Question about Maytag Washing Machines
2000 silverado screech on drivers side front wheel only when sits overnight when I move and turn feft after about 1 mile goes away and does not come back till next morning Just replace rack and power steering pump Did not help
    Novelist:
  • 144 Answers
Sounds like a problem with either the idler pulley or the serpentine belt. If a belt is loose or worn it may slip when the alternator is working hard. Alternators work extra hard for several minutes after first starting the engine. They do that to recharge the battery after you've taken a lot of electrical energy to start the engine. The extra electrical energy is normal at startup, but if it's making a loud noise it is usually an indication of a loose belt or slipping because of a worn spring on the idler.
BTW, you posted this under Maytag washing machines; last I checked a Silverado isn't even closely related to a washing machine... just trying to help.
Posted on Mar 20, 2011
Replaced steering wheel gear box 2 days ago on a 06 f350 diseal and it will not burp
Leave truck sit overnight then jack front wheels off the ground make sure correct fluid is up to proper level Start engine and turn wheel all the way from left stop to right stop and back 5or 6 times to get all the air out of system.Make sure weight is off front tires.Recheck fluid level while doing this to make you dont suck air back into system and fluid is not foaming up.
Apr 21, 2013 | Dodge Dakota Cars & Trucks
OK, let me be more specific on the front noise on my 2006 Honda Accord, EX, 4cyl. I have 80000 miles and about 3000 miles ago, I started to hear a noise , which I believed was coming from the driver side...
While driving and with radio off, listen to the noise. Find a road that is clear on which you can drive without any traffic. Drive at a constant speed and make light shifts to the left and right, by doing this, the weight of the vehicle will shift to the apposite side of the steering wheel to which you turn.
When you turn to the left, the weight goes to the right (passenger side) wheel, if the noise stops, you may have a bad wheel bearing.
When you turn to the right, the weight goes to the left (driver side), if the noise stops, you may have a bad wheel bearing.
If the noise does NOT go away, then you may have bad CV's.
Another way to check is by lifting and securing in jack stands. Vehicle in neutral and with your hands, rotate wheel with one hand. Other hand place on suspension component. Spring of strut. If you feel slight vibration, you may have a bad wheel bearing.
With vehicle on jack stands, one hand on top of wheel and other on bottom, try to see if you can move the wheel in and out which may be a had CV.
Jul 25, 2017 | 2006 Honda Accord 2.4
Which one cylinder 1 in a 2000 chevrolet 1500 silverado
the #1 cylinder is on the front cylinder on the drivers side. From front to back on the drivers side is 1-3-5-7 and the passenger side is 2-4-6-8.
Apr 12, 2011 | 2000 Chevrolet Silverado
Upon starting truck in morning after sitting all nite there is a knocking/rapping sound coming from engine for about 5-10 seconds and once in drive and moving at a slow speed it goes away and does not come...
most likey a wrist pin bad or cam bearing and last a rod bearing you need a stethascope to locate it ehrn it's knocking. could even be a pully or belt tensioner.
Mar 21, 2010 | 2003 Chevrolet Silverado Ss
There is a humming sound coming from the front end of my 1999 oldmobile alero. Only happens when the car is moving. I dont hear itat idle or even when pushing the gas at idle. could it be my transmission...
Hello! If the humming noise is speed related(gets louder as vehicle speed increases)check front wheel bearings. If the noise goes away when turning one way or the other then it will most likely be in the front wheel bearing. If you turn the wheel(while moving)to the right and the noise goes away it is on the right side. If you turn the wheel to the left and the noise goes away its on the left side. Hope this information helps!
Sep 13, 2009 | 1999 Oldsmobile Alero
Screeching noise coming from driver side tire
The high pitch sound may come from the brake pads as metal parts hit the disc to signal the owner that it needs change. The metal parts gets exposed when the pads have worn out. The brake also has a hub to cover the disc. See if the metal plate is hitting it but this issue would appear when the wheels are in motion. Check if it is the belts, have the tension checked out. Other than that the bearings are the other items on your wheel that could cause a high pitched sound when you car is in motion.
Aug 09, 2009 | 2005 Dodge Neon
Screeching noise when steering
These are your brake pads letting you know that you only have %10 left. There are little metal tabs that rub on your rotors when your brakes are low and cause a squeeling noise. Just replace your front brakes.
Jun 15, 2009 | 2000 Dodge Caravan
Whirring noise in the front-end of a 2000 Cirrus
it does sound like wheel bearing a cv joint dont make noise and then stop but you can jack the car up and in neutral try to shake the tire from side to side.to see if you have any play then turn the wheel by hand try to feel for roughness in bearing. let me know what you find. Phil.
Jun 09, 2008 | 1993 Chrysler Concorde
Washing Machines Logo
43 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
