Question about Bosch Washing Machines
Cant opne the drawer-softner/powder dispenser on my bosch 1200 s express
    Brigadier General:
  • 6,277 Answers
Here are my complete guidance notes for accessing and cleaning dispenser drawers.
The Bosch one is first on the list. If you still cannot remove it i.e. it is stuck come back to me, please!
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
One of these should enable you remove it
(I am having to guess some of the following!)
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
Good luck,
John C
Posted on Mar 20, 2011
The fabric softner is staying in the drawer after cycle has finished. the drawer is clean so dont know what to do to solve this problem. it is modell classixx 6 1200 express
Hi Carol from retired Englishman in SW France,
I hope you don't mind me saying so but often the softener dispensing siphon tube gets missed when cleaning the dispenser 'cos it's difficult to see!----------->
If this isn't the problem it could be that the water dispensing is not working correctly. It is easy to check by selecting (final?) rinse, pulling the drawer slightly out and seeing and hearing whether water is being fed into the softener tray. If is isn't then it is a call-out ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 31, 2011 | Bosch Washing Machines
I have a Bosch Exxcel 1200 Express washing machine and notice that the fabric softener is not being flushed into the drum. Otherwise it washes OK. I have scrubbed out the powder tray and emptied the...
John C
Jun 18, 2011 | Bosch Washing Machines
Water leak from front powder/conditioner drawer.
Completely remove the dispenser unit. look inside the recess you have just taken the dispenser drawer from and look up. You will find this is covered in muck. Clean it with an old toothbrush or something but do not use too mush pressure. This should solve your problem. If not then you will need to replace the dispenser unit completely
May 22, 2010 | Whirlpool AWM5125/1 Front Load Washer
Softner not being flushed into machine
Hiya,
there is only a few reasons for the softener not to filter through firstly i would surgest removing the drawer that the softner goes in & flushing it through with hot water this will help dislodge anything that may have built up inside, sometimes the fabric softner section has a top part that comes off if so remove this & flush both sections, if you can see a black sludge then it is just build up that is blocking the path stopping the softner getting through.
Hope this helps
Apr 21, 2010 | Bosch WBB24759GB Front Load Washer
Water is backing up in the fabric softner dispenser? After every wash I have to empty the fabric softner dispenser because it is full of water
Bosch Nexxt Premium WFMC6400UC Front Load Washer
This video will show you how to keep yoursoap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question..
Dec 03, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Indesit WIE147 leaking from soap dispenser
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 17, 2009 | Washing Machines
Fabric softener dispenser no longer works on my Bosch, the dispenser remains full of fabric softener, all else ok Bosch classixx 1200 express
Remove soap drawer completely from washer, and thoroughly clean all parts of it, paticularly the conditioner compartment..
Get a piece of stiff wire, and make a right angled bend in the end of it, then poke the wire into all the holes in the top of the soap drawer compartment to clear any possible blockage.
This should solve the prob.
Please rate my solution.
Thankyou.
May 20, 2009 | Bosch Washing Machines
Dispenser tray removal
hi, nikoltheis! i'm not sure if we have exactly the same model, but it should be pretty close. here's what my user's manual says:
Detergent and fabric softner may build up in the dispenser drawer. Residue should be removed once or twice a month
- Remove the drawer by first sliding the safety latch to the right, then pulling the drawer out until it stops.
- Reach back into the left rear corner or the drawer cavity and press down firmly on the lock tab (left rear portion of the drawer). Pull out the drawer.
- Remove the insert from the bleach and fabric softner compartments.
- Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders and liquids. Large amounts of fabric softner residue may indicate improper dilution or that more frequent cleaning is required.
- To clean the drawer opening (the empty area left behind when you remove the drawer) use a small brush to clean the recess. Remove all the residue from the upper and lower parts of the recess. (The picture shows this being done with a tooth brush.)
- Replace the insert pressing "X" to lock it in place. Return the dispenser drawer.
Jan 18, 2009 | Frigidaire GLTF2940ES Front Load Washer
Fabric softner dispenser
take the soap dispenser drawer out and clean the drawer and the underneath the drawer, then clean the inside of the machine where the drawer fits into to. It could be caused by a build up of soap.
Oct 30, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Washing Machines Logo
129 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
