Question about Sub-Zero 695/O Side by Side Refrigerator
Our Sub-Zero 695 frige has a EC20 and a EC40 code blinking. What could be the problem?
  • 56 Answers
SOURCE: sub zero 700 TR error code 06
Error code six means: from SZ
Refrig. evaporator thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
Erratic temp can be many things such as an open door. Clear the code by holding the bell key for 15-30 seconds or until you hear a tone. Keep an eye on your temps for a couple of days. If it comes back its time to call a service tech. If you are in OC I have the number of the best tech for Sub Zero in all of SoCal. There is more tests that can be done depending on how tech savvy you are.
Posted on Jan 23, 2009
  • 531 Answers
SOURCE: My Sub Zero 695 refrigerator seems to be running most of the time
check your coldcontrol see if to high
Posted on Apr 07, 2009
  • 173 Answers
SOURCE: Service Light
Tighten bulb.
Posted on Jul 08, 2009
hiltonjug
  • 612 Answers
SOURCE: my sub-zero 695 motor keeps running, very noisy..
If it is one with the compressor on top . Check the coils up top . You may find that they need cleaning because it sound like it's unable to cool enough to satisfy the thermostat therefore it runs all the time trying to.
Please rate solution
Posted on Aug 25, 2009
Testimonial: "Thank you for your help"
  • 72 Answers
SOURCE: the ice maker in my sub zero 695 is not working,
NORMALY ITS THE INLET VALVE THE WAY I CHECK A VALVE IS HOOK 110 VOLTS DIR TO IT IF WATER COMES IN IM THE IM MAKER ITSELF IS BAD
Posted on Nov 06, 2009
Need owners manual for a Sub-Zero 695 and maintenance manual
If your trying to remove the grill plate thats located at the top of the machine what you need to do is open both the freezer and the refridgerator doors and look up. There are three vertical phillips head screws that you'll need to remove first. After that you'll be able to pull the grate forward and remove the springs, one on each side that keeps tension on the grate. Once those are removed, the grate will be easy to take off.
Apr 26, 2012 | Sub-Zero 695/S Side by Side Refrigerator
My 632 is flashing EC 40. What is the problem?
Here's a list of all error codes for the 600-series Sub-Zeros.
http://fixitnow.com/wp/2006/06/29/error-codes-for-the-sub-zero-600-series-refrigerators/
EC40 = Excessive Freezer Compressor Run
Mar 24, 2011 | Sub-Zero 632 / S
My Service light is blinking and there is an EC 50 code flashing. Can someone tell me how to fix the problem. I have tried turning the unit off and restarting it but the error eventually comes back.
EC50 indicates that your refrigerator is running too much. Resetting it won't help. The problem will come back within 24 hours, as the control board monitors the run time of the unit. Most likely you have a bad condenser fan motor or a freon leak. Call for service asap!
Sub-zero refrigerator repair in Orange County, CA
Feb 05, 2010 | Sub-Zero 695/O Side by Side Refrigerator
Sub-Zero PRO48 fridge - Error Code 40 and EC91
Here are the most common Sub-Zero error codes:
Sub-Zero Error Code EC40: Freezer will not stop running
Sub-Zero Error Code EC50: Refrigerator runs too much
Sub-Zero Error Code EC24: Defroster is not heating enough
Sub-Zero Error Code EC 06: Evaporator thermistor reads inconsistent temperatures
Sub-Zero Error Code EC20: Defrost Bi-Metal Operation is faulty
Larry Rogers
http://sparkleappliance.com/ca/sub-zero-refrigerator-repair-los-angeles
Nov 08, 2009 | Sub-Zero PRO 48 Side by Side Refrigerator
My sub-zero 695 motor keeps running, very noisy..
Aug 25, 2009 | Sub-Zero 695/S Side by Side Refrigerator
Water/Ice Dispenser Does Not Consistently Work
Sammy, I am having the same problem with my 695. I have a call into subzero service and will let you know what I find out.
Thanks for your help as it fixed my problem as well, albeit temporarily.
Alan
Jan 12, 2008 | Sub-Zero 695/O Side by Side Refrigerator
Sub-Zero 695/O Side by Side Refrigerator Logo
96 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
