Question about Maytag Washing Machines
Clothes come out very wet. washer spins but not fast enough.what part needs to be replaced on a maytag front loader model #mavt236aww
    Brigadier General:
  • 6,277 Answers
This sounds very much like the motor is failing or the belt is slipping. Motors- and belts, which is sensible to change at the same time- are easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts, normally 2, should be loosened and the belt removed then remove the bolts completely
With the motor it is false economy to just have the brushes changed. Experience of others is that the brushes may only last months unless, that is, the motor is totally refurbished. Refurbishing includes skimming the commutator on which the brushes run. Without skimming the brushes do not sit firmly on the commutator but straddle it- the centre is often more worn than the outer part.
Unfortunately motors are not cheap- the motor for our 18+ yearold Bosch cost GBP250 but it will probably outlive us! It's your choice obviously.
Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
Hope this is your problem solved.
Good luck,
John C
Posted on Mar 20, 2011
All cycles work but clothes come out wet, top loader model# AAV7000AWW is there a lint trap that needs cleaning?
Lint traps are in dryers, not washers If clothes still come out wet then perhaps the water pump is not working properly and/or the drum is not spinning fast enough to allow centrifugal force to remove water from clothes.
Feb 07, 2016 | Washing Machines
I have a Fridgidaire front loader. It completes the regular wash cycle, but clothes are soaking wet- it's not doing the final fast spin. When I select the drain/spin option, it drains and eventually...
Either an off balance load (unlikely if it happens all the time), a bad door switch, or a bad motor control board. Easiest repair is to try replacing the door switch, failing that, i'd call someone in to test the speed board.
Apr 05, 2010 | Frigidaire ATF6000ES Front Load Washer
Kenmore washer 3.5 super capacity. Machine spins
It sounds like your tub bearing is bad or going bad. It could be the adjustment on your spin cycle. Does your unit allow you to adjust this. Also are you overloading. Can you send me the brand and model of your unit and I help you more.
JimmyC
Oct 05, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
My kenmore front loader wont spin fast. it will spin when the clothes are washing slowly but wont spin fast to get rid of the water so clothes stay soaking wet.
Check your drain and make sure it isn't plugged. If ok then remove the bottom panel on the front of the machine. Under it is the washer pump. The pump is either clogged or bad. The washer will not go into a full spin when the water isn't draining properly.
Sep 16, 2009 | Washing Machines
My washer doesn't wring the clothes fully.
It's not spinning fast enough because of a loose or worn belt on the motor. Post back with your model number and I may can find a diagram of your washer to help you.
Sep 04, 2009 | Maytag Performa PAV2200
Maytag Neptune MAH6700AWW spins but not fast enough
Too much laundry in your machine. Try a smaller load and see if you have the same problem
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Jan 17, 2009 | LG WM1814CW Front Load Washer
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
Washing Machines Logo
156 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
