinegar pasted through and water doesn't come out faster , it must be another problem. Hope this helps.
Mar 10, 2015 | Bialetti Coffee Makers & Espresso Machines
Side valve is releasing pressure too early.brikka is 3 months old
check your filter plate to make sure it isn't clogged , that could make the safety valve do it's job and go off.
Sep 11, 2010 | Bialetti Brikka Espresso Machine
Cleaning problems
Hi - I just clean mine with hot water (no soap), and dry it with a towel then leave it on the window sill... My problem is that the coffee can taste a bit metallic at times; and i want to know if I should be cleaning it after every time I use it... Suggestions?
Jun 08, 2008 | Bialetti Coffee Makers & Espresso Machines
Feb 20, 2008 | Bialetti Moka Express 6-Cup Coffee Maker
Brikka don't open!!
Three approaches to this: 1. Apply more force. Easier said than done, because these things, while elegant, are always an awkward shape. If you can't get a pair of rubber strap wrenches, you might try wrapping the bottom section in a couple of layers of cotton to keep it from getting scratched, and clamping it in a vice. Get a loop of cord, hook it over the lug the handle goes onto and stick a pole into the other end. This should allow you enough leverage to unscrew the top. 2. Pour boiling water into the top section, let it heat the top up a bit, then pour out the water and attempt to unscrew (in theory, differential expansion should improve the clearances and make it easier to undo) 3. Combine (1) and (2). A.
May 13, 2007 | Bialetti Brikka Espresso Machine
Bialetti Brikka Espresso Machine Logo
176 people viewed this question
Top Bialetti Coffee Makers & Espresso Machines Experts
Ross Keen
Frank Russell
Frank Russell
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a Bialetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
