Question about Bulova Watches
A little over a year ago I purchased a Bulova wall clock. On the back, above the bar code, is marked C4455, then some spaces, then CW112. The movement is the HERMLE 2215. When I replaced the batteries with two new Duracell C batteries, the clock still chimes (on the hour), but neither the minute or hour hand moves, but the quarter-inch brass "head" sticking out of the stem does move slowly, about a second at a time, which to me seems to indicate the movement is working. I was thinking of taking off the hands and trying re-installing them, but I don't know how to get the quarter-inch brass head off. It just seems to rotate when I turn it (without the batteries in) and does not seem to loosen. Any ideas?
  • 67 Answers
SOURCE: wall clock not working
If you are sure the hands are not touching as they pass, perhaps the minute hand and hour hand are binding together at the hub. Try this: Gently pull on the minute hand by gripping its hub with the nails of your finger and thumb. It should slide forward a little (or come off). Also the same for the hour hand, to ensure it is not binding on the face of the dial.
I don't know the particular clock, but if it has a SECONDS hand, this is often the one that needs to be freed.
If all the hands are free, all should be good. If it has a seconds hand and the clock stops when this hand is going "uphill", try a fresh battery. If this doesn't fix it, remove the seconds hand and use the clock without it. Or you could try to counterbalance the hand by adding a little weight to the opposite side... this could work, but as it increases the mass of the hand also, it still might be a problem.
Another way might be to shorten the seconds hand..!
Posted on Feb 22, 2008
  • 203 Answers
SOURCE: second hand moves every 4 seconds
the battery need replacing this is what its supposed to do when batt low. if this helps please rate joe
Posted on Nov 22, 2008
escapement
  • 2334 Answers
SOURCE: second hand movement
Your TAG is fitted with EOL (end of life) feature. This is the cause of that 4 seconds interval movement of seconds hand and thus indicating the time for battery replacement. The timekeeping is not affected by this- it is just warning to replace battery a.s.a.p.
Find your nearest watchmaker and ask for battery replacement.
Do not forget to rate, please.
Posted on Mar 07, 2009
escapement
  • 2334 Answers
SOURCE: Bulova 96R31 keeps time + date, but the chronograph does not work
The problem is in chronograph module or related gear train. To find what exactly the problem is, special tools and equipment is needed as well as watchmakers knowledge and skill. There may be just an underpowered battery, but according to your explanation, I tend to think that the first causes mentioned by me are the right ones. Visit your nearest watch repair shop and ask to check your watch for any faults. Rate me, please.
Posted on Feb 25, 2010
Testimonial: "I'm the one who submitted the question. Thank you, I will visit a watch repair shop. It's a shame the watch is only 2-3 months old! Thanks again "
escapement
  • 2334 Answers
SOURCE: Stuck second hand
You need a new battery, as there is not enough power to move both gears. You can send it back to Wenger and get battery replaced or just pop into your nearest watch repair shop and get it replaced. It will cost you $5.oo and will be done in 10 minutes time instead of months of waiting it back from Wenger. Rate me, plz.
Posted on Feb 26, 2010
I have a mans accutron bulova watch serial number H 963884 look for info year value
Value information here
https://www.google.ca/search?rls=com.microsoft:en-CA:IE-ContextMenu&biw=1438&bih=677&q=bulova+accutron+serial+numbers&sa=X&sqi=2&ved=0ahUKEwjM14mTz7PQAhUT4mMKHb7LB3YQ1QIIZCgB
Determining the Date of a Bulova Watch For purposes of assigning a date, Bulova watches break down nicely into three basic groups: 1) pre-1926, 2) 1926 through 1949, and 3) 1950 and beyond. Those three date ranges are differentiated by the presence or absence of certain case and movement markings as well as the nature of any such markings, as explained below.
In general, for all time periods, it is important to understand that Bulova watches never provide an obvious date of manufacture anywhere on the watch. Rather, the date must be "de-coded" using symbols, serial numbers, and two-character codes placed on various parts of the watch. These codes and the manner in which they should be interpreted is the subject of this article.
Many observers of Bulova watches are confused by the sometimes seen patent dates stamped on the inside of some Bulova watch cases, and they misinterpret such dates as the time of manufacture. In point of fact, those patent dates apply only to certain aspects of the case design and indicate only when those general designs were patented. Those designs were used on many watches produced over a number of years, and the applicable patent date in no way indicates when any particular watch was produced. Below are images showing the two patent dates that often cause confusion.
Read LOTS more HERE: http://www.watchophilia.com/general-information/determining-the-date-of-a-watch/
accutron bulova Google Search
Nov 19, 2016 | Bulova Watches
I648725
Since the 1950s Bulova has used a 2 digit date code, usually on the back below the serial number. The letter is the decade (L= '50s, M='60s, N=70s, etc.) and the number is the year. For example, a Bulova with a date code of M3 was made in 1963, one with N0 was made in 1970, and so on. Prior to the 1950s, it's more complicated.
Jul 18, 2014 | Bulova Accutron Watches
What do the numbers C837317 on the back of my ladies Bulova watch mean? The watch looks similar to the Bulova 98R98.
On the back are the specific "case" number. The numbers on the dial below the 6 o-clock position are the "model" number.
Oct 04, 2011 | Bulova Watch
I have a Bulova Watch that was given to a Clark Candy employee with a Serial Number of 523791. Looking for what year it was made and is it worth anything
The value of your watch depends greatly on the model / style, age, and case composition. It goes without saying, but watches (of any mechanical quality) that have real gold cases right now are worth quite a bit more than watches with gold plated, gold filled, gold-tone, or stainless steel cases. Presentation watches like those given to employees upon retirement were often gold or gold-filled--but there's a world of difference in value between those two types of watches.
In terms of age, it's much easier to date vintage Bulova watches by their "year code" than by their serial number. If you look carefully, usually above or below the serial number, you'll see a little alphanumeric code, like L5, N3, or P6. These can be translated as follows:
Lx = 195x Mx = 196x Nx = 197x Px = 198x Tx = 199x
Pre-1947 Bulova watches used little symbols to show the year of manufacture. A picture of those codes can be found here, as well as elsewhere on the Internet:
http://www.manleyhorlogerie.com/Watch_History/bulova.htm#Bulova%20Date%20Codes
Jul 24, 2011 | Bulova Watches
I got a vintage Bulova. it has A404403 on the back. What website I can check its year?
It's much easier to date vintage Bulova watches by their "year code" than by their serial number. If you look carefully, usually above or below the serial number, you'll see a little alphanumeric code, like L5, N3, or P6. These can be translated as follows:
Older Bulova watches used little symbols to show the year of manufacture. A picture of those codes can be found here, as well as elsewhere on the Internet: http://www.manleyhorlogerie.com/Watch_History/bulova.htm#Bulova%20Date%20Codes
Jul 13, 2011 | Bulova Watches
I NEED TO KNOW YEAR OF BULOVA LADIES WRIST WATCH ITS 10 KT AND I HAVE A SERIAL NUMBER z78782. it has bulova ms on back
A Bulova "M5" code would indicate that the watch was made in 1965. Vintage Bulova watches can be dated by this little alphanumeric code:
Pre-1950 Bulova watches used a variety of symbols and numbers (e.g., 47 and 48 to designate 1947 and 1948) to show the model year of the watch. A chart of those symbols can be found here: http://www.manleyhorlogerie.com/Watch_History/bulova.htm#Bulova%20Date%20Codes
Can any one tell me what year these Bulova watches were made
no not of these details only bulova can do this drop them a email
Mar 23, 2010 | Bulova Watch
The watch is a marine star purchased 6 months ago and two months ago began losing time
It's under warranty so send it back to Bulova. Or if you don't want to deal with Bulova you can pay a watchmaker to repair the watch.
Hope this helps,
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Nov 01, 2009 | Bulova Watch
Watches Logo
166 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
