Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
I have a husqvarna 137 chainsaw. The problem is with the bar oil. When the saw runs oil is flowing but where the rubber corner piece which allows the oil to flow out of appears to be just dripping the oil straight out. It looks like it should fill a small reservoir behind the metal plate and the oil then moves upwards where the chains drags the oil through the oil hole on the bar which is moving outwards as in the top chain on the bar. However the chain-brake area is just getting messy with oil splattering all over and the bar not actually getting oiled. I have fitted a new metal plate to see if the corner of the original was not sealing properly but that has not helped. The bar holes are clean. Any suggestions as I can't see what it could be?
  • marcus459 Apr 12, 2011
    I have since fitted a new worm gear and oil pump assembly but still very little oil is reaching the bar instead it makes a real mess in the chain brake assembly
It's the rubbers. I had the same problem with my 137 and 141. The rubbers shrink over time and the oil never makes it up the channel. The replacement part is one piece and less prone to leaking than the original 2 piece design.
Posted on Jan 29, 2012
  • 710 Answers
Hi marcus,
The bar and chain oil goes into the oil tank on the side. The oil for the engine is mixed with the gas before filling the gas tank.
Hope that helps.
Handy Andie
Posted on Mar 20, 2011
  • 1 more comment
  • Handie Andie
    Handie Andie Mar 30, 2011
    This is for anyone who is looking for this answer. I misread the question when I answered it.
    If the bar oil is running out near the clutch too freely, I have found that sometimes the problem is because the bolt holding the bar on is not seated correctly. It is the outside bolt and is accessible through the bar oil filler cap. The bolt has a square head and fits snuggly between two ridges in the bottom of the bar oil container. I used a magnet extension and just reseated it, then tightened the nut on the bolt tightly to pull the bolt on tight. Have not had a problem since.
    Hope this helps someone. If it does, I would appreciate a vote or comment.
    Handie Andie
  • Handie Andie
    Handie Andie Apr 12, 2011
    Hi Marcus,
    Did you replace the oil seal or check the pump and all its components for cracks or leaks?
    Could have something like that. If the bolt in the oil container is completely tight and fitted properly, the only other thing it could be would be a leak in the pumping system, such as the above. In that case, the bar wouldn't be getting enough oil.
    Handie Andie
  • marcus459 Apr 13, 2011
    Hi Andie, do you mean the two bolts that come out of the saw body that fit through the bar, I have to check if one of these is aligned correctly through the bar oil chamber? I have replaced the worm gear, oil pump, plate that fits over the rubber hose/oil port and I have also replaced this. There is adequate oil coming out but the plate just simply is not sealing properly to hold the oil so that move up to the channel that aligns with the oil hole in the bar. I'm getting a hell of lot of oil splattered in and around the chain brake area but the bar is getting quite hot still.
How to adjust oil flow to bar on husqvarna 51 saw
The 51 does not have an adjustable oil pump.
Feb 16, 2014 | Husqvarna Chain Saw 20" Bar
Tip
Chainsaw Bar Oiling
Keeping your chainsaw bar oiling during use is the life of not only your bar but your saw. If the bar is not oiling, you will over power the engine on the saw thus depleting it's service life. <br /><br />On most saws there is a oil set screw on the bottom of the saw next to the bar; it has three settings. One way to see if your bar is oiling is to start the saw and put a piece of cardboard, old shirt or board in front of the saw while it is running. Rev the engine up with the bar in front of the piece of material and you should see a vertical line appear. If you can see a vertical line, your saw is oiling properly. If you see a vertical line with a lot of spray, then it is oiling to much. Adjust the set screw accordingly. <br /><br />Another thing to keep in mind is to make sure your oil line running from you oil fill tank is not clogged with debris keeping the bar from getting sufficient oil. <br /><br />Also, if you have a bar where the tip can be lubed, make sure you grease it. The tip of the bar gets extremely hot and keeping the tip properly greased will allow the bearings in the tip to last longer. Here is what you need and how to do it below:<br /><br /><span style="font-weight: bold;">Grease Tip of Bar</span><br /><br />Purchase a pre-filled grease gun manufactured specifically for the tips of chainsaw bars. Oftentimes, when purchasing a new saw, one will be included, if not they are inexpensive to buy. Use high temp grease when refilling. Place tip of grease gun in hole at tip of bar, and give a few pumps. When grease comes out the end of bar, enough has been used.
Keywords: Saw, Chain, Oil, Grease, Husqvarna<br /><br />
on Nov 15, 2010 | Garden
Fuel mixture for a Husqyarna E-series 137, mod/137802010
The mixture should be 50-1 with Husqvarna rwo stroke oil, it is recommended that you use a mixture of 25-1 with other brands of two stroke oil, this is because they do not know the quaility of other brands, always try to find genuine Husqvarna oil.
Aug 27, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
359 chainsaw husqvarna. is there a manual oiling adjustment or is it always automatic? There seems to be some sort of adjustable screw above the oil reservoir fill cap.
The screw above the filler cap is to hold the housing on. The adjusment screw is on the bottom of the saw. When looking at the bar side of the saw, turn it over and you should a screw below the bar and clutch. It has 3 positions. Turning it to the right will decrease the flow of oil, to the left to increase it.
If you put a longer bar and chain on, you usually have to increase the oil flow.
In case you didn't know, to check to see if you have the oil flow correct, run the saw with the blade facing a light, flat object or a chunk of wood you just cut. You should see a light oil line appear after a minute. This is a good way to be sure your pump is working. If you don't see a line of oil, something's wrong. Out of oil, pump not working, etc.
Hope this helps. If it does, I would appreciate a vote or comment. Thanks,
Handie Andie
Mar 30, 2011 | Husqvarna Garden
No chain oil feed
not sure if the 455 rancher is the exact same as my rancher but when the oil feed on my saw seems slow i remove the chain and bar and clean the chain grove. pay special attention to the end that is near the motor there are a couple of places that allow the oil to flow from the saw body to the chain groove and then subsequently to the chain
Feb 25, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Why is my husqvarna chainsaw not oiling?
Not wanting to be patronising, is there oil in it?
Ok, now sensible answer...
Have you cleaned it - remove the chainguard, chain and bar. Using compressed air, blow through the oil hole in the bar, and in the machine where it meets the bar and between the rails on both sides of the bar.
are you sure that it isn't oiling? rev the machine to maximum and hold the tip of the bar about 2 inches from a reflective surface for about 20 seconds. if you see a thin layer of oil, then the saw is actually oiling ok (huskies tend to run a bit dry but don't worry)
Try turning up the oil pump - turn the saw upside-down, behind the chaincatcher on the sump of the saw you shuld see a silver screw turn it anti-clockwise to increase the oil flow.
hope this helps.
Jan 11, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 235 is not oiling.Hole and groove on bar have been cleaned. The saw does drip oil with the bar off when running.All parts are clean but bar is not getting oil.Hope you can help,thanks.
With saw running and high speed hold saw close to a piece of wood and check for oiling. If still no oil, then use air pressure at hole in bar to clear.
Sep 26, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 350 oil not getting to chain
Take the bar and chain from the saw. Clean the two small ports that run from the large oil holes at the drive end of the bar out to the chain groove on each side. Clean the entire chain groove. Start the engine with these parts removed--oil should ooze out from the side port in the engine case with the engine running at med speed. If it doesn't, then there is trouble near the pump inside the case. When everything is back together, run the saw at full speed with the bar tip near a piece of cardboard--it should throw off a thin line of oil onto the cardboard after a few moments of running. Hope this helps!
May 26, 2010 | Husqvarna Chain Saw 20" Bar
Husqvarna 272 xp, setting for setting screw for oiler
To check for proper oiling, run the saw at speed with the tip of the bar near a piece of cardboard--it should throw off a thin line of oil after several moments of running. Adjust the oil adjust screw CCW for more oil. The screw is usually in the lower front or underneath the engine. Remove the bar and chain first before adjusting anything and check the oil passages located in the drive end of the bar for plugging--especially the two small passages that go from the large oil holes out to the chain groove on both sides. Start the engine without the bar and chain--look at the oil port where the bar mounts next to the engine. It should ooze out oil with the engine running fast. If nothing at all, the pump, oil lines, and oil filter in the tank should be checked. When everything seems to be working, then adjust oil flow for best operation. Hope this helps!
Apr 17, 2010 | Husqvarna Chain Saw 20" Bar
137 stalls
Sounds like an air leak somewhere. Or possible a clogged fuel filter.
Mar 14, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
560 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
