Question about Sony Televison & Video
Permanent lines of color on the sides of the screen
    Novelist:
  • 99 Answers
I don't know what model of tv you have. I am guessing you need to do a convergence alignment. I don't think Sony has an option to do a partial alignment from the standard tv menu. Your best bet is to find a copy of the service manual and look at how to do a convergence alignment or have a service person come over and do it for you.
Posted on Mar 20, 2011
Two vertical black lines on the screen of my ps50b430
Unless someone played with the TV and disconnected the plasma display from the address buffer boards that go under the screen the prospects aren't good.
All vertical lines in all plasma TVs I have seen are operated by chips embedded in the fabric of the display as well.
When they fail they'd either short or burn open.
In the first case they'd prevent the TV from coming up, in the second they'd typically manifest as either black or a random color vertical line like you have.
This is not repairable...sorry.
The odds of this being something else is fairly minimal in my opinion.
Please don't kill the messenger...
bobby @ coppelltvrepair . com
Aug 25, 2012 | Televison & Video
Vertical Lines Dell Ultrasharp 2001fp
Sorry to say that it is a permanent damage of your monitor screen. Usually you can do nothing. But if you want to change the monitor screen, you have to visit a monitor & television specialist.
Cost will be 1/4 of a new monitor.
Sep 22, 2017 | Dell UltraSharp 2001FP 20.1" LCD Monitor
White line down side of screen
When the line is not there--go to a unused video input and examine the screen in that area--if you see a slightly darker area where the line was--it has permanently burned a mark in the screen itself.
Apr 25, 2012 | Samsung Televison & Video
Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
What you're describing is usually the result of an improperly seated connector. With the power disconnected, open the tv and locate any connectors between the LCD screen and the driver circuit board. Unplug them, and reconnect it assuring it's properly and firmly seated. Be careful when handling these cables as they tend to be quite fragile... take your time.
Nov 28, 2009 | Sony BRAVIA KDL-46V3000 Television
Permanent vertical line down monitor
The thin ribbon that connects the board on the back of the lcd screen to the front glass of the lcd screen got damaged.
It wraps around the top of the screen and is very thin and can be easily damaged.
May be from old age and heat at the top of the screen or it could have gotten hit at the top.
The cheapest way to repair this is to replace the lcd screen with a good used one because trying to find a shop to try to repair it would cost more than a new monitor.
It will change color with different colors and also if you push the screen at the top point. Don't play with pushing the screen too often as this may cause more to show up.
Sorry there isn't an easy fix to this.
Fran
Mar 29, 2009 | Acer AL2216WBD LCD Monitor
My screen on my asus 900 has two lines going across the bottom of the screen.
i may be incorrect, but i believe those lines are dead pixels, basically, they're lines of pixels (or dots) on the screen, that have become permanently one color, usually white or black
Jan 20, 2009 | ASUS Eee PC 900 Notebook
Vertical lines in my laptop screen
My understanding is that you have 2 laptops with the same problem, if that is the case, you need to replace the lcd. When you have lines on lcd's, that is a sign of a bad lcd.
Jun 10, 2008 | Toshiba G15-AV501 Qosmio Notebook
Plasma TV technical difficulty
if you can still see the picture its most likely the control board that's going bad, you will still need a tech out to fix the issue.
May 19, 2008 | LG 42PX5D 42 in. Plasma HDTV
what i recommend you to test is to press behind your monitor and see that the line goes off or not.If it does..that mean you have a loose connection,it can be fix.Incase no then you have problem with your LCD.Normally if its LCD problem then you fix this problem,all you have to do is change the LCD.
goodluck,takecare.
May 04, 2008 | Toshiba Satellite P30 P35 Series Notebook
Televison & Video Logo
24 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
