Question about PNY 4GB USB 2.0 Flash Drive - Grey/Black
HOW TO USE FLASH DRIVE - PNY 4GB USB 2.0 Flash Drive - Grey/Black
  • 492 Answers
For most PC's you just plug it in to the front USB port. The software will install automatically. Just follow the promps and it will create another drive every time you plug it in. You treat it just like Drive C.
Posted on Mar 20, 2011
Is there a way to change the font color of files and folders names in a flash drive?
I found it, from another web site. SmartUSB.net.
It explains step by step, how to change font color in a flash drive.
Change font color in your flash drive
http://www.smartusb.net/p/change-font-color-of-your-flash-drive.html
Show your colors to your brother.
Change your flash drive icon
http://www.smartusb.net/p/change-flash-drive-icon.html
Insert symbols to your flash drive label
http://www.smartusb.net/p/insert-symbols-to-flash-drive-label.html
Hide a file or folder in your flash drive
http://www.smartusb.net/p/hide-file-or-folder-in-flash-drive.html
Add wallpaper to your flash drive background
http://www.smartusb.net/p/add-wallpaper-to-flash-drive-background.html
Jul 25, 2012 | Electronics - Others
Tip
FLASH DRIVES - RESTORE & RECOVER DATA
Restore and Data Recovery on Flash Drive
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
on Sep 09, 2010 | Computers & Internet
How to add wallpaper to flash drive background?
First you need to create a desktop.ini file in your flash drive.
Open Notepad and click Save as.
Then set file name to desktop.ini and change Save as type to All files.
Click Save as.
Place your wallpaper in the flash drive. It should be a ".jpg" file
Open desktop.ini file from your flash drive. Copy and paste below code to it.
Last line of the code, you can see "IconArea_Image=wallpaper.jpg". Replace "wallpaper.jpg" with your wallpaper name.
[ExtShellFolderViews]
{BE098140-A513-11D0-A3A4-00C04FD706EC}={BE098140-A513-11D0-A3A4-00C04FD706EC}
[{BE098140-A513-11D0-A3A4-00C04FD706EC}]
Attributes=1
Save your file. Unplugged the flash drive from PC and plug it again. That's it.
If you need more information
Visit SmartUSB.net
How to insert symbols to flash drive label?
There is a method to do it. But not simple. But following few steps you can do it.
Visit SmartUSB.net.
It explains step by step, how to insert symbols to flash drive label.
I think you will also like these things,
Jul 25, 2012 | Computers & Internet
How to change flash drive icon?
Change the icon of a flash drive or any kind of removable disk which use to store data, is very easy.
Just try this,
1. Open Notepad and copy and paste below 2 lines to it.
[autorun]
Icon=logo.ico
2. Save it as autorun.inf to your flash drive
Before to click Save as... change Save as type to All Files
3. Then copy and paste your Icon file to flash drive
4. Rename it to logo.ico
5. Remove your flash drive from the PC and plug again
You will see your flash drive with a custom icon
For more and clear information visit
Jul 24, 2012 | Computers & Internet
I got a new transcend USB jetflash drive 16GB, but my system not showing any response towards it, what shall i do..??? is to download a software for it...??
Flash drives do not need a drivers (plug and play). There are several possibilities:
1. Assumptions: USB port error, computer drivers normal, normal flash drive.
Solution: insert a flash drive into another USB port. If the USB port 1 is not detected, insert flash drive into a USB 2, USB 3 or USB 4.
2. Assumption: normal USB ports, computer driver error, a normal flash drive
Solution: reinstall the chipset drivers, or USB.
3. Assumption: normal USB port,
computer driver normal, flash drive is broken
Solution: try to insert the flash drive into another computer. If the flash drive is not detected, it means your flash drive is damaged.
Solution to determine the cause of damage:
1. If you have a USB mouse, use the mouse to check the damage to the USB port. Example: connect the mouse to the USB 1, USB 2, USB 3 or USB 4. If every USB port, mouse is detected, the conclusion normal USB port
2. To check your computer's drivers, right-click My Computer - Properties - Hardware - Device Manager
3. If points 1 and 2 are normal, the possibility of flash drive damaged.
Because the new flash drive, flash drive is most likely normal. Based on experience, cause damage to the flash drive is a USB port is dirty. The USB port is dirty, can cause short-circuit flash drive. The characteristics of short-circuit flash drive. When inserted into a USB flash drive (about 5 seconds), the temperature of the flash drive become extremely hot. If there are problems like this, immediately unplug the flash drive, to prevent permanent damage.
I hope this information helps.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Transcend Jf V30/ 32 gb flash drive. When saving data less than 4GB and after removal of flash drive most data are lost. What can I do ?
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive to working order you need to format the flash drive,BUT you will lose the data stored on the flash drive.
www.artplus.hr/adapps/eng/dpr.htm www.CardRecovery.com
Mar 15, 2011 | Computers & Internet
I plugged in my flash drive and nothing happened. Why is it not recognized
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
Nov 25, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How to recover flashdrive transcened 4gb v30, it can detect but i can't open?
If you need the data on the flash drive this program may help: -
Oct 11, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Windows asking me to format my flash drive
Just format your flash drive! Before you start formatting your flash drive, transfer all data from your flash drive 'cause when you format your flash drive, it will erase all the data. After you have formatted the flash drive, then you can transfer back the data to your flash drive.
Dec 20, 2008 | Computers & Internet
PNY 4GB USB 2.0 Flash Drive - Grey/Black Logo
366 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Sandy Moore
Sandy Moore
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
