Question about Yamaha 2500 Watt Industrial Inverter Generator YG2800i
Yg2800i generator runs for about 5 minutes and then stalls
    Sergeant:
  • 259 Answers
Put a new fuel filter on it and when it stalls take the fuel line off the carburetor to check if gas is getting to the carburetor. If it is remove the sparkplug put the wire on it and ground the nut of the plug on the engine block and pull the cord and check for spark between the sparkplug gap. If no spark you might have a faulty coil, when it gets hot it has no spark.
Posted on Mar 20, 2011
Yamaha Portable Generator EF 1000 iS won't start. Last time I ran the generator (several months ago) I let it run until it was out of gas. Yesterday I filled the tank and started the generator. It...
Try cleaning the carb out,(hog wash carb cleaner I use) the float may be stuck or the needle & seat.You may need a rebuild kit for the carb,about 12 bucks.hope this helps
Jan 09, 2011 | Yamaha 2500 Watt Industrial Inverter...
Yamaha EF2800i generator will only run with the choke engaged. Will not hold load. Unit was in storage for 8 months while I was out of country. Added fresh gas, checked spark plug, let warm up for...
Remove & Check Float bowl on carburettor for any foreign matter. If there is any, it could have got into jets causing engine to run lean (only run with choke) and not be able to carry load in this state. A cleanout of the carby would not hurt and check the fuel tank for any sediment as well.
Aug 24, 2010 | Yamaha 2500 Watt Industrial Inverter...
Irregualar idle on econo mode
Check the governor for excessive play, as well as the carburetor for a too rich (floats) or too lean (clogged jets). A quick shot of ether or unlit propane torch near the air cleaner will tell you which one it is. If runs better, then mixture is too lean.
Jan 30, 2010 | Yamaha 2500 Watt Industrial Inverter...
Running at idle speed
1) Check the "Economy Throttle" setting (or some similar verbage). Inverter types dont have to run full speed to produce full voltage.
2) Apply a load. These magically accellerate and decellerate according to load conditions.
Hope this helps,
Dolf-
Oct 13, 2009 | Yamaha 2500 Watt Industrial Inverter...
Yamaha yg2800i generator will only idle
My guess is that while it was running out of gas the balnket and heater was pulling a load that the generator could not keep up with. Do you still have the manual????????
Mar 25, 2009 | Yamaha 2500 Watt Industrial Inverter...
Yamaha 2500 Watt Industrial Inverter Generator YG2800i Logo
371 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
jmt
Level 1 Expert
Robert Wooley
Robert Wooley
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
