Question about Sport & Outdoor - Others
There was no operating manual for my Marksman Metal Detector Professional Grade #1 Discrimination Settings.? #2 sensitivity Knob? #3Target Indicator? I know these 3 ??? are stupid but I don''t want to mess up on my son's gift to me. Any help would be greatly appreciated. thank you
IS THER A VIDEO THAT SHOWS ME HOW TO DO THE SETTINGS ON A MICRONTA 4003 VLF
It is one of the simplest ones to use. My niece used one for a while. I could not find a video but here are the instructions;
Instructions
    • 1Turn the metal detector on with the "Volume" knob. This also adjusts the level of sound.
    • 2 Check the batteries. Turn the "Test" knob to the Battery 1 or Battery 2 position and confirm that the needle points to the green area. Then turn the knob to "Nor" for normal operations
    • 3 Hit the red "Auto Tune" button on the carrying handle with the head portion of the detector away from any metal objects, and turn the "Tune" knob until the needle hits 0.
    • 4 Turn the "Sens" knob to the middle position.
    • 5 Turn the "Mode" knob to VLF (very low frequency), and turn the "GND" knob to account for the type of ground (such as dirt or sand) you are using the metal detector for.
    • 6 Turn the "Mode" knob to either the TR1 or TR2 position. To set the detector to find metals such as gold or silver, set the "Discrim" knob to Non-ferrous Metals. You can also set it to find Ferrous Metals if you want to search for iron or steel.
    • 7 Hold the detector with the search coil parallel to the ground. You can adjust the angle of the search coil by loosening the wing nut on the end of the shaft and swinging it to the desired position.
    • 8 Swing the detector in wide sweeps about 2 inches from the ground.
Read more : http://www.ehow.com/how_5011582_use-micronta-metal-detector.html
Jan 30, 2015 | Retail Supplies
Manual for ranger security 33 zone walk through
Here is your manual in English pdf format:
http://148.243.99.22/CONTROL_DE_ACCESO/RANGER/manuales/33Zone-Manual.pdf
Jul 08, 2014 | Ranger Security Detectors Ranger Security...
How do i set my green youth metal detector to only to coins
u cant set these for only COINS but u can use the u can exclude unwanted or limit these with the anolog controller settings.. it can be good and bad though..if u set it to discriminate to high..u will then take the chance of excluding smaller items.. to low and u then get cross signal issues and dig up lots of junk.. best to learn the way it behaves with diff kinds of metals and at diff depts so u dont miss out on that one chance to hit it big..
When out hunting with a metal detector, you could come across more junk than treasure. You may detect and dig up rusty nails and bottle caps in the hope of finding coins or other valuables. To resolve this issue, most detectors are equipped with a discriminator. Setting the discrimination level allows you to distinguish between good and bad tones when hunting for specific metallic objects. One of the most effective ways to use your discriminator is with a technique known as reverse discrimination.
Chadman
Aug 19, 2013 | Wildgame Innovations Youth Analog Metal...
Bought a famous trails metal detector and when installing batteries and turning it on the needle shoots all the way to the left.Nothing will move it nor will it detect anything.the manual says something...
I have a metal detector similar to a Famous Trails.
This would indicate that your sensitivity switch is set to full high. Try rotating the sensitivity switch to the center. There should be a button just below the meter which, when pressed, causes the needle to center.
With sensitivity set to mid range and the needle centered, the buzzer should not be sounding unless the coil is near some sort of metal.
Make sure all of the other knobs, if any, are also centered.
Aug 04, 2013 | Famous Trails Discriminator Ii Metal...
I am going to buy myself a metal detector. Should I get one with automatic/ preset detectors or a manual one?
That's a really good question. Manual settings on detector for discrimination can increase the depth at which things are detected, but if you get the settings wrong, you probably won't find much, so it's a risk. I think that for less experienced users, automatic detector settings are the best solution a it reduces the likelihood of making mistakes.
Feb 21, 2013 | Retail Supplies
Bounty Hunter Quick Draw 2 Detector de metales
Thanks When you're ready to step up to the world's finest <A HREF="http://detectorsforgold.com/gold/category/metal-detectors-gold">metal detectors</a>, you're ready for Bounty Hunter. And get set to dig deep. Not into your pocket, but into the ground. That's because genuine<A HREF="http://detectorsforgold.com/gold/bounty-hunter-tracker-iv-metal-detector.html">bounty hunter tracker iv</a> can pick out virtually any metal object from any terrain - yet even with all their features, they are surprisingly affordable.
Jan 22, 2013 | Bounty Hunter Digger Metal Detector
Precison Gold metal detector instructions for use
I still think you can't rely too much on metal detector. Well, metal detecting is far more difficult than you think. Besides owning a good metal detector, the most important thing is that you should be very patient. Because you will find much more scraps than treasures.
Jul 19, 2012 | Sport & Outdoor - Others
A Radio Shack Metal Detector
http://support.radioshack.com/productinfo/DocumentResults.asp?sku_id=63-3006&Name=Metal%20Detectors&Reuse=N
Dec 27, 2008 | Bounty Hunter Digger Metal Detector
Sport & Outdoor - Others Logo
281 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
