Question about LG WM-2277HW Front Load Washer
My dispenser door sticks. It only comes out about 1/2 inch and then you have to keep opening and closing it that little bit until it comes open all the way. Where is it sticking and how do I fix it?
  • tjrandall5 Mar 20, 2011
    So far this has seemed to help. Thank you.
    Problem Solver:
  • 19 Answers
With the dispenser fully opened, reach in the tray to the retaining clip at the top above the tray. depress clip and fully remove tray. rinse tray to remove dirt and detergent, and with a toothbrush scrub away at interior guide path. use a silicone based lubricant on side rails of the dispenser tray and reinsert, open and close till problem is solved, if problem persists repeat proceedure.
Posted on Mar 20, 2011
    Thanks for the help. Sofar it seems to be working
Garage door will not stay closed. hit remote button when door is down to keep it closed
Assuming that you do not have anything interfering with the obstruction sensor located at the bottom/sides of the door opening, you most likely will need to adjust the "force-down" control. This control switch should be located on the power-head of your opener. An arrow should indicate direction to turn to increase the force down. You must be careful not to increase it too much or you will create a crushing danger for pets and children. Turn only a little at a time until a test keeps the door closed. You must then place an obstruction under the door (1 inch tall) to make sure it still reverses when an obstruction is met. Sometime temperature conditions will affect the correct operation of the opener and it will need readjustment.
Aug 20, 2012 | Home Security
The ice and/or water won't stop coming out the door when the back soft panel area is pressed. Either ice or water keep coming out when the back is pressed with a glass until door is opened. When the door...
It sounds like the actuator for your dispenser switch is sticking. To fix it you will need to get inside the dispenser housing, which involves removing the decorative front panel on the dispenser.
It's kinda tricky to get this thing apart, and it's even harder to get it put back together if you've never done it. I'd recommend calling a repairman.
Sep 28, 2010 | LG LRSC-26922 Side by Side Refrigerator
My dishsoap is not getting dispersed into the load. I use electrasol cubes, they worked GREAT until yesterday, now the little door opens but the cube is just stuck in there sort of melted when the cycle is...
IF THE SPRAY ARMS ARE ROTATING THEN THE SOAP SHOULD BE DISSOLVED AFTER THE DISPENSER OPENS. IS SOMETHING BLOCKING THE DISPENSER DOOR FROM OPENING COMPLETELY WHEN YOU CLOSE THE DOOR TO WASH. EITHER THE DOOR IS BLOCKED OR NO WATER IS REACHING THE DISPENSER.
Mar 10, 2010 | KitchenAid 24 in. KUDP01DL Built-in...
How to unlock a child proof lock for a Toyota Camry?
open the door (from the outside)
keep the door open, sit down on your heels and look at the inside of the door next to the latch, (the bit you never see with the door closed) you will see a little "tag" sticking out, probably with <LOCK/UNLOCK> printed next to it, this is the child-lock.
please leave feedback good or bad
Jan 21, 2010 | 2000 Renault 181
Ice dispenser appearing to get stuck in the open
The noise is probably the solenoid which operates the door or the one that switches it from cube to crushed ice. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Here's a diagram of the dispenser which may help.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=48122&diagram_id=656733#d656733
Jan 08, 2010 | Maytag MZD2768G Side by Side Refrigerator
Garage door only opens 4 inches then reverses and stops
you need to replace gear when the door is fully closed. then do your tweaking.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Kenmore Elite Dishwasher 630 1630 9400 Soap Dispenser Problem
From your description even when the soap dispenser opens it is opening late which is why all the soap does not dissolve.
Try adding only half as much soap and see if it opens then - even a little spilled soap catching on that little latch mechanism can cause it to be difficult to close and stick opening.
Also make sure that the spring that controls the door is not broken.
May 19, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Fridge door pops back open
The seal on your door may not be sealing properly, when you close the door the seal helps create a vacuum which keeps your door closed firmly, you might need to replace the door seal, you could also try leveling your fridge by putting shimmys underneath the feet, you might also want to check to make sure there is nothing sticking out of your fridge such as drawers or food racks that may keep the door from closing all the way. good luck.
Mar 16, 2009 | Refrigerators
Cann't eject cassette from Canon ZR60
I had a similar problem last few days with my ZR60.
The problem I had was that the tape won't eject and on repeated attempts to eject it would eject as if it had a mind of its own.
I was messing with it a little bit and realized that the door was not opening fully. Being a delicate item I didn't realize that I was not fully opening the door may be because there was a little friction in the pivot pins or what ever.
Try to gently swing the door open fully and see if it helps.
Since I discovered this problem I tried 10-12 times, and every time it would eject the tape and load it.
I was almost going to give up this camcorder last night thank GOD, I am able to use it.
Good Luck to you.
Dec 27, 2008 | Canon ZR60 Mini DV Digital Camcorder
Refrigerator door not closing tightly
HI. thanks for your question. sometimes you put a lot of heavy jars in the door shelves . so i would raise the front of the fridge to help it close better. thanks
Oct 15, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
LG WM-2277HW Front Load Washer Logo
123 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
