Question about Caliber Gamo USA Hunter Elite .177 Air Rifle with 39x50 IR Scope
Does it suitable for diana magnum 350 for shrt range like as 40m i can adjust scope but for long rane 100 m scope cant be zero
    Top Expert:
  • Caliber Master
  • 52,096 Answers
Air rifles are not good for 100 m
Posted on Nov 08, 2015
Scope adjustment
What type of scope are you using? Some scopes have a locking ring at the base of the turret. You may want to check for one of those.
Dec 02, 2013 | Optics
I inadvertantly changed my elevation adsjustment.
this is an excellent article on zeroing a scope.
http://www.outdoorpros.com/How-To-Guides/How-To-Zero-A-Rifle-Scope/5
Apr 06, 2010 | BSA ® 2 - 7x32 A/O Sweet 17?? Rifle Scope
CAN NOT ZERO GUN
You may try to bore sight it first. Pull the bolt and setting the gun on a good rest sight thru the barrel at a dot on the wall within ten feet. Then adjust the scope to that dot. As you adjust the scope tap the bore of the scope with a screw driver handle, tap it after each adjustment not hard, but enough to give it a sharp jolt. Once you are close here, move out to the range and shoot at 15 yards. Using a rest, again tap the scope after each adjustment. Then move out to 50 yards and you will want to be shooting high 1.5 to 2 inches here. Shoot slow keep the barrel cool and try for 2 shot groups till you have got the scope dialed in. Then move out to 100 yards for your preference of zero. Remember use the same ammo you will hunt with or at least the same bullet weight. If you can't get her to get on paper you can try to loosen the scope in the rings, one at the time once the gun is a little warm. Loosen the barrel ring first then snug it back down and then the receiver ring. If your group moved now, she was in a bind due to a cold gun at set up / installation.
Dec 01, 2009 | Optics
I used all of the elevation adjustment on 3-9-50mm scope and my 22 rifle still shoots low at 25 yards
its a bad mount thats doing this,,,you can get over it easly by letting off the rear top mount of the scope (the mount near your eye) and pushing under your scope a strip of 35mm film this will lift the eye end of the scope giving you more range,,(elevation) only put 2 or 3 strips of film under the scope any more that this could bend the scope tube when you tighten it up
but a strip of film is about 25th of an inch and 1th will give you 1/4 of an inch at 100 yds ie:1 click! so you should easly get 10 inches at 100 yds or more with 3 strips of 35mm film under the scope even with bullet drop, the only other way to sort this out is to buy an adjusterbal mount witch is very pricy and 35mm film is cheaper, i do this all the time with my scopes
Nov 21, 2009 | Tasco Scope Guide Quickly Zeroing Rifle...
I have a weaver k-8 scope with adj. rings on front bezel ??????
the front ring is for adjusting point of impact at a given range,,,its called a "parallax ajustment" it corrects for the scopes inaccuracies over its full range say from 10 yds to 100 yds there a bit of a pain on a hunting rifle as you need to focus them every time and that slows down your shooting, when only a snap shot will get the kill you cant wate to mess about focusing the darm scope so i never use them on my rifles,,unless im target shooing,, or im snipping when i have time to take my shot,,,
(a head shot only!) only a parallax scope is spot on aim from 10yds to infinity
Nov 18, 2009 | Weaver Optics
Unable to zero in on target?
take it in because if he bumped the rail the scope is on it can make it inaccurate
Aug 01, 2009 | Optics
Adjusting Range on Redfield Scope
There should be a set screw or screw that you can loosen to make that adjustment. Once you have it where you like it, just tighten it back up and enjoy you ability to make those quick adjustments when needed.
Mar 29, 2009 | Optics
When you zoom your scope does the impact point change on the target? is that when you use mil dot?
No, the cross hairs remain fixed. The zoom serves only to magnify the field of view.
Aduz
Mar 25, 2009 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
Zeroing scope adjustment
First, adjust wind-age and elevation to center or zero position. Remove your scope from the gun and make sure that the scope mounts are aligned, this is critical. Purchase an alignment tool is necessary. Then remount the scope. The scope should seat in the mounts without binding. If it does bind, the mounts are not aligned.
Start sighting in at close range,10 to 30 yards, then move out to 100 yards.
Jan 03, 2009 | Tasco 3-9x40 World Class Riflescope 30/30...
I have a Bushnell Sprotiew 4x, 15mm scope mounted on a Mossburg .22 rifle. My shots are hitting left six inches and low. Can you please tell me how to adjust this scope? Thank you.
Keep in mind Diane this is for a set distance. if you are taking a shot at a target further than your are set for (ie a target you wont get 3 shots @) remember how the bullet is travelling as it goes down range
one idea would be to set your rifle up down range and zero it in on a target (preferably paper) now adjust 1 MOA (try and have target @ 100 yards and 200 yards)
see how far the bullet moves for each moa adjustment. then check it against the next range.
this should remain constant @ a set number of inches per 100 yards.
so if you zero in @ 100 yards and then move 1 moa any direction and it adjusts (lets say and hope it is 1.047 inches") then you do the same for 200 yards. it should be twice as much movement. ie 2.094"
once you know what 1 moa represents on your scope you can adjust alot more accurately.
REMEBER the total inches of movement / adjustment per MOA is directly related to range (a precise range helps in shooting) so if your squirrel is 150 yards and your first shot is off 9" to adjust you divide 9" by the inches per moa so 1.5 (150 yards /100) X (Inches per 100 yards per moa you measured hopefully 1.047") its 9" divided by 2x1.047 = 9" / 2.094 = 4.29799
this number needs to be rounded to the nearest click on your scope (most are 1/4 MOA scopes and you can tell by looking at how many clicks/lines are inbewteen each large number on your windage and elevation dials
so to turn this into an adjustment we round 4.29799 to 4.25 which is 4.25 MOA or 17 clicks on a 1/4 min scope.
GL and any questions just post and ill help
not please rate this as fixya :)
Note i can provide EXACT information that would allow you to determine range, and windage and elevation adjustments by looking through scope and estimating range
then factoring in weather variables. NOTE you hafta enjoy math or just want to know how to shoot really well. :)
Dec 22, 2008 | Barska Optics Barska 10-40x50 Ao Varmint...
Caliber Gamo USA Hunter Elite .177  Air Rifle with 39x50 IR Scope Logo
146 people viewed this question
Top Caliber Optics Experts
George Merkley
George Merkley
obsteiner
john h
Are you a Caliber Optic Expert? Answer questions, earn points and help others
