Hi from retired Englishman in SW France, Sorry but unfortunately you do not say what make and model your machine is. Different makes, models, different fault codes! Thanks, John CHi from retired Englishman in SW France,
Thanks,
John C
You can't post conmments that contain an email address.
Category moved from Kenmore Oven to Washing Machine
codes tend to be generic.. It is a speed sensor issue. you need a service call.
F7 error code Kenmore washer
The F7 E1 error code indicates a Basket Speed Sensor Fault in the top-load, belt-drive washer (VMW). F7 E1 is displayed when the main control cannot determine the speed of basket-or speed changes too quickly.
May 7, 2014
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
just press "user preset" "original size A3" and "3" simultaneously to enter service mode and the display will be "F1"
to reset the p/m, you should change the value of F7-c22 and F7-c26
go to F7 mode(press 7 to move to F7, then press start) press "2" "2", then start press "0" to reset the value of F7-c22, then press start now press "2" "6", then start press "120000" to reset the value of F7-c26 (this counter is countdown so it starts with highest count) press start press stop to exit F7 mode press "user preset" and "stop" simultaneously to exit service mode
There, there is counter, which it is necessary to throw each 12 thous.. (making at preventive maintenance of the printer). For installation new cartridge it is necessary simultaneously to press shift Ctrl F1. In connection with extension market copiers Panasonic and with all becoming more frequent questions in Conferences has solved be divided accumulated by information.
The Whole hereinafter presented information pertains to device of the serieses DP
Now about that, what fall into service mode; for entering we press consecutively: key "FUNCTION", key "ORIGINAL SIZE", key "3".
For emergency input in switched off condition hold the keys "FUNCTION" and "STOP" for DP-1515, for the other device - a keys "FUNCTION and "CLEAR", and snap the tumbler of the feeding.
Now we in service mode, possible installthe developer; for what we call at in mode F8-09 and wait the completions of the process for 3 minutes. If this first start or was changed the drum, that executes the procedure F8-14. For leaving from service mode жмем on keys "FUNCTION" simultaneously and "Clear".
Most often used functions of the service mode:
F7 02 General counters mines F7 03 Counters mines before following preventive maintenance Unset "wrench" is produced by record in cell F7-03 importances 0 F7 06 Counters mines on installed drum F7 10 Counters mines on the same developer
F7 error indicates a fault with the water flow meter .
Check the sump filter at the bottom of the dishwasher, then close the
door and turn on the power. then hold the start button with the + and -
buttons under the LCD display, until the drain pump starts. This
should then reset the dishwasher.
Thanks,
John C
