Convert cubic feet to gallons - Office Equipment & Supplies
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
That depends on the gallon. One US gallon is about 0.13368 cubic feet. One UK gallon is about 0.16054 cubic feet.
Posted on Mar 20, 2011
Can you help me i need a pump that will produce 1 GPM thru 250' x 1/2" tubing @ 10psi
You can convert pipe size to gallons per minute of flow by calculating the cross-sectional area of the pipe and making some reasonable assumptions about pipe volume and the rate of flow. Pipe sizing is measured by the internal diameter of the pipe, not the overall outside diameter. Once determined, the overall volume can be calculated. Pipe flow is described in gallons per minute. Shorter lengths of pipe will have a greater flow than a longer length of the same diameter. This is caused by internal resistance of the pipe itself. By the same reasoning a larger diameter pipe will have a greater flow or GPM than a smaller pipe at the same pressure or flow rate. Pressure is described as pounds per square inch. The square-inch measurement is determined by the area of the pipe. The pounds are the amount of force that is placed on the liquid to push it through the enclosed space.With that background, you can estimate the flow based on the pipe size.
Find the cross-section area of the pipe. Area is equal to pi times the radius squared or a = 3.14 x r2. A two-inch diameter pipe would have a cross-section area of 3.14 x 12 or 3.14 square inches.
Understand that water has a certain pressure associated with the height of that water. One pound of water pressure, or 1 PSI, is equal to 2.31 feet of elevation in height. In other words, a 1-inch column or pipe of water that is 2.31 feet high will have a pressure of 1 PSI. The overall height -- not volume -- of the pipe corresponds to the pressure. A 6-inch diameter pipe that is 2.31 feet high will only have 1 PSI.
Find the volume of the 2-inch diameter pipe in Step 1 that has a length of 10 feet. Ten feet is equal to 120 inches. Multiply 3.14 square inches, the cross sectional area, times the length. The volume of the pipe is equal to 376.8 cubic inches of volume.
Convert cubic inches into cubic feet. One cubic foot equals 1,728 cubic inches. Divide 376.8 cubic inches by 1,728 cubic inches per cubic foot and the answer is .218 cubic feet. This means that the 2-inch diameter pipe that is 10 feet long has an internal volume of .218 cubic feet.
Calculate the amount of water that can be contained in the section of pipe at any given time. One cubic foot of water is equal to 7.48 gallons. Multiply 7.48 gallons by .218 cubic feet and the amount of water in the pipe is equal to 1.63 gallons.
Find the GPM if the flow of water is one foot per second. Multiply the one-foot per second flow by 60 seconds per minute and the flow is now 60 feet per minute. In other words the water will flow through the 10-foot pipe six full volumes for every minute. Since the piping contains 1.63 gallons per 10 feet of pipe, multiply 1.63 by six and the final GPM is equal to 9.78 GPM of water flow from the 2-inch diameter pipe.
Jan 19, 2018 | Plumbing
Convert a cyclinder with a volume of 1357 cubic feet to gallons needed to fill it
0.133681 cubic feet = 1 US Gallon
1357 cubic feet = x US Gallons
I set these up as a ratio and solve for the unknown by cross-multiplying.
In this case,
0.133681 1357
1 x
Cross-multiplying (or multiplying both sides by x, same thing) we get 0.133681x = 1357. To get x by itself, we divide both sides by 0.133681 and we get x = 1357/0.133681.
Good luck.
Paul
Dec 29, 2015 | Office Equipment & Supplies
How many gallons of water in 3172 cubic feet of water?
There are 7 1/2 gallons of water in a cubic foot.
3172 x 7.5 = 23,790
To calculate how much water in a swimming pool, in 'US Feet':
Length x Width = Surface Feet
Surface Feet x Average Depth = Cubic Feet
Cubic Feet x 7.5 = Total Gallons
Mar 07, 2015 | Pool & Spa
I Need To Convert 110 Gal. Of Diesel Fuel To Cubic
110 US gallons is about 14.70 cubic feet. 110 UK gallons is about 17.66 cubic feet.
Oct 18, 2014 | Office Equipment & Supplies
72in x 29in x 24in how many gallons calculator
72 x 29 x 24 = 50,112 cubic inches / 1728* = 29 cubic feet. There are 7.48 gallons per cubic foot, so the tank is actually 216.92 gallons, assuming the dimensions given are inside measurements. I hope you have a strong stand and floor because the water alone weighs 1735.36 pounds (8 pounds per gallon).
*12 x 12 x 12 = 1728 (cubic inches to cubic feet conversion)
Jul 17, 2014 | Aqueon All Glass Aquarium Co. 210 Gallon...
Cubic feet calculator
17.6 cubic feet is 17.6 cubic feet.
You can't convert cubic feet to feet any more than you can convert your height to gallons.
Mar 22, 2014 | Office Equipment & Supplies
Inches to cubic feet
Inch is a measure of length and cubic feet is a measure of volume. There is no conversion between them. It's just like trying to convert inches to gallons, it can't be done.
Now if you want to convert cubic inches to cubic feet, that's possible. Since there are 12 inches to a foot, there are 12-cubed or 1728 cubic inches in a cubic foot.
Jan 10, 2014 | Office Equipment & Supplies
How many gallons per cubic foot? Or... how many gallons in 9 cubic feet?
Google is very good at this, if you type "us gallons to cubic feet" it will work it out for you.
So 1 US gallon = .13368 cubic feet
or 9 cubic feet = 67.32 US gallons
Mar 24, 2011 | Office Equipment & Supplies
502 people viewed this question
k24674
jasbo
jasbo
