Question about Panasonic Lumix DMC-FS7 Digital Camera
My panasonic dmc fs7 wont turn on, even when it has been on charge for a significant amount of time. there is absolutely no life in it
  • 172 Answers
SOURCE: Just purchased a panasonic dmc
What do you mean 'won't work'. Won't power on?
If it won't power on and camera and battery is new. I would suspect batterry or charger fault to begin with, assuming you know the outlet socket you charged it in is good. Charger should have green light on while charging batt for about 3 hours.
If you have a voltmeter, outside terminals of charged battery should read about 3.7 to 4Volts. Also be sure battery is installed correctly. Don't belive it can be reversed, but not sure.
Hope this helps.
Posted on May 16, 2008
  • 11967 Answers
SOURCE: my flash bulb doesn't work, picture are dark
Do you have it turned off? Is there a picture of a lightning bolt with a line through it? If so, press the button with the lightning bolt until the screen shows a lightning bolt and an "a". Also, do you have the camera set on a scene mode such as night? The flash won't go off in some scene modes.
Posted on Jan 28, 2010
  • 146 Answers
SOURCE: DMC-FS7 I have activated language to Japanese and
Press [Menu/Set], select the [Setup] menu icon [Wrench/Spanner icon] and then select the[Face with a speech bubble icon] to set the desired language.
Hope this helps.
Posted on Mar 20, 2010
Obertelli
  • 3006 Answers
SOURCE: When I turn the camera
This is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Panasonic service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you.
Posted on Sep 24, 2010
lock123
  • 6831 Answers
SOURCE: My camera is coming up with a system error (zoom)
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Oct 07, 2010
I just took the camera out of the box and after fully charging the battery, I began to check out my new panasonic lumix DMC-FS7. After taking 2-3 pics, the camera stopped working and an error message...
Go into the menu and find "reset" and follow the on-screen instructions. If this does not solve the problem, then you need to return the camera.
Nov 24, 2010 | Panasonic Cameras
I have a new Lumix DMC-FS11 How can I rotate video footage 90 degrees so it plays the right way when down loaded ?? Thanks
You can't. Not without special software and a *really* powerful computer. Rotating a video takes an enormous amount of number crunching and processing time and even then you'll suffer a very significant loss of quality.
Sorry this is not the answer you hoped for, but rotating a single still image is one matter and a video is a different ball game altogether.
Sep 30, 2010 | Panasonic Lumix DMC-FS5 Digital Camera
How do I get my Panasonic Lumix DMC-FS7 to delete pictures...when I delete it says can not delete? I'm frustrated....
If the slide switch on the side of the card is in the locked position, you cannot delete....move the switch.
Aug 08, 2010 | Panasonic Lumix DMC-FX10 Digital Camera
DMC-FS7 I have activated language to Japanese and now can not understand language to restore back to english
Hope this helps.
Mar 20, 2010 | Panasonic Lumix DMC-FS7 Digital Camera
How to change the language to english because its in japanese language?
You can download the manual (in english) from here .....
http://www.panasonic.co.uk/html/en_GB/Products/LUMIX+Digital+Cameras/Stylish+Compact/DMC-FS7/Manuals/1994677/index.html;jsessionid=0a6d28f030d771f7f5cda5bb4afaa2aa879f33d20d0a.e34MaN0RbxyTbO0LbxiRax4Kb30Pe6fznA5Pp7ftolbGmkTy?trackInfo=true
The important thing to note is that irrespective which language its in, the menu choices are the same in all languages. i.e. if menu choice one is <data> in english, its the same in Japanese - even if it looks like a stream of rather pretty characters.
Menu language is dealt with on page 29 of the manual. It looks like a simple change if you recognise the icons they have used.
Feb 25, 2010 | Panasonic Lumix DMC-FS7 Digital Camera
No live video output on PC via composite video socket.
That's only for playing back videos you shot on the camera. It doesn't provide live view to an external source.
Jan 29, 2010 | Panasonic Lumix DMC-FS7 Digital Camera
I drop my perfect Lumix dmc-FS7. now works but screen shows only half of the view, Is there any chance I can buy new screen? is it really expensive ? is it better to buy a new camera?
if you camera is less thn a year old, and it doesn't have a DENT that you can tell, you can send it back to the pananosic repair sop for free.
if it is really bad don't waste your time they will send it back to you o call you asking for the same amount you pay for the camera o more. crazy isn't !.
here is the screen replacement at ebay
http://cgi.ebay.com/Panasonic-Lumix-DMC-FS7-LCD-DISPLAY-SCREEN_W0QQitemZ170382572016QQcmdZViewItemQQptZDigital_Camera_Accessories?hash=item27ab97b9f0
you paid from 180 to 240 on this camera so it will be wort to get the replacement. just don't loss the screws lol
Oct 08, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
Camera will not turn on
Honestly, drop it again.. this worked for me in december when i had the same problem.. just tap it on a table a couple of times, reverse the effect. This worked for me!
Jul 19, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Panasonic Lumix DMC-FS7 Digital Camera Logo
107 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
