Question about Hyundai Computers & Internet
Hyundai n220w monitor, just stopped working, blue light flashes slowly but screen will not come on
5 Suggested Answers
SOURCE: Sceptre X7g Monitor Flashing Red & Blue Lights. Blank Screen
i fixed this problem by unplugging the monitor, unplugging the video cables. Then hold down the power button while plugging it back in. Release power button and then press power button for on. It worked then. I got the icon for no signal, i plugged back in my monitors. Sceptre X9W
Posted on Mar 10, 2008
ginko
  • 19396 Answers
SOURCE: F-17 neovo monitor stopped working. power light is flashing yellow
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1 The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours, sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr suddenly are a blown capacitor on power board, the inverter board powering up backlight lamp has blown, or a fault on main lcd controller board.
check also the video cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Check connectors, try moving the video cable, and if the cable is not built in, then also try a replacement cable.
Regards
Posted on Mar 06, 2009
SOURCE: Samsung monitor blue flashing light, black screen
The picture board of your monitor has developed fault. That is why the screen is black.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity, because the fault is not something you can fix in other not to complicate issues..
The repairer will help diagnose and replace the faulty picture board and your monitor is back and better.
Take care.
Posted on Apr 19, 2010
SOURCE: Samsung 953BW monitor. Blue light is flashing but no picture.
hi, i have the same problem...any solution?
Posted on Jun 26, 2010
Hyundai U220WD LCD monitor displays OFF MODE (on a black backgroung). How do I restore the display? What does the MWE button do?
Hi
If the screen is connected to a computer usually its a video card/ video cable problem and not the LCD monitor. Try to check the video cable look for loose connection or bent pins, if none try using a different video cable or checked the video card component of the computer too see if its still working,. Your monitor is dependent to your video card signal inside the computer. Without the signal monitor will not work.
thanks for using Fixya
Mar 25, 2011 | Hyundai Electronics N220W 22 inch LCD...
Moved my computer and now my monitor won't wake up. unplugging the cord to the computer comes up with a no connection signal but the blue light stops flashing. Plugging the cord to the computer back in...
Be sure computer is actually starting. Power off then on computer you should see the boot sequence and then windows screen on monitor. If you do not see startup sequence monitor is not sleeping either the monitor has failed or the video card has failed. Try another monitor first.
Oct 16, 2017 | Samsung SyncMaster 940N 19 inch LCD...
Computer screen is flashing
dell monitor will work fine and then go black with an internal blue light flashing from the bottom of the screen up. I have checked wires they are ok. I am able to get it working sometimes if I move the position of the screen back and forth or up and down the on button will stop flickering and it will come back on. HELP!
Jun 24, 2009 | HP f2105 21" LCD Monitor
Hp pavilion f1703 blue monitor power button flashesw/ dark screen
Have you tried connecting this monitor to another computer, even a laptop. This would tell you whether the display is bad or the video card is the culprit. I suspect the monitor's power supply is dying. Taking it to a pro for repair should cost @55.00. Buying a new monitor @ $100 - $125.
Mar 26, 2009 | HP Pavilion F1703 17" LCD Monitor
LiquidVideo L17LCD2 17 in. Flat Panel LCD Monitor - Power Issues
firstly stop turning it off and on because you will blow something else like a power board then it will be a big paper weight.
next get a torch and when it is powered on and supposed to be showing images, shine the torch at the screen.
if you can see everything then you have a broken backlight or problem with your backlight and connections.
they cost approx £15 and a little labour, its not a big job. you may be able to do it yourself if you can get hold of a service manual.
Feb 26, 2009 | Liquid Video L17LCD2 17" Flat Panel LCD...
Monitor is black and blue light flashing
Boot from safe mode and try a different pixel/color arrangement. Obviously a lower pixel and color setting.
Mar 25, 2008 | Computers & Internet
L90D+ will no longer work
The video card is gone ,to expensive to fix it.
Jan 03, 2008 | Hyundai L90D+ 19" LCD Monitor
Sep 11, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
Flashes on then goes black
The green light only lets you know there is a valid video signal reaching the monitor. If the green light was not "on" your problems would possibly be within the pc itself. Something is not holding the circuit for the backlight "on" thus going black. Suggestions are: 1. Take it to get it repaired (if not under warranty) Hyundai carries a 3 yr warranty on this monitor. Website provided. 2. Buy a new monitor http://www.hyundaiq.com/Eng/Customer/CusSvc/Csvc.asp
Aug 27, 2007 | Hyundai L91A 19" LCD Monitor
Computers & Internet Logo
116 people viewed this question
Top Hyundai Computers & Internet Experts
Marvin
Marvin
rhodesworks
Randy Schumann
Randy Schumann
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
